Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 05-02-2008, 03:42 PM   #1
WickedRS
Member#: 90415
02 2.5RS silver
05 front end conversion
Default 02 headlight wiring converted to 05 wiring?
i have done an 05 front end conversion, but i am stuck on what i need to do to the 02 headlight wiring to convert so it will work with the 05 headlights.
WickedRS is offline   Reply With Quote
Old 05-02-2008, 04:31 PM   #2
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
best bet is to make a relay harness that trips on the stock 9007 plug and then relays through a positive switch system for the highs and lows.
you'll need two relays, H1 plugs, 9005 plugs, 9007 bulb (male) plugs, and a ton of wire and solder.
oh, and a good academic knowledge of how relays and wiring works.
or you could just buy a JDM bugeye plug and play harness for projectors because they use the same bulbs as the 04 lights. if you do that though, or if you don't use relays and don't wire the relays properly, your lowbeams will turn off when you hit the highbeams... not good.
the relay harness is the best idea.
Handsdown is offline   Reply With Quote
Old 05-02-2008, 05:03 PM   #3
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
hear i evn made this for u! lolz
light blue is probably wrongzors.
equip hid planet:
http://img.photobucket.com/albums/v5...HID-9005-P.jpg
from this thread
http://www.hidplanet.com/forums/viewtopic.php?t=6612
+42 exp
only difference is that subarus use switched ground so your bulb to relay paths might differ.
Old 05-02-2008, 05:30 PM   #4
WickedRS
Member#: 90415
02 2.5RS silver
I had a feelin that I was going to have to use relays and the 05 stock plugs. I have been installing mobile electronics and remote starts for 9 years, among custom work. So I am really good with relays and soldering. I appreciate the diagram. I will figure it out. Right now I have the 02 headlights in it now. looks weird
Old 05-02-2008, 05:36 PM   #5
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
Dude, please... all dumb typing aside...
Please get pictures of the 02 lights in the 04 front. I need to see this, just for kicks. Does the hood close? i wouldn't imagine it would.
Old 05-02-2008, 07:49 PM   #6
WickedRS
Member#: 90415
02 2.5RS silver
I have pics. I was able to get the hood to close, I have been on here for awhile but I still havent figured out how to post picture, without using photobucket. Help and I will post
Old 05-02-2008, 07:56 PM   #7
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
hosting is the first step, so use photobucket or imageshack(i like imageshack because it's so easy) to upload and host the picture...
then you put the url of the image inbetween IMG tags, which go [ IMG ] without the spaces, and a [ /IMG ] on the other side.
so it looks like this:
Code:
[ img]http://www.mywebsiteaddreagggpoop.co.qx/folder/file.jpg[/img ]
without the spaces.
this is all in a newbie faq on here somewhere that probably explains it better than i.
Old 05-02-2008, 08:22 PM   #8
WickedRS
Member#: 90415
02 2.5RS silver
Old 05-02-2008, 08:31 PM   #9
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
haha! that is absolutely crazy. thanks for the pictures!
the upside of a relay harness is that it improves light output by decreasing voltage drop... but you already knew that.
Old 05-03-2008, 03:33 AM   #10
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
this thread is money. just so you know, i laughed for about 10 mins after seeing those bugeye lights stuffed into the 05 openings.... lol
handsdowns idea sounds pretty legit. use some relays to power those 05 lights.
jdubya301 is offline   Reply With Quote
Old 05-03-2008, 01:16 PM   #11
WickedRS
Member#: 90415
02 2.5RS silver
I figured people would find this hilarious, I laughed every time I walked in front of the car.
04 sti cv boot rip :( Can i convert to 05? lennybootzz Transmission (AT/MT) & Driveline 4 05-23-2010 08:49 PM
04 STI Wiring harness Vs.05+ Wiring harness krich503 Electrical & Lighting 2 05-02-2010 06:35 PM
Question: How to convert 02 wrx center console to 05+ sti center console MrMakesitRain Newbies & FAQs 2 12-29-2009 10:46 PM
FS/FT: 02 Rs Fully Converted to an 04 sti with mods!!! Very CHEAP!!!! hudsonhawk Private Vehicle 'For Sale' Classifieds 45 01-22-2009 01:36 PM
02-04 Center wiring conversion to 05-06 dash Bad Wagon Interior/Dressup/Audio & Security 4 08-24-2006 03:25 PM
Message Board Statistics All times are GMT -4. The time now is 07:47 AM.
