Old 02-23-2002, 07:10 PM   #1
MrWRXNYC
Member#: 14310
Platinum Silver
Question WHat do u think about only putting springs in the front?
I just bought eibachs,
and im thinking, the back height of the stock wrx is fine...
what do u guys think about only dropping the front?
Peace
Mike
MrWRXNYC is offline   Reply With Quote
Old 02-23-2002, 07:29 PM   #2
SFastWRX
Member#: 13379
I am Oz
Not a good idea. The stiffer front springs with the stock struts will make the front underdamped and bouncy, while prematurely wearing out your front struts. Better to install the full set of springs and replace the struts with a set that has proper damping for the spring rate. Or if you have the cash and want the best handling/adjustability, you could get coilovers (but you already have the springs, so get the struts).
SFastWRX is offline   Reply With Quote
Old 02-23-2002, 08:32 PM   #3
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Exclamation
First, springs aren't only for lowering as aftermarket springs have higher spring rates than the factory ones. Stiffening the front without stiffening the rear as well will increase understeer.
Also the Impreza is supposed to be slightly lower in the rear for optimum handling (it's due to the chassis design). Lowering the front only would hurt handling.
Shane -- http://www.warpthree.net
Warp3 is offline   Reply With Quote
Old 02-23-2002, 08:50 PM   #4
MrWRXNYC
Member#: 14310
Platinum Silver
Ok thanks guys
Peace
What Do You Think About The Mail In Maps TSO AccessPort 7 06-23-2009 11:34 PM
What do you think about this front lip? Woot Interior & Exterior Modification 27 01-13-2007 08:19 PM
What do you think about in the shower? WRXedUSA Off-Topic 28 01-30-2004 10:57 AM
What do you tip and what do you think about it? sonicsuby Off-Topic 58 10-29-2003 06:16 PM
What do you think about the Cerwin Vega 2602? Fusion Car Audio, Video & Security 3 09-06-2000 08:00 PM
