#1 |
Member#: 150196
SCIC
Vehicle:2006 wrx silver 48w |
are the spark plugs a hassel to do on an 06 wrx?
#2 |
Member#: 141672
Vehicle:07' wrx Uncle Scotty 5W30 |
Click on the bottom sticky in this forum and then click spark plug facts.
I just looked and there are no real details how to do the job. Last edited by mikeythejew; 05-04-2008 at 08:58 AM. |
#3 |
Member#: 22412
SWIC
Vehicle:2012 Legacy 2.5GT Ice Silver Metallic |
doing the plugs on a Subaru engine isn't that big a deal - remove the coil packs, then remove and replace the plugs like you would on any other engine - the main difference is that they are on the side of the engine, rather than the top. If anything is in your way, just remove it (not sure about an 06, but on my 02, it helped to remove the battery and windshield washer bottle)
#4 |
Member#: 79164
NWIC
Vehicle:2005 WRX tHe Silver one |
#5 |
Member#: 67661
Vehicle:2004 WRX sedan Blue |
Its not that bad, took me like 1.5 hrs the first time, then maybe 50 min the second time. 1 of them had a cracked insulator, so its totally worth it
#6 |
Member#: 27833
Vehicle:2002 wrx black |
Took me about a 1.5 hrs also just did mine this wkend. On driverside i just removed the windshield washer bottle n that was it. If u have a socket driver that has a swizel head that helps out a lot. Too bad I didnt.
#7 |
Member#: 150196
SCIC
thanks for the info you guys rock
#8 |
Member#: 142551
TXIC
Vehicle:2000 Integra Type-R Phoenix Yellow |
What plugs are you all recommending (if anything other than factory)? Car is my wife's. 100% stock.
#9 |
Member#: 111641
Vehicle:08 BMW 135i MSport tuned/full exhaust/intake |
You'll need to remove the airbox and the air pump, just a heads up.
#10 |
Member#: 141028
Vehicle:2002 WRX Wagon WRB |
#11 |
Member#: 111641
#12 |
Member#: 137009
Vehicle:2005 Impreza WRX WR Blue |
#13 |
Member#: 123822
Vehicle:2006 WRX TR Black |
I changed my spark plugs on my '06 WRX TR this past weekend. It wasn't that bad, other than the fact I couldn't get to the one (last one) by the air pump on the driver's side (3 newly installed, 1 old one left). I noticed after removing them, they had normal wear (not sure if there's any repercussions when driving with 3 new plugs and 1 old one). I couldn't reach my man hands far enough to pull the last socket out (still managed to fit a small ratchet to loosen the bolt). I'm definitely going to try and figure out how to remove the air pump to get to the last one sometime this week.
I followed the directions on scoobymods (thanks Peaty) as well as getting additional information with the "difference" between the 02-05 models compared to the 06-07's, which isn't much other than the air pump and removals that aren't necessary. Here's what I did: Passenger side: 1. Disconnected negative battery terminal 2. Removed front air duct (flat funnel-shaped held on by 2 bolts; connected to the snorkus) 3. Unplugged MAF sensor (carefully) then unclip hoses on top of the air box and MAF sensor wire from the side clip. 4. Removed the airbox (held on by two bolts) and air intake duct. 5. Removed the plugs held on by one bolt each 6. Stuck in a socket extension for spark splugs and loosened/removed. 7. Replaced with new spark plugs (IMPORTANT: 15-18lb (torque wrench)) 8. Put it back to together. Driver side: 1. Removed battery 2. Took the windshield washer bottle plastic screw off (to allow flexibility when working) 3. You'll see the plugs on the side. Sorry, but unless you have barbie hands, I can't see a way to get that last plug out (nearest to the firewall) without removing that air pump. Any help? suggestions? Mods: -Cobb AP v1 stage2 '93oct -Invidia bellmouth dp v2 -DC Sports single canister cat-back -K&N air filter |
| Thread Tools | |
| Display Modes | |
| Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? | jungleman | Service & Maintenance | 2 | 02-09-2009 03:45 PM |
| spark plug replacement | boxer02 | Factory 2.0L Turbo Powertrain | 8 | 02-21-2003 01:59 PM |
| Spark plug replacement | WRXVII | Service & Maintenance | 2 | 02-08-2003 04:08 PM |
| Spark Plug replacement - how hard? | Beaumont | Service & Maintenance | 4 | 08-20-2002 05:37 AM |
| Spark Plug Replacement Procedure | arejay | SVX Forum Archive | 2 | 08-10-2000 05:16 PM |
