#1 |
Member#: 151842
SCIC
Vehicle:07 WRX |
Im planning on getting a new hid kit for my 07 wrx...does anyone have any suggestions?
I was also wondering what the size of the bulb is for the headlights as well as the size of the bulb for the reverse lights...thanks in advance
#2 |
Member#: 128269
Vehicle:2007 STI Limited [ugm] #311 |
Your halogen projectors are not made to take HID bulbs from a drop in kit. You will get poor results from a kit and blind oncoming drivers.
You should read the HID FAQ's and do some more research before you waste your money. |
#3 |
Member#: 159636
Vehicle:2007 WRX -18G EWG WRB |
They work great for me, and no complaints from others http://forums.nasioc.com/forums/show....php?t=1428163
for bulb sizes go to : http://www.sylvania.com/ConsumerProd...lacementGuide/ |
#4 |
Member#: 139076
Vehicle:2002 stg2 wagon 03 suzuki sv650s |
myride is your mom, that has to be the worst set up i have ever seen. im sorry.
i know you spent alot of time and money, but damn dude, you are blinding anything and everything at night, and NOT getting the best ouput possible. infact, you have most likely detracted from the original OEM light output quality. edit: to rex, since your headlights use h11 bulbs, there is not much you can do to improve your lighting, other than a projector retrofit. hid kits are not a good investment, no matter how many people come on these threads saying theyre good. if you research and read, 99% of these "what kind of HID kit should i get" threads end with the mods locking them, because enough knowledgeable people make their correct points. double idiot edit (haha): i was thinking he had a 08 for some reason. please do some research. dont buy a kit just because it looks nice having 6000k lights. trust me, it does not look l=nice on the road, and definitely does not look nice being glared into other drivers eyes at night. Last edited by jdubya301; 04-29-2008 at 09:03 PM. |
#5 | |
Member#: 128269
#6 | |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
the WRX takes h7 in the headlights. HIDs actually work fine. TxWrx had a set of McCulloch HIDs in his and it is not a problem. we reaimed the lights slightly lower, and never had any problem with glare. trust me i was always in front of him. or driving at him....or watching him drive by. the light output, was just as good as stock. with no hot spots. we also replace his fogs with yellowstars, then some cheap yellow bulbs from autolumination, the combo looked great. his hids were 5000K. i can probably find some pics if need be. the reverse lights iirc are 7440. single filament wedges. |
#7 | |
Member#: 128269
#8 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
since you have a 07 to a TSX retrofit. it wont cost much and you will have lights that are 10x better then if you do a hid kit. also, pick up some good oem HIDs (ballasts and bulbs) they will last much longer and you will find it easer to find replacement parts if you need them.
#9 | |
Member#: 128269
s2k's are nice too, but of course I'm biased ![]() |
#10 | |
Member#: 139076
i agree that d2s with adapters in an h7 application works pretty well. |
#11 |
Member#: 125495
RMIC
Vehicle:06 Wrx SGM stg 5+4-7 |
I guarantee that if you throw a HID kit in you will have hot spots and glare, even with the 06 07 wrx projectors. just go aim your lights at a dark wall. The hot spots and glare arent even close to as bad as reflector HIDs but its still there if you look close. i wouldnt say that its blinding either as i had some myself. But definitly go with a retrofit. Its worth the extra money.
#12 |
Member#: 161832
Vehicle:2000 Outback Limited Black |
try xenonexpert.com for apexcome HID conversion kit. i love mine and haven't seen any negative effects from it.
#13 |
Member#: 159636
Yeah, they really do work great. It may not be 100% of what it could be, but its damn near close. I have been running this for 3+ months and have never been flashed to dim. The reason I put the HIDS in is so i could see better, if it didnt work great, I would have taken it out. Ill try and get some good pics in a dark setting (cut off, spread, hot spots, etc)
#14 | |
Member#: 128269
#15 | |
Member#: 140712
SCIC
Shane |
#16 | |
Member#: 125573
TXIC
Vehicle:2006 2.5i ProTune by Sean S. |
Blake Last edited by bsikora; 04-30-2008 at 03:30 PM. |
#17 | |
Member#: 139076
flame on. enough said. i will save my breath |
#18 |
Member#: 4597
TXIC
#19 | |
Member#: 128269
I tried a drop in kit in my 05 WRX when I first got the car and was ignorant about HID lighting. So don't try to BS me and everyone else on here and try to tell me your lights aren't glaring all over the place, because they are. And if you still think your drop in kit is amazing, then drive your car up against a wall, take a picture, and prove the results that you and other members are raving about. Then I'll show you a picture of the cutoff of my s2k retrofit and show you how poor your lighting really is. And just because people don't flash their high beams at you, doesn't mean your lights aren't annoying them. |
#20 | |
Member#: 139076
#21 |
Member#: 159636
Also, dont the 05's just have reflector? where as the 06-07 MY has projectors? Maybe thats part of the reason for the poor results?
P.S. I will post pics of my car against a wall, just give me a couple days, I would love to see the comparison |
#22 |
Member#: 139076
yep. 02-03 have reflectors. 04-05 have reflectors. 04-05 sti's also have reflectors, but they were made to mate with d2r HID bulbs.
#23 |
Member#: 4597
TXIC
yeah the reflector on the o4's and o5's are horrible for hids. i had an o4 rs and was considering it, until i saw pics of the hids....horrible. but the o6 and o7's are projectors. granted they are "designed" for halogen, they do a very good job of cutting off the beam. so the hids are not HORRIBLE. you are comparing apples to oranges.
you had an o5 with bad reflectors and hids compaing to an 06 with projectors and hids and then to an s2k retrofit. of course a correct retrofit is going to look better, especially with some of the better projectors available. but he is not asking for that. just because they dont flash doesnt mean it doesnt annoy them? so then how do you know it IS annoying them? same way you assume it is, others will assume its not. |
#24 |
Member#: 158498
Vehicle:07 WRX w/ JDM 6spd SWP |
06/07 is different from all years, so you really cant compare them at all to other years...
#25 |
Member#: 162299
South East
Vehicle:2007 Impreza WRX OBP 93 Impreza L, 91 Legacy L |
i have a sort of related question...how do i tell the projectors from an 06-07 sti to a wrx one? I have a set in front of me but i cant seem to distunguish whether it is a sti one or just a regular wrx one...the guy whoi bought it from said they were for the sti but now that i look at them i cant see any sort of... markings that would suggest that is true...
| Thread Tools | |
| Display Modes | |
| 06/07 WRX headlight swap for OEM 06/07 STI HID headlights! Plug n play? Melted wires? | subierider | Electrical & Lighting | 31 | 05-12-2010 01:34 PM |
| WTB 06/07 wrx headlights/ headlight wireing harness | knighter | Private 'Wanted' Classifieds | 1 | 01-06-2010 08:46 AM |
| Question about 06-07 STi headlights vs 06-07 WRX headlights | downsti | Interior & Exterior Modification | 4 | 08-06-2009 03:18 PM |
| WTT-Baltimore-06STI HID Headlights for 06-07 WRX Headlights plus cash | Psybin | MAIC Private Classifieds | 3 | 10-23-2008 12:34 AM |
| WTT-Baltimore-06STI HID Headlights for 06-07 WRX Headlights plus cash | Psybin | Exterior/Styling | 0 | 10-21-2008 01:28 PM |
