Old 05-01-2008, 06:53 PM   #1
hypoxvi
Member#: 173002
Default 2.5/2.0 hybrid
So my EJ205 spun a bearing and I will most likely be replacing it with a EJ255 from an 06 WRX and running my 2.0L heads. Just wondering if I would need new injectors, pump, or anything else. still planning on running a TD04 for now.
hypoxvi is offline   Reply With Quote
Old 05-01-2008, 07:05 PM   #2
Udonboy
Member#: 40788
2004 WRX Sedan
No, you don't need to change those out if you're planning to use the TD04. I have an EJ257 with 2.0L heads and the TD04. I only had the shortblock, and oil related items replaced since there was metal everywhere on those parts.
http://forums.nasioc.com/forums/show....php?t=1053426
Udonboy is offline   Reply With Quote
Old 05-01-2008, 07:47 PM   #3
Rick539
Member#: 35997
If you plan on rebuilding the shortblock you will need to do research. Gaskets for the 2.5 works fine for the short block but you will need 2.0 head related gaskets and parts. If you are getting the full shortblock should be no problem. One important thing, I found out the hard way, was the harmonic balancer. Defintely different between the engines. Be sure to do your homework so it does not bite you in the end.
Rick539 is offline   Reply With Quote
Old 05-04-2008, 12:52 AM   #4
Paulys05wrx
Member#: 82433
2005 STi EFR 6738 &
WRX EFR 8734 Twin Scroll
I have noticed on my hybrid that the pulley is extremely wobbly. I used the WRX stock pulley and stock torque. Are you suggesting that i get a STi pulley? I was not aware they were different until looking at a friends STi. Thanks
Paulys05wrx is offline   Reply With Quote
FS: 04 wrx 2.5/2.0 hybrid 500 miles needawrx13 NESIC Private Classifieds 2 09-27-2009 04:28 PM
04 wrx hybrid 2.5/2.0 needawrx13 Private Vehicle 'For Sale' Classifieds 2 05-08-2009 12:26 PM
FS: 04 wrx 2.5/2.0 hybrid 500 miles needawrx13 NESIC Private Classifieds 18 04-22-2009 10:33 PM
FS: 04 wrx 2.5/2.0 hybrid with 500 miles needawrx13 Private Vehicle 'For Sale' Classifieds 0 04-17-2009 08:37 PM
wrong camshaft timing or?? 2.5/2.0 hybrid Gixxer1K Built Motor Discussion 19 02-05-2008 12:14 PM
