Old 04-29-2008, 04:24 PM   #1
Giganticprune
Member#: 147662
2006 wrx tr stage 2
Default hooray. new system in the works!
so, here it goes. it has begun. after realizing i cannot fit (8) eclipse sw4200 10 inch subs. im ordering (4) kicker L5 12's on friday. unfortunately the came out to be a little more expensive than i hoped (105 a piece :P ) if im not mistaken ill need to order the dual 4 ohm coils right?
the box is going to be sealed with the subs being mounted inverted due to mounting depth issues. the 4 channel will be hidden under the cover plate.
4 channel = mtx ta3404, possibly to be upgraded to something with a little more power.
mono amp = kicker zx1500.1, possibly to be swapped out for the zx2500.1 down the line.
im excited
Giganticprune is offline   Reply With Quote
Old 04-29-2008, 04:29 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Yes, you'll need the dual-4s homie. I'm still a little curious why the L5s, 3 L7s would be just about the same volume, but then again you wouldn't get QUITE the same power at 2.66 as you would at 2.00
Let us know how it turns out!
Audiosavvy is offline   Reply With Quote
Old 04-29-2008, 04:52 PM   #3
Giganticprune
Member#: 147662
2006 wrx tr stage 2
you know exactly why i want 4 subs. cuz lyke omg i can haz moar subz. its just kinda one of those, if i can, whynot? im just waiting on the carpet to come from parts express and i need to do another 2 layers or so on the glassing.
it looks like a big booger in my opinion
Old 04-29-2008, 04:55 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I know, that's what I mean. 3 L7s would be very close in volume to 4 L5s, but either way you will be happy .
So what are you gonna do under the hood to get that heavy-ass brick moving now?
Old 04-29-2008, 05:02 PM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Dam dood, if a impreza trunk didn't rattle bad enough as it is... this is just.... well, a lot.. lol... yeah, and i'm the guy going with 2-15's..lol
How thick are you planning for the glass?
Old 04-29-2008, 05:04 PM   #6
Giganticprune
Member#: 147662
2006 wrx tr stage 2
about 8 layers. but i may do 7, ive been using more resin than i usually do because its been a while since i did any glassing. plus im still not that good at it, so then the matt doesnt do what i want it to; i kinda drown it in resin.
Old 04-29-2008, 05:15 PM   #7
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Well, just remember this for your trunk lid... lol...
Old 04-29-2008, 05:20 PM   #8
Audiosavvy
Member#: 150794
Qcab dakota 4x4
^^^ no, methinks you're gonna need a whole mess of this
Old 04-29-2008, 07:01 PM   #9
Giganticprune
Member#: 147662
2006 wrx tr stage 2
yeah, its all about that low-alkali cement. none of that regular crap.
as far as sound deadening, i did a bit of dynamat on the trunk lid and the deck lid a while back. im gonna have to make some adjustments on the decklid
Old 04-29-2008, 07:21 PM   #10
subaru3169
Member#: 55252
* pullup bar *
wow 4subs in an impreza.. a SEDAN impreza!! can't wait to see the finished product=)
subaru3169 is offline   Reply With Quote
Old 04-29-2008, 07:38 PM   #11
Giganticprune
Member#: 147662
2006 wrx tr stage 2
well im dropping the money off to my friend on friday. kicker is usually pretty quick with the shipping, so hopefully within 2 weeks it will be done. obviously ill keep everyone posted.
Old 05-19-2008, 07:18 PM   #12
Giganticprune
Member#: 147662
2006 wrx tr stage 2
theyre here!
other 3 are in the back seat. hope to finish the box up in the morning
Old 05-19-2008, 07:46 PM   #13
iridebmx
Member#: 153116
2008 WRX 5-Door
SWP Necklace
Can't wait to see the finished product. Looks good so far!
iridebmx is offline   Reply With Quote
Old 05-20-2008, 01:57 PM   #14
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
It's going to be to loud for the body structure, I've SEEN peoples cars, that have ripped the trunk lock from the trunk before doing similar... I'm figuring this will be no different
Old 05-20-2008, 03:20 PM   #15
Giganticprune
Member#: 147662
2006 wrx tr stage 2
finishing the cover plate and re-running the 4-channel rca's in the morning. the 4 channel will be hidden under the cover plate.
Old 05-20-2008, 03:38 PM   #16
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You are a MADMAN.... lol....
Now you need to do the front up like this, so you can hear something besides the subs...
Old 05-20-2008, 04:34 PM   #17
mrgreg
Member#: 75622
Looks like a torture chamber.
mrgreg is offline   Reply With Quote
Old 05-20-2008, 06:11 PM   #18
iridebmx
Member#: 153116
2008 WRX 5-Door
SWP Necklace
Like your front stage bright?
Old 05-21-2008, 01:38 PM   #19
Giganticprune
Member#: 147662
2006 wrx tr stage 2
now i gotta go run to an audio shop to use their volt meter..i guess i didnt do the series-parallel wiring right so my amp is cutting out.
but im happy with how it turned out
Old 05-21-2008, 01:49 PM   #20
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Looks GREAT man, to bad for your poor trunk space though...lol...
I gotta ask, do you have any bracing inside the box, between the woofers? If not you really should, that thing has got to flex like a somabich..
A good 1" dowl right in the center would help a lot..
Old 05-21-2008, 02:06 PM   #21
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Looks clean man. Not quite my cup of tea, but very nice. I hope your top-end can keep up
Old 05-21-2008, 02:14 PM   #22
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
Looks good but I would try to hide the wires a little better, they look like they're just dangling there and detract from the rest of the clean area...
What wiring problem are you having? You have 4 dual 4 ohm right? Did you wire them all up in parallel? That would cause a .5 ohm load - the amp can only do 1 ohm right? If you did each sub in series between the coils and then in parallel with each other you'd have a 2 ohm load...
ptirmal is offline   Reply With Quote
Old 05-21-2008, 02:47 PM   #23
Giganticprune
Member#: 147662
2006 wrx tr stage 2
i dont know exactly what happened, but everything wasnt wired in all parallel, but for some reason it was still coming out to .5 ohms, got it all taken care of though. its pretty loud, i was expecting a little louder, but it sounds pretty clean; which i wasnt expecting.
and..no bracing inside the box...i thought about it, but that bump where the spare tire usually screws into makes a very awkwardly shaped surface, so bracing was really hard to do.
and with so many wires going between the subs, its kinda hard to hide them. i couldnt come up with anything creative.
Old 05-21-2008, 04:06 PM   #24
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Oh yeah, I forgot about the hump....
are you using the hump to hold the box down? If I envision your box in the first pic, the centerline falls somewhere forward of the hump
Old 05-21-2008, 04:31 PM   #25
Giganticprune
Member#: 147662
2006 wrx tr stage 2
nope, nothing is holding the box down. doesnt really need it, ive built a couple of these spare tire sub boxes, havent had a problem with them trying to escape.
but ill think about the whole bracing thing. i just have no free time for aynthing right now. i still havent re-run my 4 channel wires so my interiors are still all fudged up
new dry sump system in the works benw Built Motor Discussion 138 05-03-2011 12:23 AM
New patch in the works for 16bit models xswrex Open Source Reflashes 71 03-31-2009 08:03 AM
New suspension system in the mix! jnorth85 Brakes, Steering & Suspension 6 01-07-2008 06:23 PM
New movies in the works phillywrx Off-Topic 54 11-08-2003 02:01 AM
Possible new SVX in the works? HomerJay SVX Forum Archive 6 08-22-2000 08:50 PM
