Old 05-05-2008, 02:23 PM   #1
mtntrekker30
Member#: 158173
Default Starter Motor Replacement '99 OBS
My starter motor is making that squealing kind of noise indicating that she is about to go out. Can anyone recommend a good starter motor? I know Mitsubishi makes the OEM (dealer wants a small fortune for the part and a very large fortune to replace) but what about these you get at Autozone or Checker Autoparts? It doesn't seem too hard to replace--disconnect battery, undo a few bolts, replace, then reverse the procedure. Thank you in advance.
mtntrekker30 is offline   Reply With Quote
Old 05-05-2008, 03:41 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There are places on-line you can check with and compare prices. The main thing I would be concerned with is the warranty on the unit. Getting a good remanufactured unit should save you some money and have a good unit. You could also have a local shop rebuild yours. I would compare prices before doing that though.
Cougar4 is online now   Reply With Quote
Old 05-05-2008, 06:13 PM   #3
voodoochylde
Member#: 135005
1999 Impreza L
Red
I've never had a squealing noise from a starter but I've only worked on one on my old Legacy.
The contacts were pitted and corroded from being...well...17 years old and original. A lot of the parts can be replaced (my contact set was around 25 bucks). They're not hard to tear apart...the worst part of the job (no kidding) is pulling it off and getting it back on. That lower bolt is a headache.
Whatever route you go, good luck!
voodoochylde is offline   Reply With Quote
Old 05-05-2008, 09:50 PM   #4
voodoochylde
Member#: 135005
1999 Impreza L
Red
Whoops! Double post! Sorry!
Need help with installing replacement OEM rear springs on '99 OBS Ski4Ever Impreza Forum 0 06-26-2009 04:36 PM
Can a remote starter ruin the starter motor? Please Help! big67 Car Audio, Video & Security 4 12-21-2005 09:15 AM
is it possible to get the '99 RS look for my '99 OBS? kaisersouse Interior & Exterior Modification 4 07-18-2005 01:35 PM
Replacing Starter Motor roffle Service & Maintenance 3 07-26-2004 07:19 AM
('93-'01) How to tell a '99 OBS from an '00 OBS? Necromancer Impreza Forum 6 01-13-2004 03:07 PM
