Old 05-05-2008, 01:26 AM   #1
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Default Brake bleeding problem
I was bleeding my brakes completely today (trying to run all the old fluid out and replace with fresh) and not just bleed a bit to see if there was air.
Everything was fine until the RR brake (Third brake I worked on).
I use the method of undoing the bleed screw while someone pumps the brakes for me. When I undid the screw while the brakes were being pumped, nothing came out of the bleed screw. I did see a slight amount come out AROUND the bleed screw at the base, probably because I opened the bleed screw to far.
I tried this a couple of times with the same result. All the other corners were fine. I could bleed them with no issues.
Any tips/hints on what to do next?
I was having issues with one of the rear brakes through the winter. One of them would start to squeal until I lightly pressed the brakes then it would stop for a while and then start squealing again. Plenty of pad left. I did take the pad out of the caliper a month or so ago to clean the caliper and rotor and that made the brake noise go away.
Any ideas?
Thanks!
wobbletop is offline   Reply With Quote
Old 05-05-2008, 02:33 AM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
keep pumping until fluid comes out, might take you a few minutes
probably have air in your system
Nuke209 is offline   Reply With Quote
Old 05-05-2008, 11:11 AM   #3
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
I doubt I have that much air in the lines.
The person pumping the brakes said that the resistance did not go down when I loosened (sp?) the bleed screw. So could it be blocked internally?
Old 05-05-2008, 11:37 AM   #4
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
Take the bleed screw completely off and flush it real good with brakleen.
anickode is offline   Reply With Quote
Old 05-07-2008, 01:26 PM   #5
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Resolved.
Brake bleed screw was clogged. Used a small allen key to clear out the small hole on the caliper end of the screw.
Thanks!
Old 05-07-2008, 05:46 PM   #6
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
Originally Posted by wobbletop View Post
Resolved.
Thanks!
Make sure you have caps for those bleeders.
brake bleeding problems smellslikecurry Legacy Forum 3 03-08-2009 12:39 AM
Installed Stainless Brake Lines- bleeding problem klinebau Service & Maintenance 12 01-14-2008 09:03 AM
After Brake Bleeding, ABS Light Swivel1000 Brakes, Steering & Suspension 1 04-20-2001 01:44 PM
Help!!! I need someone to help me with brake bleeding!!!! Andrew Bay Area Impreza Club Forum -- BAIC 6 10-02-2000 10:21 AM
Brake bleeding/Super Blue Racing fluid? Thug Technical Forum Archive 10 06-08-2000 01:39 PM
