Old 04-29-2008, 09:41 PM   #1
brian3676
Member#: 167849
2000 Impreza 2.5rs
Default Re used head bolts... caused head gasket to blow again?
Well i called the guy who helped my do the head gaskets the first time when they blew on my 00 2.5rs. turns out he reused the head bolts. i thought on subaru's u are supposed to use new ones? he works at a dealership and says they dont use new ones at the dealership eather, but now i have about 8,000 miles on the motor since the new HG were put on the there leaking again, this time the oil is getting into the coolent though, not the normal external blow they usually have, yes the heads were resurfaced and the block was checked and it was fine, so anyone think it could have been the head bolts that made it leak this time? its the only thing i could think of
brian3676 is offline   Reply With Quote
Old 04-29-2008, 10:14 PM   #2
decke48
Member#: 178804
1998 lgt
yes subarus use "streching" head bolt. and must be replaced when removed.. might be leaking because of the reused head bolts but might of been torqued wrong or out of order and actully warp the head..
decke48 is offline   Reply With Quote
Old 04-29-2008, 10:47 PM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Internal headgasket leaks are just as common as external leaks.
I just double checked the FSM, replacing the head studs is NOT required or even recommended. I've never seen them replaced on a car in the shop either unless specifically requested (and the customer pays for the parts/labor to replace them of course).
Its more likely that they didn't follow the tightening procedure properly if anything.
Old 04-29-2008, 11:09 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Yeah, on subaru's they can be reused apparently (I had to get my head around this too...coming from the ****astic Ford Essex engine). +1 on improper tightening sequence. Did you guys use a torque wrench that's properly calibrated too?
rougeben83 is offline   Reply With Quote
Old 04-29-2008, 11:39 PM   #5
brian3676
Member#: 167849
2000 Impreza 2.5rs
i did not do the tourquing my friend did but i am sure he did it right he is a full subaru tech and a dealership and does HG all day long, i have a few other friends who work there too and they all said he is really good and is the main person who does the HG on cars that are brought in. who knows though guess ill do it again! i work on hondas and nissans mostly i am a ASE tech but have never done a subaru though. on nissians u usually use new head bolts not always though depends on the engine and on honda they are not strech bolts so u always re use then, i have never reused a strech bolt though
Old 04-30-2008, 12:11 AM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Hmm..it could just be a bad gasket...I dunno. By your posts it doesnt seem like there wouldve been any warping from the previous blown HG that couldve led to improper mating of the new gaskets...
At least you guys can do it yourself...not losing like $1000 everytime you have to do the HG again.
Old 04-30-2008, 12:26 AM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I always reuse those bolts... but I also have the heads decked.
jamesfacts is offline   Reply With Quote
Old 04-30-2008, 02:08 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Like I said, they aren't bolts, they are studs. So installing new ones isnt as easy as just replacing bolts, and also not necessary.
Have you done anything to the car since the headgaskets were replaced? Run different coolant or oil or any mods, anything of that sort? If you havent done anything, i'd re-contact the dealership and ask them to re-diagnose it and if the headgaskets did indeed go bad again after the repair, ask them to at least split the cost of the repair or do something for you, since obviously headgaskets shouldn't be going bad again after 8,000 miles...
Old 04-30-2008, 09:46 AM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Subaru Stars
Ditto. I blame either heads that were warped and not decked or a tech who didn't properly clean and prep the mating surfaces. Even the best of techs make mistakes. Saying that he does dozens of them just ups the odds that he will do one wrong. All he has to do is one wrong one for it to be you. This isn't saying that your buddy is a bad mechanic. This is saying that he's human...
Old 04-30-2008, 10:04 AM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I've reused mine probably 6-7 times and don't currently have a head gasket leak, nor have I ever decked my heads. *shrug*
Old 04-30-2008, 09:09 PM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Why have you taken your engine apart 6-7 times?
Old 04-30-2008, 09:16 PM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
1- Warranty replacement
2 & 3- Broke piston (turbo kit) (put it together before realizing head gaskets were on wrong, doh!)
4 - Hydrolocked (small puddle, not so small)
5 - Head gasket replacement
6 - Timing belt pulley bearing exploded
Ok, so 6. And no, they didn't replacement them on either 1 or 3 according to the invoices.
Needless to say, the next time I take it apart, it will being parted out (swap coming sometime this year).
Old 04-30-2008, 11:37 PM   #13
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
the head bolts can be re-used without a problem if the correct torquing procedure is followed.
bugeye829 is offline   Reply With Quote
Old 04-30-2008, 11:44 PM   #14
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Sorry
Old 05-01-2008, 07:00 AM   #15
Storm
Member#: 5218
96L Most Over-
Developed Beater
This is how we gain "experience" ..........
Jay Storm
UTEC causing IGN fuse to blow? Ken Cravillion UTEC 5 06-17-2010 10:35 AM
Re used head bolts? rollingindiana Built Motor Discussion 9 08-26-2008 10:42 PM
sti cluster install causing radio fuse to blow?? 02blkwagn19 South West Impreza Club Forum -- SWIC 3 04-24-2008 01:05 AM
head bolts on 2.2, re-use or new schrott Normally Aspirated Powertrain 8 02-28-2008 12:48 PM
Will Nick's generators cause gas prices to rise again? -=C=- Off-Topic 7 10-27-2005 03:45 PM
