Old 07-29-2009, 11:23 PM   #26
rkramer
Member#: 118209
2015 WRX Limitec
Originally Posted by 69subaru360 View Post
I've done 1100-1200 lbs without trailer brakes. No problems at all, barely even knew the trailer was there. I do have EBC redstuff pads and powerslot rotors so that does help a bit with stopping. I also have coilovers and big swaybars so the trailer really doesn't sway around much.
from what i've found with towing heavy loads behind the wrx is that even the crappy stock braking system has WAY more than enough capability, the problem is you don't have enough weight and traction in the tow vehicle. The trailer will EASILY slide the car in an emergency stop, and the trailer doesn't really care what braking system you are running. That is where trailer brakes save your bacon.
My previous jetboat was roughly 1200 pounds ready to go, current one is 1700. It made a HUGE difference, more than I would have expected. The most I've towed was somewhere around 2200-2500 pounds behind the wrx. 4 miles, nothing over 30 mph. It was amazing how easily the trailer could push the car when you slowed down, even at a relatively slow speed.
Old 07-29-2009, 11:48 PM   #27
69subaru360
Member#: 159682
1995 WRX
2015 F150
I think the coilovers might help me a lot with that. It doesn't transfer weight nearly as much as as stock suspension. So I don't get the nosedive when and lockup when braking. When the trailer was hooked up, the back of the car didn't even drop.
Trailer brakes are a great idea though. Subaru doesn't recomend them for no reason.
Old 07-30-2009, 12:35 AM   #28
Bug-Rex
Member#: 190935
02 Slam'd Bugeye
LOL member accnt. points
What kind of Formula car did you get?
Im a driver for the University of Alabama FSAE car.
Bug-Rex is offline   Reply With Quote
Anyone tow a car trailer with their Legacy ? IllNastyImpreza Legacy Forum 39 02-17-2008 02:39 PM
Impressions: External WG With Stg.2 2.0L WRX?? JohnnyWas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 02-01-2007 07:43 PM
New 2.5l STi shortblock with 2.0l WRX heads? neversatisfied Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 06-01-2005 12:33 PM
Anybody with a 2.0L WRX running the Exedy flywheel? sherifx Southern California Impreza Club Forum -- SCIC 15 07-23-2004 12:05 AM
towing a small trailer... justaspeedfreak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-18-2001 11:26 AM
