Old 05-04-2008, 03:37 PM   #1
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
Default easiest way to hook up push button ignition?
I was wondering what the easiest way to hook up a push button ignition. If anyone can help that would be cool. I hooked one up in my eclipse, but I was wondering if there is a better way to do it on a wrx...
skate enjoi is offline   Reply With Quote
Old 05-04-2008, 04:05 PM   #2
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Since you dont have a chip in your key, it would be pretty much exactly the same way youwired it up in your eclipse.
How did you have it wired up before anyways? Did you wire in a relay to disable voltage to the button once the car was running, or was it just wired in as a momentary circuit on your starter lead?
G3Red04WRX is offline   Reply With Quote
Old 05-04-2008, 05:08 PM   #3
skate enjoi
Member#: 120716
2002 psm ver7 wrx
it was wired onto my starter... I forget it the other wire from the button goes to a ground or to another power source
Old 05-04-2008, 06:39 PM   #4
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
Subaru Banner
You could always buy the Zero Sports one - it's plug and play.
http://www.fastwrx.com/zepubust.html
MD04WRX is offline   Reply With Quote
Old 05-04-2008, 06:50 PM   #5
skate enjoi
Member#: 120716
2002 psm ver7 wrx
I was thinking about that too, but I have a free button I used in a previous car. I was wondering if the zero sports one would interfere with my turbo timer plug and play harness though?
Old 05-04-2008, 08:40 PM   #6
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Which one do you have??
4wdrift is offline   Reply With Quote
Old 05-04-2008, 08:47 PM   #7
skate enjoi
Member#: 120716
2002 psm ver7 wrx
I have a blitz dtt with the plug and play harness and a no name push button
Old 05-05-2008, 01:20 PM   #8
skate enjoi
Member#: 120716
2002 psm ver7 wrx
anyone?
Old 05-05-2008, 02:10 PM   #9
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
what is the point of this. You still have to have the key in the ignition and turned to the on position. I dont get it
shamrock 05 is offline   Reply With Quote
Old 05-05-2008, 03:06 PM   #10
Hypnotk
Member#: 93307
05 WRX
I thought it was a good idea until I saw that you have to have your key in it.
Hypnotk is offline   Reply With Quote
Old 05-05-2008, 04:40 PM   #11
The Cheat
Member#: 66044
2004 WRX/1994 Miata
it is pretty pointless.
the easiest way to do it would be to tap into your starter wire and run that to one side of the button. then run the other side of the button to a switched +12v. you would want to use a switched +12v so it can't be cranked without the key in. make sure you fuse the wire.
again, i think this is pretty pointless.
The Cheat is offline   Reply With Quote
Old 05-05-2008, 04:44 PM   #12
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Its the bling factor guys...
Its just something different.
Its like having a racing seat vs stock. If you are the only one that drives your car, you still sit in the same position.
No big deal...
Old 05-05-2008, 04:49 PM   #13
The Cheat
Member#: 66044
2004 WRX/1994 Miata
No big deal...
a racing seat serves several purposes over the stock seat. this is more like putting the night rider led thing on the front of your car.
Old 05-05-2008, 04:50 PM   #14
sorrowfulkiller
Member#: 170439
I <3 Lamp
you could always run the button as a button that would allow the car to run or not IE theft detterent device.
cut the ignition wires, run them to the on/off button, when button is off car will not start no matter what and when the button is on car will start fine
did something like this with my 96 mustang, cept with the fuel pump... I could turn off my car while driving! lol cept it would run lean. good way to clear out the lines though, also unless someone knew what the switch did they had no clue how to start the car
sorrowfulkiller is offline   Reply With Quote
Old 05-05-2008, 05:49 PM   #15
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Not if you aren't a racer in a race...
Old 05-05-2008, 06:20 PM   #16
skate enjoi
Member#: 120716
2002 psm ver7 wrx
last time I checked the title wasnt-- easiest way to hook up push botton ignition?AND HOW STUPID DO YOU THINK IT IS?
maybe it should have been? I donno....
Old 05-05-2008, 07:28 PM   #17
The Cheat
Member#: 66044
2004 WRX/1994 Miata
a "racing" seat being beneficial to a "racer" in a "race", exactly. most people on here that have racing seats do infact track their car. go roll your eyes somewhere else.
skate enjoi - everyone is just putting their 2 cents in, just like myself, i find it kinda silly. i mean, you still have to put the key in and turn it to the on position.
i think i gave you some ok info on how to do it, if it made any sense. to help you out some more, these should be the wire colors for your car at the ignition harness. the plug you used for your turbo timer, each plug should have different colors in it. these are the colors for both sides of the plug as dei gives.
starter - black/yellow to white/black
constant +12v - black/white to whote
acc(+12v switched) - black/blue to yellow
just make sure you test the wires first with a meter and use a fuse.
Old 05-05-2008, 08:15 PM   #18
skate enjoi
Member#: 120716
2002 psm ver7 wrx
oh I know, I was just joking around... I dont expect everyone to like every single thing I do to my car. Thanks for the info though
Old 05-05-2008, 09:40 PM   #19
4wdrift
Member#: 1403
99 RBP GC8 Impreza
News
a "racing" seat being beneficial to a "racer" in a "race", exactly. most people on here that have racing seats do infact track their car. go roll your eyes somewhere else. ...
Whatever man.. ...quit crying.
I bet you daily drive your "track car" alot more than you race it.
Besides, its not even that serious man...
...I have race seats too. sheesh...
Old 05-05-2008, 09:45 PM   #20
4wdrift
Member#: 1403
99 RBP GC8 Impreza
I like your idea man (mine)...
Old 05-05-2008, 09:54 PM   #21
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Look, The Cheat
Before you get all wrapped around the axel, I was merely suggesting the analogy that
racing seats to most only serve a limited purpose. Day to day they just hold your ass in
place and don't do much more than stock hardware. That doesn't make them bad or
good, just bling when you go to the quickie mart to get a slushee.
A starter button is just bling unless you push it. Does it get you +5 hp? of course not!!
Its just something different. Just chill with the "Racing seats are serious bidness"
attitude.
Not necessary...
Old 05-06-2008, 12:03 AM   #22
skate enjoi
Member#: 120716
2002 psm ver7 wrx
Look, The Cheat
attitude.
Not necessary...
It gets you 14, everyone knows that...
Old 05-06-2008, 12:16 AM   #23
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
I was merely suggesting the analogy that racing seats to most only serve a limited purpose. Day to day they just hold your ass in place and don't do much more than stock hardware.
What? Seats are essentially a functional mod before anything else... The added bolstering keeps you from flying through the doors during cornering... especially functional upgrade if you're coming from a TS or usdm STI
A push button start just adds an additional step to starting your car... I think its pretty cool in the S2000 though
silverF4turbo is offline   Reply With Quote
Old 05-06-2008, 07:27 AM   #24
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Impreza GC8
I agree but only if you are actually rolling through the corners at a really good clip. The average guy doesn't take every corner like Michael Schumacher, necessitating the need for racing seats (or harnesses for that matter) day to day unless they race every day (in which case you are not the average guy ).
[forestgump] That's all I have to say about that. [/forestgump]
Old 05-06-2008, 10:01 AM   #25
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
quickie mart
Kwik-E-Mart
Abnormal is offline   Reply With Quote
how to make a push button ignition map450 Electrical & Lighting 5 09-30-2009 12:27 PM
Cheapest/Easiest way to hook iPod into stock car radio? MrBlue Off-Topic 17 11-29-2006 03:15 PM
The easiest way to break up with your girl stryfewrx Off-Topic 10 06-24-2005 03:02 AM
Any way to hook up a JL car sub to a home audio receiver? rhdude Off-Topic 9 05-12-2004 01:34 PM
Best way to hook up this system (Alpine and JL)? lupohki Car Audio, Video & Security 28 04-04-2004 03:40 PM
