Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 05-06-2008, 08:53 AM   #1
Member#: 154959
Question Engine Cutting Off
My 04 JDM STI idles perfectly around 750 RPM, runs beautifully with one new exception; the engine sometimes cuts off for no apparent reason, sometimes when changing gears, or turning a corner.
It's not repeatable at will, so it's difficult to diagnose, no CEL or error code is being recorded.
Any ideas ? Plugs, filters (Oil, gas) changed within last 20,000km. Problem just cropped up in last week.
csugden is offline   Reply With Quote
Old 05-06-2008, 03:29 PM   #2
Member#: 45516
MY04 STi
The engine can sometimes cut out if you go around a corner with less than 1/4 tank of gas. As gas sloshes away from the fuel pickup, the engine momentarily stutters until fuel flow is restored to the engine....might be your problem...
This problem was reduced in 05 STis as they changed the way the fuel pump picks up fuel, but 04 and earlier still suffered slightly.
Timdog1650 is offline   Reply With Quote
Engine stall/cut-off during heavy load shaggy-with scoobi Warranty Issues & SOA Problems 2 08-20-2009 07:54 PM
CEL and engine cut off anotherfiz General Community 11 07-12-2007 07:11 PM
Radiator fan causing low idle and engine cut off :( C4STI Service & Maintenance 2 11-07-2005 08:32 PM
Engine cutting off! Hawk296 Normally Aspirated Powertrain 4 01-27-2004 08:46 PM
engine cutted off alexr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-19-2002 12:57 PM
