Old 05-02-2008, 01:00 PM   #1
MrDrift
Member#: 122726
1986 Fiero
Red
Default OMG my trans won't come off!! Help!
OK, so I've got everything disconnected, and all the bolts out (6 bolts and 2 nuts) and I've pulled the Clutch fork shaft out the side. There is, as far as I can tell, nothing left holding on the trans. It will not come off. I've pried at it with pry bars to the point that they bend, I've taken a chisel to the seam and just gouged it up, it will not budge. What the heck am I missing? Help please!
MrDrift is offline   Reply With Quote
Old 05-02-2008, 01:12 PM   #2
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
I've used a block of wood and pounded the trans back from the top where the pitch rod connects. It's never been that tough to wiggle off after doing that for me at least.
Rasmusson14 is offline   Reply With Quote
Old 05-02-2008, 01:27 PM   #3
Ryanr1490
Member#: 149267
2002 6-speed wrx
psm
There is pins on either side, heat around them red hot and it will come right out.
Ryanr1490 is offline   Reply With Quote
Old 05-02-2008, 01:31 PM   #4
slowwrx02
Member#: 117548
02 WRX
the clutch locked in to the trans shaft. u need to put the fork back on and try move the fork toward the front then it should unlocked to shaft to the clutch. i had the same problem when i did my clutch.
slowwrx02 is offline   Reply With Quote
Old 05-02-2008, 01:31 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
prybar between tranny case and front crossmember.
Old 05-02-2008, 01:36 PM   #6
MrDrift
Member#: 122726
1986 Fiero
Red
That's where I bent my 2 prybars...
Old 05-02-2008, 01:37 PM   #7
MrDrift
Member#: 122726
1986 Fiero
Red
All good suggestions. Keep them coming. I hope to go at this thing with a full arsenal next this time
Old 05-02-2008, 01:38 PM   #8
MrDrift
Member#: 122726
1986 Fiero
Red
Also is the fork suppose to come all the way out or is it just suppose to flop around in there? I couldn't see how to pull it out the top.
Old 05-02-2008, 01:41 PM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
what about your axles?
Old 05-02-2008, 02:00 PM   #10
Rasmusson14
Member#: 77658
yeah, it just sits in there flopping around after you pull it up.
Old 05-02-2008, 02:25 PM   #11
scutzi128
Member#: 149467
2004 STi
try hitting the seam a little harder I had my motor pulled last weekened and we had to go at the seam pretty hard with a chiesel and mine was particularly hard to seperate since the trans and motor had not been seperated for 55k miles.
scutzi128 is offline   Reply With Quote
Old 05-02-2008, 02:42 PM   #12
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
Jack up the front of the engine on the oil pan and the pins will line up and it will drop out. No need to undo the motor mounts.
xrocket21 is offline   Reply With Quote
Old 05-02-2008, 02:45 PM   #13
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I used a VERY large chisel. 18" maybe? I combined it with a sledgehammer... It mangled up the aluminum a little, but nothing that I couldn't clean up with a file. Make sure you take a little sandpaper to the pins to clean them up before you reassemble.
bluescoobywagon is offline   Reply With Quote
Old 05-02-2008, 05:58 PM   #14
wrxjrk
Member#: 164093
pins are rusted, big chisel and big hammer will do the trick..
wrxjrk is offline   Reply With Quote
Old 05-02-2008, 07:35 PM   #15
Rasmusson14
Member#: 77658
I use a 4lbs sledge. Works like a champ as long as the block of wood doesn't splinter on you.
Old 05-03-2008, 09:02 AM   #16
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
WRB - It's mostly stock..
Woah, chisel and sledge sounds like a terrible idea to me. This is what works for me every time. If you already have an inch or more gap between motor and transmission, you MUST get the angel of the motor and transmission right for it to come out and go in easily. I just put a jack as far forward on the motor as you can. When removing it, lift on the front bottom, where the drain plug is and push back. You have to really give it some love but it should pop right out, just don't drop it on yourself. Good luck. I hope this helps.
Wrx-WannaB is offline   Reply With Quote
Old 05-03-2008, 10:42 AM   #17
bluescoobywagon
Member#: 14911
Not A Wagon!
Obviously, the chisel and sledge are used to crack the cases apart. If you don't live with salted roads, you don't know what we're talking about...
Old 05-03-2008, 11:18 AM   #18
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
^^winnAr
All4bSpinnin is offline   Reply With Quote
Old 05-03-2008, 03:01 PM   #19
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
O M G .. I am like so totally sorry I didn't think about salted roads. I was like just trying to help out.
Old 05-03-2008, 04:45 PM   #20
sumitomo
Member#: 125472
Dine-E-Mite then you can do the six speed swap.Sumi
sumitomo is offline   Reply With Quote
Old 05-03-2008, 05:36 PM   #21
bluescoobywagon
Member#: 14911
Not A Wagon!
No biggie. I grew up in So Cali and never realized what it's like in the midwest until I moved here. I miss the days of cracking loose a 100,000+ mile suspension bolt with an open ended wrench in my driveway at 2am in February.
Old 05-04-2008, 01:12 AM   #22
MrDrift
Member#: 122726
1986 Fiero
Red
Yea, the bellhousing has zero gap between it and the block. I mangled it up with the chisel pretty good so far, so I guess I'll try harder, and maybe a little heat on the pin area...
Old 05-04-2008, 07:12 AM   #23
bluescoobywagon
Member#: 14911
Not A Wagon!
I banged on mine for a good 2 hours before it came apart.
Old 05-04-2008, 11:52 AM   #24
hkerekes
Member#: 66310
2015 korean muscle
Are you 100% sure that the trans has no bolts holding it to the block. Did you take off teh crossmembers / driveshaft? Is the shifter rod stuck?
Mine was difficult but it came off with a 36" prybar alternating from the top and the bottom. As long as you dont crack anything you can marr up the surface its not that big of a deal.
hkerekes is offline   Reply With Quote
Old 05-04-2008, 03:18 PM   #25
MrDrift
Member#: 122726
1986 Fiero
Red
Everything is off the trans, and the trans crossmember is off. I took 6 bolts and 2 nuts off, that's what I could find and that's how many the book shows.
Trans won't come off motor - No I am not a n00b bmw50021 Transmission (AT/MT) & Driveline 10 02-14-2010 01:21 AM
followed all steps. engine won't come off!!! help!!??!?!?!!?? MrSaabaru Subaru Conversions 18 08-12-2005 01:58 AM
HELP! My wheel won't come off the hub! RightyTighty Tire & Wheel 9 12-05-2004 06:45 PM
Aarrg, my tranny won't come off. Wellhung Transmission (AT/MT) & Driveline 5 11-28-2002 07:45 PM
Cap bolt just won't come off!! Need help! scooby5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-08-2001 12:25 AM
