Old 02-22-2002, 03:04 PM   #1
bbaerotek
Member#: 10427
WR Blue
Question Anyone here actually install Koni inserts?
If anyone has I would appreciate some pointers or any info on any modifications needed to make them fit.
I have read several posts where people have alluded to having to modify them to get them to work. If anyone has actually done it I would appreciate some install tips.
Thanks in advance,
Brian
Just waiting on the UPS man!
bbaerotek is offline   Reply With Quote
Old 02-22-2002, 03:45 PM   #2
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
If you try a search here, a member on the board has them (I can't remember his name). I just PM'ed him the other day, but have not heard back.
What part numbers did you order? I can't seem to find a part number for the rear struts because they have fitment problems.
Also, did you order for a sedan or a wagon?
Paul G.
paultg is offline   Reply With Quote
Old 02-22-2002, 04:36 PM   #3
bbaerotek
Member#: 10427
WR Blue
Post Part Numbers
Here is what I have for part #'s
8610-1351- front
8610-1352 rear
The rear is listed by Koni as a special order part.
But the vendor I used (eshocks.com) says Koni USA is now beginning to stock them.
I am not sure about the fitment problems. I would like to know what I am getting myself into.
I have a sedan BTW.
Old 02-22-2002, 05:21 PM   #4
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Silvuh
Default Koni
The rear Koni struts should be available in April. I ordered a set for my WRX Sedan and I specifically requested no inserts. The fronts are fine, you'll just have to wait a month or so for the rears.
Dave
Scoobie Doogie is offline   Reply With Quote
Old 02-22-2002, 09:35 PM   #5
paultg
Member#: 437
'91 Miata MX5 (Red)
This is the member on the board (who has posted about the install) : trhoppe
If you do a search under "Koni" for the past year in the Suspension Forum, his post should come up.
bbaerotek:
Thanks for the part numbers. Are your struts both inserts front and rear, or just the rears?
Scoobie Doogie (Dave):
You kind of confused me. Are your front struts not an insert, but a complete strut, and your waiting for the rear complete strut to come out the end of April (where did you hear that)?
The reason I asked:
If I do decide to go with Koni's (which I thought were all inserts), I would buy a 2nd set of WRX Struts/Springs (Used) to hack up.
Thanks guys. Sorry if this has been covered. I have only been researching it for the past few days, and haven't had much time to read.
Paul G.
Old 02-23-2002, 01:29 AM   #6
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Silvuh
Paul,
The front struts are the same for the WRX and the RS. The rears were the inserts that you have to cut-up. They were designed for the RS and not the WRX. Koni is manyfacturing struts for the WRX now. The fronts are available now and the rears will be available in April. Info source is John at Stranoparts. www.stranoparts.com Of course now you have me second guessing myself and therefore I am calling them on Monday.
Dave
Old 02-23-2002, 09:41 AM   #7
IXLR8
Member#: 14570
'02 WRX
OK, now I'm confused...
Been following (pretty much) the Koni insert discussion for a while but if you cross reference the part number listed for an '02 WRX by Stranoparts (8610 - 1351/52) on the Koni web site, you find that number listed only for:
"1994 - 2000 - Impreza 2.0GT Turbo Sedan/Wagon (Plus) 4WD for original KYB struts only "
Am I missing something? It's very possible I am (wouldn't be the first time), I didn't think these two applications were the same. Anybody know for sure?
IXLR8 is offline   Reply With Quote
Old 02-23-2002, 10:49 AM   #8
paultg
Member#: 437
'91 Miata MX5 (Red)
Here is what I find on the Koni-na site:
SUBARU Impreza 2.5 RS AWD, 94-99
Front: 8610-1351 Sport
Rear: 8610-1352 Sport
Special McPherson strut insert bolted into OE housing after cutting top and removing old internal parts. For OE KYB only
So, these part numbers are not for our '02 WRX cars. They fit though, with some modification. If they were for our cars, they would be listed as a '01 Impreza application (since that's when our WRX was available everywhere else), or a '02 model since our car is an '02 car. If the application says '00 or less, it is for the older body style (I think).
I think people have installed the RS inserts in WRX strut housings.
So, you have one option:
1. Order WRX specific front Koni inserts for the WRX and rear RS inserts and make them fit.
I am going to wait it out I think, and see what happens.
Paul G.
Old 02-23-2002, 12:06 PM   #9
IXLR8
Member#: 14570
'02 WRX
thanks Paul, seems right to me... you hit pretty much all the options I'm looking at, and with the same conclusion... I'm waiting too.
Old 02-24-2002, 11:55 AM   #10
Gary (gg)
Member#: 179
98 2.5RS
Rally Blue
Check out a user, trhoppe, he has them on his WRX and has ran at the ProSolo in Florida. He got his for $600/set.
Gary (gg) is offline   Reply With Quote
Old 02-24-2002, 12:29 PM   #11
ConeMasher
Member#: 2135
Stranoparts is still listing the Koni 8610-1351 (front) and 8610-1352 (reaer) for the WRX. Those are both inserts. Where are the mysterious front full-struts (not inserts) available? Tirerack? The inserts from Strano are $150 each, the fronts (no model # specified) from the Rack are $210. Perhaps the housing accounts for the difference.
Oh, yes, I'll call on Monday, but if someone has an answer before then, I'd appreciate it
-- ConeMasher
ConeMasher is offline   Reply With Quote
Old 02-24-2002, 07:06 PM   #12
paultg
Member#: 437
'91 Miata MX5 (Red)
I am not sure either. If you call and find out, let us know.
If I have time, I'm going to try and call also.
Paul G.
Old 02-25-2002, 01:01 PM   #13
Gary (gg)
Member#: 179
98 2.5RS
Rally Blue
I think the Koni sport struts are inserts at that price.
Old 02-25-2002, 03:04 PM   #14
paultg
Member#: 437
'91 Miata MX5 (Red)
I spoke with Luke at Tirerack today:
Confirmed:
The front WRX Koni's they sell are inserts
He has no info on when the rears will be available.
As far as he know, Koni only makes inserts for the WRX, not a complete strut housing.
So, I have edited my post of options above to reflect this info.
Paul G.
Old 02-25-2002, 04:21 PM   #15
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Silvuh
Right on. They are only inserts.
Dave
Old 02-27-2002, 01:20 PM   #16
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Silvuh
Default Koni info
The Koni's are inserts only.
1. the fronts are available now and fit just fine
2. the rears will be available in April and will just drop in with none of the cutting that you needed to do to get the RS inserts to fit.
3. www.stranoparts.com is where you can get them at a fair price. I am paying about 150 each give or take a couple dollars.
Dave
Local Shop that sales & installs Koni inserts? obraystyle Rocky Mountains Impreza Club Forum -- RMIC 12 06-17-2009 02:03 PM
Who installs Koni inserts? Rich10 Tri-State Area Forum 7 06-21-2005 04:11 PM
How is it to install koni inserts? titanium wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-08-2004 04:45 PM
Has anyone tried out the Koni inserts on the track yet? Pete Holt Brakes, Steering & Suspension 1 01-29-2004 11:10 AM
Installing Koni Inserts... BlackEye Brakes, Steering & Suspension 9 06-26-2003 10:53 PM
