Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 05-05-2008, 07:44 PM   #1
sorrowfulkiller
Member#: 170439
I <3 Lamp
Default Wiring from engine bay?
I've been looking for a spot to get some wiring thru from the engine bay into the pass compartment, where is the easiest way thru the firewall... btw I'm trying to get 6+ wires thru for my homemade wideband
sorrowfulkiller is offline   Reply With Quote
Old 05-05-2008, 08:07 PM   #2
02redwagone
Member#: 87067
02 Old but tasty
SRP
Look for the big rubber grommet in the pedal area under the dash and cut an X in it just large enough to accommodate your properly split loomed wiring. You can see it behind the drivers side of your TMIC too.
02redwagone is offline   Reply With Quote
Old 05-05-2008, 08:14 PM   #3
VMRSport
Vendor
Member#: 178415
+1, on a 06 WRX I worked on, it was right behind the clutch pedal. Didn't have to move anything out of the way to get to it.
Very easy to take off and put back on.
VMRSport is offline   Reply With Quote
Old 05-05-2008, 08:28 PM   #4
danmezz
Member#: 126339
2003 WRX Wagon
there should also be another big rubber grommet behind the intercooler you can feed wires through as well...
danmezz is offline   Reply With Quote
Old 05-05-2008, 08:41 PM   #5
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
unless you have a front mount, then it will not be behind the intercooler... just look for the rubber plugs on the firewall
skate enjoi is offline   Reply With Quote
NEWB QUESTION!: which hole do i run a wire from engine bay to interrior? bnr34rb26dett Newbies & FAQs 4 05-31-2009 06:10 PM
Smoke coming from from engine bay... minhha2006 Mid Atlantic Impreza Club -- MAIC 2 10-06-2008 01:37 PM
Getting wires from engine bay to cabin. willguidry Electrical & Lighting 11 02-04-2003 01:39 PM
creaking noise from engine bay? imprezey Normally Aspirated Powertrain 0 08-30-2002 06:18 PM
burning smell from engine bay 2.5GT General Forum Archive 6 12-04-2000 10:43 PM
