Old 05-07-2008, 09:33 AM   #1
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
Default New patch in the works for 16bit models
I thought i'd give you an update on the new patch that i am working on and of course gauge interest
Features currently implemented:
1.Launch control
2.Boost + wastegate map switching
3.Rev protect (rev limiting based on coolant temperature)
4.Valet mode (switchable on/off)
so what do you think?
xswrex is offline   Reply With Quote
Old 05-07-2008, 10:28 AM   #2
4wdwrx
Member#: 72042
2002 WRX impreza
WRB "Blue Mammoth"
looks good. how about adding anti-lag
4wdwrx is offline   Reply With Quote
Old 05-07-2008, 10:28 AM   #3
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Sounds great.
5. that virtual gauge/dash program you started working on
wrxsti.l is offline   Reply With Quote
Old 05-07-2008, 01:52 PM   #4
Hawke
Member#: 25777
1.Launch control
I suppose there isn't enough room to include a timing table, fuel table and injector scaling? Just thinking of a map switch to change from a pump tune to a race or E85 tune.
Hawke is offline   Reply With Quote
Old 05-07-2008, 02:25 PM   #5
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
He's allowing the switch from MT to AT WG & Boost tables in the factory ROM, similar to ECUTec I'm sure.
testes1010 is offline   Reply With Quote
Old 05-07-2008, 03:14 PM   #6
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
Valet mode would be awesome.
Casey is offline   Reply With Quote
Old 05-07-2008, 11:23 PM   #7
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
how would you change boost + wastegate on the fly? also how to enable valet mode??
mostly interested int he first 3, i like the 3rd one, very clever!
ProdriveDreams is offline   Reply With Quote
Old 05-08-2008, 01:58 AM   #8
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Very nice!
Are you planning on carrying this over to 32bit or will there be changes?
fujiillin is offline   Reply With Quote
Old 05-08-2008, 02:07 AM   #9
xswrex
Member#: 87255
2002 Impreza WRX
well there is room in a different area, but this is something else and out of scope of current patch in discussion.
Old 05-08-2008, 02:10 AM   #10
xswrex
Member#: 87255
2002 Impreza WRX
On the other hand not all ROMs have 2x boost and wg tables from the factory
Old 05-08-2008, 02:15 AM   #11
xswrex
Member#: 87255
2002 Impreza WRX
Boost & wg map switching is toggled when the engine is running, vehicle is not stationary, throttle is fully depressed and rear defogger switch is toggled from off to on.
Valet mode is toggled when the vehicle is stationary, ignition is on without engine running, throttle is fully depressed and rear defogger switch is toggled from off to on
Old 05-08-2008, 02:20 AM   #12
xswrex
Member#: 87255
2002 Impreza WRX
Originally Posted by fujiillin View Post
Very nice!
certainly planning to carry it over
Old 05-08-2008, 04:55 AM   #13
bebeu
Member#: 43088
00 Impreza
I am waiting for these features :
U Rocks man
bebeu is offline   Reply With Quote
Old 05-08-2008, 05:44 AM   #14
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
that rev protect sounds like what the new BMWs have.... kewl!
Hyper is offline   Reply With Quote
Old 05-08-2008, 09:43 AM   #15
Hawke
Member#: 25777
That makes sense.
Thanks for the awesome work xswrex!
Old 05-08-2008, 09:52 AM   #16
Bullwinkle1983
Member#: 172332
2006 WRX
18g'd and RomRaided
In that case, I'm really looking for a quickly flashing CEL on knock/FBKC. Similar to the UTEC style.
Bullwinkle1983 is offline   Reply With Quote
Old 05-08-2008, 10:12 AM   #17
MIKE DD
Member#: 106818
+1 for valet mode!! I have to valet my car alot here in s. florida.
MIKE DD is offline   Reply With Quote
Old 05-10-2008, 09:15 AM   #18
quazimoto
Member#: 70395
How about wastegate compensation per gear?
quazimoto is offline   Reply With Quote
Old 05-11-2008, 08:25 AM   #19
Rogan
Member#: 142133
3 Jeeps
And a Saab
Flat foot shift
1.Launch control
Rogan is offline   Reply With Quote
Old 05-11-2008, 11:17 AM   #20
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Honestly, it isn't really necessary. Just tune for 4th gear and use the vehicle speed compensation for 1st gear.
If it's really an issue, a good BCS isn't that expensive.
Old 05-11-2008, 01:25 PM   #21
quazimoto
Member#: 70395
16 bit ECU's do not have vehicle speed compensation for first gear.I use a GMBCS.I would like to tune for 1st or 2nd gear,which allows for the quickest spool up.Yes,yes it is necessary.It would allow any 3 port to work like an MBC but without the PTFB.
Old 05-11-2008, 11:46 PM   #22
eminehart
Member#: 11205
2009 WRX
Dom3-e85-ewg
I heard about running a MBC in parallel with the GMBCS would be be the current fix. Running high Wastegate duty then have the MBC as the failsafe for the top end in higher gears. Not exactly sure what is meant by in parallel but I am kinda wanting to do this. I would have to think about the vacuum hose routing for a bit to come up with the solution.
eminehart is offline   Reply With Quote
Old 05-12-2008, 12:09 AM   #23
eminehart
Member#: 11205
2009 WRX
Dom3-e85-ewg
ok here it is.
Set wastegate duty to 100% in the full throttle column.
Set up a Tee to split manifold pressure to both BCS and MBC than set up a Tee to connect the output of the BCS and the output of the MBC to the Wastegate.
Effectively you have an Manual Boost controller at Full Throttle and use the computers wastegate duty at part throttle. If the computer want's the wastegate to open it does, if the MBC wants it to open it does.
I just now wish I hadn't sold my Perrin MBC.
Old 05-12-2008, 09:05 AM   #24
Rogan
Member#: 142133
3 Jeeps
And a Saab
here's my crude but effective diagram..
Old 05-13-2008, 11:42 AM   #25
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
oddly enough my 97 wrx ecu has this built in already
spark & fuel cut at 5000 until warm
hooray. new system in the works! Giganticprune Car Audio, Video & Security 50 05-23-2008 03:41 PM
AutoWeek reports that Legacy and Forester STI may be in the works for USA! rsholland News & Rumors 66 11-14-2006 12:17 AM
New movies in the works phillywrx Off-Topic 54 11-08-2003 02:01 AM
Are any struts in the workings for the WRX? Raslian Brakes, Steering & Suspension 1 03-31-2003 11:35 AM
Possible new SVX in the works? HomerJay SVX Forum Archive 6 08-22-2000 08:50 PM
Message Board Statistics All times are GMT -4. The time now is 02:45 AM.
