Old 05-05-2008, 12:02 PM   #1
GodWhomIsMike
Member#: 102287
2014 Crosstrek Ltd.
Tangerine Orange
Question Would 255/40/17s on 17x8 wheels fit a 2008 WRX without any modifications?
What's the widest wheels/tires that will fit a 2008 WRX without any modifications? Would a 17x8 wheel w/ 255/40/17 tires fit a 5-door WRX without any rubbing, and no modifications (no fender rolling or suspension changes).
GodWhomIsMike is offline   Reply With Quote
Old 05-05-2008, 12:14 PM   #2
Kylemorg
Member#: 172509
2008 Impreza 5-door
Red
As a first place to do a "reality check" "will these fit" type of search, I'd recommend going to www.tirerack.com and using their car search feature for wheels. That will tell you what the widest wheel and tire combo should fit, pretty much guaranteed without rubbing.
They do list Einkei RP03 in 17X8 48mm offset with 205/50 tires...
The wider you go on tires, the more risk of rubbing, and the more road-swale and grooved pavement pull you'll typically have. Why would you want to go with 255 width?
IMO, if you want a wider tire, you'd be better off going with something like a 225/45R17 which only has a .4% diameter difference. (http://www.1010tires.com/TireSizeCalculator.asp)
http://www.discounttiredirect.com/di...ARU&vid=009419 lists alternate "plus zero" sizes up to 235/45R17
Kylemorg is offline   Reply With Quote
Old 05-05-2008, 12:26 PM   #3
GodWhomIsMike
Member#: 102287
2014 Crosstrek Ltd.
Tangerine Orange
I've seen a few sets of 17x8s they had that I thought were nice. Just wondering if the 255/40/17 size would clear the wheel wells and suspension.
Using the miata.net tire calculator (http://www.miata.net/garage/tirecalc.html), it seems that the size is very close to stock (obviously it's wider). But at 60 mph, the difference would be 0.1 mph.
Old 05-05-2008, 12:26 PM   #4
JuggernautTCW
Member#: 169223
as far as i know, 235 is as wide as you can go without rolling fenders or running really aggressive camber. 235 fits perfectly on a 8" wide rim anyway. you also want to check the offset... its the key to wheel fitment.
JuggernautTCW is offline   Reply With Quote
Old 05-05-2008, 12:46 PM   #5
aross
Member#: 831
11 Blurple WRX
03 BH MBP
I don't know if it helps, but I have had 245/45/16 on my car - no rubbing -on 16X8
aross is offline   Reply With Quote
Old 05-05-2008, 01:02 PM   #6
GodWhomIsMike
Member#: 102287
2014 Crosstrek Ltd.
Tangerine Orange
Cool thanks. Didn't think 16s would clear the brakes though.
Old 05-05-2008, 01:05 PM   #7
aross
Member#: 831
11 Blurple WRX
03 BH MBP
No problems there, they are 2002-2005 WRX size - so 16's are easy.
Old 05-05-2008, 01:16 PM   #8
GodWhomIsMike
Member#: 102287
2014 Crosstrek Ltd.
Tangerine Orange
Nice, because not being able to do 16s in the Winter on my LGT was a royal pain in my ass.
Old 05-05-2008, 01:25 PM   #9
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Yeah, I pimped the 16" steelies this past winter.
I am sure 255 is not hard.
Old 05-05-2008, 02:15 PM   #10
Arctic Penguin
Member#: 119532
2006 WRX
without any suspension changes the 08 is a wallowing pig and putting any wide wheels and tires on it will be a total waste
Arctic Penguin is offline   Reply With Quote
Old 05-06-2008, 10:00 AM   #11
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Thanks for your insight, but those of us that own them do notice the advantage the tires give.
My 08 was as fast as an 06 wrx in autocross last year.
You do have to be more controlled with your inputs, but it does hold on well.
As soon as you have suspension, the new rear suspension puts you waaaaaay ahead of the older chassis.
Old 05-06-2008, 12:18 PM   #12
Arctic Penguin
Member#: 119532
2006 WRX
again...waste of time
spend the $$$ on better suspension and then deceide on wheels and tires
eating through a set of $$$ tires because the suspension sucks is counterproductive
my stock 02 was a wallowing pig
my stock 06 was a wallowing pig
and the stock 08 i drove was the same wallowing pig
and burning through tires on a wallowing pig isnt one of the things that ive learned in my life to think to be anything but a waste of $$$
Old 05-07-2008, 09:53 AM   #13
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
^^^^^ true. I went through a set of 300 rated tires in about a year on springs and since I got suspension have gone through about half a set of 200 treadwear tires. I was especially surprised after an autox where the wear was minimal. If I had done that on my old setup, the tires would have been screaming for mercy as I understeered all over the course.
blahhblahh is offline   Reply With Quote
what's the most powerful battery that will fit the oem 93-01 battery tray? 2slofouru Electrical & Lighting 1 01-23-2010 09:41 PM
The minimum wheel size that will fit? RallyIt07 Tire & Wheel 2 12-16-2008 06:26 PM
What's the widest tire that will fit on the stock 02 wrx rims? thumpetto007 Tire & Wheel 0 02-16-2008 02:35 PM
What is the widest tire that will fit stock 07 TR Wheels RedefinedTR Tire & Wheel 11 06-30-2007 02:19 PM
Anyone got some CHEAP wheels/tires that will fit a WRX? Patrick Olsen New England Impreza Club Forum -- NESIC 7 06-17-2004 11:53 AM
