Old 04-30-2008, 09:14 PM   #1
hoffmanEstates
Member#: 122043
04 wagonier
psm
Default hid prob
ever since hids i put hids in my radio and CB have static why what can i do? to stop this and dont say - the hids. cause sti and others have hids. do i need to sheild some wires?
hoffmanEstates is offline   Reply With Quote
Old 04-30-2008, 09:41 PM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
how are they hooked up? and btw, almost anything in my wrx causes static on my cb. even the turbo spooling
jdubya301 is offline   Reply With Quote
Old 05-01-2008, 11:20 AM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
To see if the CB antenna is picking up the noise remove the antenna connector from the radio. If the noise goes away then it is being picked up by the antenna. If the noise is still present then it may be coming through the power system.
If the antenna is picking up the noise you might try placing some aluminum foil around the ballast transformer fot the lights. If the noise is being picked up through the power lead then you might try using a ferrite noise suppressor near the power input to the lights.
Cougar4 is online now   Reply With Quote
Old 05-01-2008, 03:38 PM   #4
Handsdown
Member#: 29355
or you could get rid of your hid's
Handsdown is offline   Reply With Quote
Old 05-01-2008, 06:16 PM   #5
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
+1
Cheap HID kits cause all kinds of problems but this is the first time I have heard of this. Those kits are not manufactured to any standards like the OEM parts are. It is possible to cause interference because of the high voltage created by the horrible $4 ballasts. Older ignition systems did this a lot.
Shielding the wires only will likely do nothing. You could try shielding the ballast and the wires going to the bulbs. It probably won't do anything though. If it were me I would throw the HID kit in the garbage and put some nice halogen bulbs in. If you really still want HIDs do a retrofit with OEM parts and projectors. This way you won't blind people, you have much better light output, and they will likely last longer than the car.
Ryan
FourOnTheFloor65 is offline   Reply With Quote
Old 06-05-2008, 11:30 PM   #6
full of dents
Member#: 181717
12 sti hatch
w r b
bump
im experiencing the same problem. i actually just posted about it on clubwrx.net couple people on there with same problem. i got my HIDs from mod-express.com. i put the same ones on my 240 with no problems or radio static
wanted to see if anyone came up with a solution
Jay
full of dents is offline   Reply With Quote
Old 08-04-2008, 12:42 PM   #7
full of dents
Member#: 181717
12 sti hatch
w r b
bump - still looking for solution to this
Old 08-04-2008, 01:33 PM   #8
steverx05
Member#: 128269
Did a 3 year old start this thread? I can't even understand what the question is here. Are you guys experiencing static on your CB radios from a drop in HID kit, or are you getting static on your regular stock radio? How are your kits wired up? Are they wired directly to the stock headlight wiring or have they been attached to the battery using a relay wiring harness?
steverx05 is offline   Reply With Quote
Old 08-04-2008, 01:51 PM   #9
GeoffSFAs10
Member#: 173996
you need a better ground
GeoffSFAs10 is offline   Reply With Quote
Old 08-04-2008, 02:19 PM   #10
full of dents
Member#: 181717
12 sti hatch
w r b
this isnt my original thread. im just having a similar problem with my radio...tried better ground, tried more grounds, tried better radio ground. nothing
EDM hids in pre HID 02 bugeye, HID not ignigting trueno92 Interior & Exterior Modification 0 10-07-2009 11:57 PM
Rear Rotor prob or alignment prob? kaijubei Brakes, Steering & Suspension 7 08-03-2009 02:15 AM
HID grounding prob, no more fogs or hi-beams HongKongBeef Electrical & Lighting 2 08-24-2006 07:58 PM
Synchro prob or clutch prob? Evaider Transmission (AT/MT) & Driveline 4 03-19-2002 10:27 AM
RS probs, n1 same probs ? Kwez Technical Forum Archive 9 10-11-2000 10:12 PM
