Old 04-29-2008, 10:33 AM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default How to check steering u joint vs rack ??
ok I've got the tie rod ends disonnected, and its STILL hard to turn the wheel...
so I've got it narrowed down to:
Steering rack
OR
steering knuckle going to the rack...
how can I narrow it down ????
IllNastyImpreza is offline   Reply With Quote
Old 04-29-2008, 10:54 AM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
if you are refering to the universal joint from the stearign column to the rack, take it out and see if it moves freely, it should flop around like a dead fish and be easy to move.
Old 04-29-2008, 10:55 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
awesome thanks Ill do that
Old 04-29-2008, 11:24 AM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
make sure you mark the position of the joint where it slips into the column and the rack so you can put it back in the same spot if it is ok.
Old 04-29-2008, 03:27 PM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
ok I've got both 12mm bolts out of the knuckles in the colum... what else do I have to take off the slide the colum out ???
Old 05-06-2008, 11:39 AM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
I've got both bolts out, and the steering wheel of... but how the hell do I take out the knuckle ??? it slides back and forth freely but there isn't enough room to slide it off...
what now ??
Old 05-06-2008, 11:49 AM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
you may have to drop the rack a bit to get enough clearance - try slackening off the driver side mount...?
make sure the bolts are OUT not just nuts off (there is a keyway on the rack shaft)
there is no need to remove the steering wheel btw
UkNuck is offline   Reply With Quote
Old 05-06-2008, 11:55 AM   #8
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
ok I got it ! and the knuckle is SHOT ! this means I don't have to take my entire rack out
I'm gona pick up a new one today... then go shop for a new steering wheel
the subaru tech sheet told me to take the steering wheel off... Why the hell did I need to do that ??????????? ****ing LAME
well... I guess its an exuse for me to pick up a new steering wheel thats a little more comfy ;P
Old 05-06-2008, 12:06 PM   #9
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
ok I need a Part name for the steering U joints shaft... I called autozone and he had no idea what to search under...
what is it called ???
DIY: how to remove rear knuckle on WRX (to install new wheel bearing) txl146 Brakes, Steering & Suspension 46 06-07-2014 11:49 AM
How to Install steering rack Bushings Mr. Mercado Brakes, Steering & Suspension 1 04-23-2008 06:34 PM
any tips on how to get shift knuckle swivel thing off wrxmase Transmission (AT/MT) & Driveline 7 03-23-2007 03:42 PM
Anyone know how to install Steering Rack Bushings... wrxunit8 Southern California Impreza Club Forum -- SCIC 24 01-26-2007 05:30 PM
how to prevent scratches from roof racks? criz Interior & Exterior Modification 1 12-02-2004 07:28 PM
