Old 05-01-2008, 07:20 PM   #1
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.54 Dale tuned
Default got a ?.....mobil1 and spun bearings
well the ? is i've seen alot of threads out there about mobil1 and spun bearing in our cars, i've seen people contact soa about it but has any one taken a oil sample and contacted mobil about this issue and if so what was there response back?
also i'm sure there is a list of people on here that have stated how many miles/what kind of oil/state of tune/what year the car was when the spun bearing happened and if not i'd like to start one.
Mike
tribalwrx is offline   Reply With Quote
Old 05-01-2008, 07:45 PM   #2
young j
Member#: 144478
2005 sti
wr blue
i highly dought it was the oils fault.
young j is offline   Reply With Quote
Old 05-01-2008, 07:56 PM   #3
tribalwrx
Member#: 32993
vf39 Best trap 110
not saying it was, hell when mine spun i was running mobil1 in the crankcase, but i see alot of threads about it and was just wondering if anyone had talked to mobil about it?
by the way i started using rotella t 5w40 syn at 4000 miles on the new motor.
Old 05-01-2008, 07:57 PM   #4
ej20_ftw
Member#: 151013
2008 WRX STI
2006 Legacy GT ABP & Z's
I think it's not mobil1's fault. It's because of the oil viscosity (5W-30).
ej20_ftw is offline   Reply With Quote
Old 05-01-2008, 08:05 PM   #5
tribalwrx
Member#: 32993
vf39 Best trap 110
i don't think thats the only reason, i was runnning m1 5w30 for 60k miles before the bearing went, and had tons of times in the high rpm's at the track and on a open empty highway without any issues, also when we opened up the heads the cam's and valve shims had not shown any wear, i switched to a 5w40 because i do run the engine hard and don't want another bearing failure.
Old 05-01-2008, 08:51 PM   #6
Gunner
Member#: 36540
04 Silver GGA
Cobb Stage 1 EQ Tuned
If 50% of the cars have M1, it is normal to hear that 50% of spun bearings engines have M1 in them. I am sure that M1 has a much larger market share than Amsoil, Redline, Royal Purple, and Castrol etc.
At the same time, I laugh when I read about spun bearings complains when they use 5w-30 on a track (sometimes in Texas heat, no less). And they complain that it was M1's fault.
No, I do not use M1 nor do I work for Mobil.
Gunner is offline   Reply With Quote
Old 05-01-2008, 09:32 PM   #7
bluesubie
Member#: 767
04 FXT
Noone has yet to show proof that the oil failed. Although they have showed proof of poor maintenance, poor tuning and stupid decisions. There a tons of threads to search through in the 2.0 forum.
-Dennis
Old 05-01-2008, 09:51 PM   #8
tribalwrx
Member#: 32993
vf39 Best trap 110
but does anyone know if someone sent a sample in or even voiced there concern to mobil about it, they want to say don't use it because you may spin a bearing but has anyone contacted mobil to see what they say, thats really what i'm looking to see.
Old 05-02-2008, 10:37 AM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
Is it safe to say if you do not drive your stage 10 vehicle in an energy conserving manner, you should not be using an energy conserving oil?
strohausii is offline   Reply With Quote
Old 05-02-2008, 10:40 AM   #10
bluesubie
Member#: 767
04 FXT
No samples have been sent in. Most are too eager to jump onto nasioc and post, "WTF? Mobile 1 sUX". Some people have said that they've done used oil analyses prior to the spun bearing and wear was normal.
There have been great uoa's on M1 5W30 and there have been uoa's with very high lead (bearing wear) on M1.
-Dennis
Old 05-02-2008, 11:59 AM   #11
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Not unless it is also safe to say that if you do not drive your stage 10 vehicle in a power-maximizing way, you should not use a power-maximizing oil. <which is the opposite of what you said in the quote>
"Energy Conserving" is the same as "Power Increasing" or "Power Maximizing." All it means is that the oil in question will let your engine make a fairly small percentage more power than a reference PAO fluid (that's what most folks want to call a 'true synthetic'). This power increase could be applied to any grade of motor oil, but as it happens the testing and naming only apply to 5W- and 10W-30 oils (and xW20? I don't recall).
There are a number of ways to release more power than the reference PAO, and one of the main ones is friction modification. Frequently (always?), there is some temporary shear allowed as well. The question is only one of what your engine needs for protection. Note that an owner's perception of what it needs (i.e. what makes an oil protect well) is generally only the same as what it actually needs by coincidence.
bulwnkl is offline   Reply With Quote
Old 05-02-2008, 04:07 PM   #12
bluesubie
Member#: 767
04 FXT
You sound like an ad for Royal Purple. It gives you more h.p. because it's a "qualifying oil".
-Dennis
Old 05-02-2008, 06:59 PM   #13
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Ouch!
I'm just trying to point out that every coin has two sides (and some have far more than that). It gives you more hp because less is wasted plowing through the (unnecessarily?) thick oil.
Old 05-05-2008, 03:31 PM   #14
Arctic Penguin
Member#: 119532
2006 WRX
this one AGAIN
Arctic Penguin is offline   Reply With Quote
Old 05-05-2008, 03:58 PM   #15
Mechie3
Member#: 120152
2006 06 WRX, 86 FMOD
Blue, White/Red
It's probably due to several things (some already stated):
*high # of users = high number of failures (AFAIK no one has ever calculated the % failures vs users for the oils)
*M1 is often seen as "the" oil by non enthusiasts and new enthusiasts as well and people think it will last for a long time, be a wonder oil, etc
*Many users are new to turbo cars and unaware that they burn oil/need constant checking
*M1 seems to burn off in Subies faster/more than other oils leading to oil starvation as the problem, not so much the oil itself (though the starvation is caused by the oil burning you can argue that the oil is implicitly the problem)
Mechie3 is offline   Reply With Quote
Old 05-05-2008, 03:58 PM   #16
bluesubie
Member#: 767
04 FXT
Well, why did you bump it?
-Dennis
Old 05-07-2008, 09:26 AM   #17
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Besides spun bearings, M1 5W30 is also responsible for JFK's murder and global warming!
Ernest is offline   Reply With Quote
got my ACT clutch and throwout bearing.put the bearing in pressure plate.cant remove! stiboost04 Transmission (AT/MT) & Driveline 2 04-27-2010 08:47 AM
FS: 05 WRX EJ205 shortblock w/ spun bearing and valve covers scoobysti05 Engine/Power/Exhaust 2 05-19-2009 12:07 AM
spun bearings and recent oil changes ride5000 Factory 2.0L Turbo Powertrain 29 03-28-2007 05:12 PM
FS Axis block spun bearing and other misc parts. greysave Engine/Power/Exhaust 36 10-15-2006 02:47 PM
New STI case halfs and STI short block with spun bearings StiScoobySnacks Private 'For Sale' Classifieds 3 05-26-2006 06:05 AM
Message Board Statistics All times are GMT -4. The time now is 07:26 AM.
