Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Old 05-07-2008, 12:33 PM   #1
ursmother
Member#: 64447
Default Replacing timing belt, need to do pump too?
Does everyone typically replace the water pump when they are doing the timing belt? The dealer said they don't usually do the pump, since they have very little problems with them.
ursmother is offline   Reply With Quote
Old 05-07-2008, 12:56 PM   #2
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
No you do not need to change the w/p unless it is leaking. These are not Honda's and Toyota's. The Subaru w/p rarely go bad. However, if you want a piece of mind, then go ahead and change it. Of all the Subaru's we see, maybe 2 or 3 had leaking pumps.
blackfang is online now   Reply With Quote
Old 05-09-2008, 01:34 PM   #3
BGPKR
Member#: 41842
2006 LGT LTD 5SM
Would it be safe to assume that oil pump replacement is recommended when replacing the timing belt?
BGPKR is offline   Reply With Quote
Old 05-09-2008, 02:11 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Not unless it is leaking or have failed.
Old 05-09-2008, 05:30 PM   #5
flstffxe
Member#: 155358
2008 Forester
Steel Silver
No need to replace it but it is a good idea to re-seal it. Along with doing the crank seal, cam seals. If it were me, I would reseal the water pump while you are there. Less work now to prevent it from happening down the road, then it would be to do it "if" it leaks down the road.
flstffxe is offline   Reply With Quote
Old 05-10-2008, 12:35 PM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
they don't go bad huh?
hehe, I've seen a lot of them go. Mostly do to improper coolant changes and corroded pump wheels which ate away at them. Yes they don't leak, but they can and will fail.
No need to mess with the oil pump UNLESS its already leaking. Other than that leave it be.
to the op.
replace it. you are in there and what really is another $65 at that point??
sidewayz is offline   Reply With Quote
Old 05-10-2008, 06:55 PM   #7
RoadTrippin
Member#: 161175
Just changed my timing belt, replaced the WP and OP as well b/c both were leaking...oh well, personally considering WP's arent too costly and you will be working in the area anyways I would just do it, save yourself the hassle later.
RoadTrippin is offline   Reply With Quote
Old 05-11-2008, 01:30 AM   #8
Engmus
Member#: 115645
When I do mine, I'll be doing the oil and water pump.
Stricly because with my luck, I'll bottle it up, drive 5k and one or the other will go out.
Of course...with my luck i'll replace them with new and get a dud new out of the box...haha.
Screwed either way!
Engmus is offline   Reply With Quote
Old 05-11-2008, 09:03 PM   #9
blackfang
Member#: 131347
2007 Legacy 2.5i SE
to the op.
I never said they do not go bad. I said they rarely go bad. There is a difference.
These are not Toyota's or Honda's which are pretty much guaranteed to be leaking or weeping by 90k. When I worked for Toyota about 75% or more w/p's were bad by 90k.
In the past 18+ months, we have had 1 water pump fail on a Subaru. I see some 150-200k Subaru's daily as well. I think that is all the proof I need to make a professional opinion on them.
Old 05-11-2008, 09:45 PM   #10
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
i chose not to change the water pump during my timing belt change...
at 163k now, but I will change it at the 210k timing belt change!!
dm
dwmoss_68 is offline   Reply With Quote
Old 05-11-2008, 11:47 PM   #11
ringe
Member#: 49998
2007 WRX CT Stg 2
There is no reason NOT to do the water pump at the same time as the timing belt, along with your cam and crank seals. Those seals are prone to leaking, and the water pump is just added insurance that you won't have to redo any of this work before a new belt is needed.
ringe is offline   Reply With Quote
Old 05-12-2008, 10:03 AM   #12
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Yes it is a piece of mind, but you do not have to replace them if they are not leaking or failed. Some people make it out to be a requirement, but it isn't. If you want the piece of mind and have the extra coin, then that is fine.
Replace timing belt/water pump after frozen "coolant"? TurboGoKart Newbies & FAQs 22 03-11-2009 04:25 PM
Timing Belt Needs Replacing rlin0997 South West Impreza Club Forum -- SWIC 15 01-22-2009 05:52 PM
Need Help! Timing belt, tensioners, idlers, water pump, crank/cam seals dhjester Service & Maintenance 4 08-23-2008 09:48 PM
Looking for help to replace timing belt on a CRX?(Sac) jotarou1 Bay Area Impreza Club Forum -- BAIC 0 02-22-2003 05:25 PM
How much to replace timing belt? Kalins1 General Forum Archive 10 07-27-2000 04:36 PM
