Old 04-29-2008, 10:20 PM   #1
Lamb155716
Member#: 155716
2008 Spesh Pitch Pro
2010 Spesh Roubaix Elite
Unhappy installed oil pressure sensor-> CEL HELP!
i just installed a prosport oil pressure sensor in the galley plug under the intercooler.
When i started the car the pressure was floating around 90-100 psi at idle.
however, the car had a CEL. (also the cruise light is flashing)
help needed please.
im afraid to drive the car and i need to get to school tomorrow.
Lamb155716 is offline   Reply With Quote
Old 04-29-2008, 11:07 PM   #2
dibblejr
Member#: 94070
05 LGT
Do you have anyway to pull the code? Did you disconnect the TPS harness? If so just do a hard ecu reset, pull the -neg battery terminal and then hold your foot on the brake pedal for 15-30 seconds with the key out of the ignition.
It is a tight squeeze to get to the galley port so depending on what you removed from the car it could be anything. Try the ecu reset above and if the CEL comes on again go get the code read.
Jay-R
help needed please.
dibblejr is offline   Reply With Quote
Old 04-29-2008, 11:26 PM   #3
Lamb155716
Member#: 155716
i reset the ecu and the cel was gone.
i guess it was the tps after all.
*relief* thought it was something really serious
thanks
Old 04-29-2008, 11:28 PM   #4
dibblejr
Member#: 94070
05 LGT
you are welcome
Jay-R
Where to install oil pressure sensor? Alaskan EJ20 Alaskan Impreza Club Forum -- AKIC 10 02-21-2008 08:56 PM
Oil Pressure sensor... where to install it? sizzflair Newbies & FAQs 8 10-09-2006 12:31 PM
JDM EJ207- Where to install oil pressure sensor jjameson Subaru Conversions 2 01-25-2006 07:23 PM
Oil pressure sensor install problems mmm3587 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-22-2002 06:36 PM
