Old 04-30-2008, 01:56 PM   #1
SCOOBYdudematt
Member#: 134380
'05 CGM STi
GT35R'd with 315mm tires!
Default need help, leaky oil in engine bay PICS!!!
Well yesterday there was leaky oil and blue smoke coming out of the back of the car when i got on it, checked the oil level today and it has 3 quarters, it was full yesterday... I know that i may have a blown piston ring because of the exhaust coming into the block, and through the pcv valve lines, but what could cause these pools of oil??? they are all by the intake shroud, and the left side of the car, but it is not on the motor, just on the sidewall, was not there yesterday. Im guessing it may be the oil inlet line to the turbo??? any comments are appreciated
SCOOBYdudematt is offline   Reply With Quote
Old 04-30-2008, 02:18 PM   #2
bdpAKAknox
Member#: 121248
possibly a valve cover and or spark plug tube gasket from the looks of your first picture.
bdpAKAknox is offline   Reply With Quote
Old 04-30-2008, 02:29 PM   #3
Steel06STI
Member#: 129711
1999 2.5 RS
whatever it is it looks to be spraying from somewhere, you may have had a boost leak and the oil from the blown ring is getting pushed out. good also be a turbo oil seal.
run a compression if that number is ok then start troubleshooting turbo. (variance less than 10 psi between banks
Steel06STI is offline   Reply With Quote
Old 04-30-2008, 02:48 PM   #4
SCOOBYdudematt
Member#: 134380
'05 CGM STi
just pulled the charge pipes, (to IM, and to turbo compressor housing), both had lots of oil in there .
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 03:51 PM
Help! Random Hoses in Engine Bay! Sh4k3NSTi Newbies & FAQs 3 07-03-2009 09:49 AM
OIL in engine bay......looks like its from turbo Whoop_ass Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-27-2006 11:40 AM
Need 12V+ switched power in engine bay, ideas? bboy Electrical & Lighting 3 06-07-2005 09:29 PM
help plz - rattling in engine bay 03 Black R3x Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-22-2004 05:47 PM
