Old 04-30-2008, 12:19 PM   #1
Rex_Guy
Member#: 45140
2004 WRX
WRB Cobb Stage 2
Default Tranny fluid ---> Grinds
Yet another thread on tranny and grinding. Did a search but didnt find anything to what I have. At 60k I did the tranny fluid change with Mobil 1 synthetic (Heard its good and others say bad). Anyway since then Ive had a grind going into 1st, also what concerns me more is upshifting into 4th at higher than 2K rmps gives me a fairly decent grind.
Last week I changed the fluid with valvoline 75w90 non-synthetic. Still no change at all.
So I am asking what could be causing the grinding in 4th at > 2K rpms??
Rex_Guy is offline   Reply With Quote
Old 04-30-2008, 01:04 PM   #2
subyduby
Member#: 107889
04 wrx 16g'd
Default redline lightweight shockproof...
I had a similair problem getting into 4th gear. I called Andrewtech after double cluthing for months. He said to try Redline Lighweight shockproof gear oil. I put it in and presto, sychros work again. I will say that the oil is not a GL5 rated product, but many people use it anyway. For example it is a big ingredient in the mixture that many members are using, something (cocktail), not sure of the first name. Otherwise I was going to open the tranny up and change some things out for the fix. This, (even if only temporary) has solved my problems for the time being. if the tranny goes i know I did all i could before a rebuild is necessary.
Hope this helps!
subyduby is offline   Reply With Quote
Old 04-30-2008, 01:07 PM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I had the same problem, as well as grinding going into 1st from neutral, and the car did not want to downshift. I added Scotty's Cocktail to the tranny and it's been working smooth as butter for 25k miles.
I tried just Redline at first, and it helped just a tiny bit, not nearly enough, but it may work for you as it did for subyduby
Audiosavvy is offline   Reply With Quote
Old 04-30-2008, 01:35 PM   #4
smurfwrx
Member#: 151928
09 Triumph S3
redline works for me. I'll be adding a little motul300 based on andrewtech's recco. for a little bit smoother shifts. < this guy needs shifter bushings
smurfwrx is offline   Reply With Quote
Old 04-30-2008, 01:38 PM   #5
bluesubie
Member#: 767
04 FXT
Synchros gone bad?
-Dennis
Old 04-30-2008, 03:35 PM   #6
Rex_Guy
Member#: 45140
2004 WRX
WRB Cobb Stage 2
hmm, well I'm going to have to try scotty's cocktail and see if thats a fix. If not I suppose its off to the dealer to get checked, aka get porked.
Thanks for the help and anymore input would be excellent.
Old 04-30-2008, 04:39 PM   #7
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I'd be willing to put down a bet saying it will fix your problem and then some. You will be pleasantly surprised
Old 05-01-2008, 12:16 PM   #8
growling_boxer
Member#: 165744
2000 LGT
2007 STi
it seemed to take a while for my tranny oil to "settle in." i have no idea why, but when i had my MT fluid changed from factory to Mobil1 at 135,000 it seemed to only get a little better. but then over the next 5000 miles, the grinding completely went away (bad 5th gear grinding from skipping a gear or two into 5th too frequently back when i first got my legacy). i thought i was going to need a tranny rebuild, but in dragging my feet for financial reasons, the problem solved itself.
growling_boxer is offline   Reply With Quote
Old 05-03-2008, 12:03 AM   #9
mikeythejew
Member#: 141672
Thumbs up
cancel
mikeythejew is offline   Reply With Quote
Old 05-03-2008, 03:07 PM   #10
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
..oops, didn't read the part about dumping the M1....
jac04 is offline   Reply With Quote
Old 06-02-2008, 03:19 PM   #11
Rex_Guy
Member#: 45140
2004 WRX
WRB Cobb Stage 2
just to cose out this thread. Put in scotty's cocktail and the tranny is working great!!! All fixed....for now atleast.
Changed tranny fluid, now 4th gear grinds shamrock 05 Transmission (AT/MT) & Driveline 12 10-29-2008 08:49 PM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 06:54 AM
What tranny fluid to reduce/eliminate grinding? Jaredm83 Transmission (AT/MT) & Driveline 6 10-11-2004 12:09 PM
Rear diff fluid & tranny fluid rich22 Service & Maintenance 7 05-06-2004 11:04 AM
WTB: Redline Tranny fluid and Rear Diff fluid RimRockaz Bay Area Impreza Club Forum -- BAIC 11 07-16-2002 04:19 PM
