Old 05-04-2008, 10:19 PM   #1
wrx-bahrain
Member#: 155303
02 WRX
Exclamation Extremely Loud Knocking Noise!
I know a lot of you are going to call me upright stupid for this mistake that I made today, but I regret it badly. I was on my way to a race, when a realized that my "check oil" light flashed; I ignored it and it left. I raced a Golf GTi with my 2.0 Subaru WRX (2002). There was a lot of RPM involved. However after the race, I started hearing a weird noise, it sounded like my exhaust was vibrating- I switched my AC on and my car stopped completely. Notice: my battery has been extremely weak for a few days. Me and a few guys try to push the car and start it, however it would try to start and then jerk back to a complete stop. We tried starting it a few times, and it would still not start. I checked the engine oil and found out that there was extremely low oil, so we towed the car to a garage (it was night time, and it wasn't open), so we decided to buy 10W40 Liqui Moly Oil and filled the engine oil up. This time, it felt as if the car was trying to start. We got jumper cables and finally the car started. However, when the car was on, there was a noise as if something was hitting something else, and the main engine block was shaking. The noise would increase as I accelerated while it was in Neutral. It was sort of like a loud knocking sound. I switched my car off.
The garages are still closed as this just happened a few hours ago.
Could someone please tell me what they think this is, and whether it could be serious!
wrx-bahrain is offline   Reply With Quote
Old 05-04-2008, 10:35 PM   #2
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Sounds like you put a rod thru the block...
Your vehicle was low on oil, you drove it, at high RPM's no less, and put a rod thru the block
Be prepared...it's a costly repair, YES, it is serious, and don't expect it to be covered under warranty
RexyGirl is offline   Reply With Quote
Old 05-04-2008, 10:47 PM   #3
wrx-bahrain
Member#: 155303
02 WRX
my car doesn't have warranty anyway; but the car still starts? Isn't it true that if I put a rod through the block or blew the pistons, the car wouldn't start at all? *hopeful*
Old 05-05-2008, 07:11 AM   #4
wrx-bahrain
Member#: 155303
02 WRX
So I took it to the garage today, and they said they're going to have to take out my engine and have a look at it. The guy presumes it has something to do with the crankshaft:S
Old 05-05-2008, 08:19 AM   #5
Arctic Penguin
Member#: 119532
2006 WRX
blew it up
is a good place to start
Arctic Penguin is offline   Reply With Quote
Old 05-05-2008, 06:46 PM   #6
Brighton
Member#: 53542
2002 02TS + 02WRX
TS=Green/WRX=Silver
Rod bearing, I know the sound painfully well. Start shopping for a new motor, it'll cost less or the same as having your current one rebuilt.
Brighton is offline   Reply With Quote
Old 05-05-2008, 08:16 PM   #7
RexyGirl
Member#: 63616
with mods :)
What kind of oil were you using before this started?
Just curious....
Old 05-05-2008, 08:31 PM   #8
wrx-bahrain
Member#: 155303
02 WRX
Well there was hardly any oil left, but before this I was using 10W40 Mobil...
Old 05-05-2008, 09:37 PM   #9
RexyGirl
Member#: 63616
with mods :)
Mobil 1 ?????
Old 05-06-2008, 07:56 PM   #10
wrx-bahrain
Member#: 155303
02 WRX
To be quite honest, I don't remember but I think it was Liqui Moly.
Anyways guys, I just back from the garage and I got extremely bad news..heh
He said that my crank shaft was broken and that a lot of things need to be changed but over all I've got to pay about $1600 to fix it all.
Here's how he's priced it.
-Used Crankshaft and connecting rods - $740
- Bearing & Main Bearing - $132
- Overall Gasket Kit - $100
- Piston Rings - $127
- Oil Pump - $172
- Spark Plugs - $47
- Oil & Filter + Coolant - $47
and the labor charge is $420
What do you guys think of the above prices.. do you think I could get a better rate anywhere online WITH shipping?
Old 05-06-2008, 08:29 PM   #11
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Sounds extremely cheap to me....is that in US dollars?
JamesWilson is offline   Reply With Quote
Old 05-06-2008, 08:33 PM   #12
wrx-bahrain
Member#: 155303
02 WRX
yep usd
im in bahrain .. the middle east:s things are pretty cheap down here..but the used crankshaft is pretty pricey!:S
extremely loud bang after taking intake mani off then back on? WTF!! fl4tsc Newbies & FAQs 22 11-14-2008 03:01 PM
Loud knocking noise IEcaliWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 05-17-2007 04:39 PM
WAY high fpress, extremely loud FPump SpoolinPA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-29-2007 09:05 AM
06 WRX: Extremely loud squealing/grinding? CrooklineWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-02-2006 05:37 PM
Extremely Loud POW HondaDestroyer General Community 25 01-23-2006 08:14 AM
