Old 05-07-2008, 12:56 PM   #1
calmbomb
Member#: 168971
2011 STI
Default WRX OEM Lamco boost gauge replacement
So I haven't fully disasembled my current setup but I bought the car used with the lamco kpa boost gauge on the steering column. I was wondering what gauges would be the best replacement. I don't think I want any other gauges except maybe an EGT. I like the placement on the column or the pod that replaces the gauge pod bezel. What would be the easiest reasonably priced gauge to swap in where I wouldn't need to rewire for it? I couldn't tell if the MadDad gauges were mechanical or eletric, and im assuming the Lamco one is mechanical.
calmbomb is offline   Reply With Quote
Old 05-09-2008, 02:09 AM   #2
calmbomb
Member#: 168971
2011 STI
bump....
anyone? please?
Old 05-09-2008, 06:41 AM   #3
JW1016
Member#: 125007
2002 WRX Sedan
I have the OEM Lamco boost gauge and was thinking about replacing it. The out to out dimension is +/- 1 11/16" on the bezel (inside the mount). It's a mechanical gauge, so I fairly sure that eliminates Autometer, since the smallest they have is 2 1/8". I did the searches and have the same question you do. Hopefully, highspeed forum rangers will help us out!? Hello...anybody out there?
JW1016 is offline   Reply With Quote
Old 05-09-2008, 07:53 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
The closest direct replacement is the Omori 45mm series of gauges, these are close enough to the 42mm size of the Lamco to fit in the same pod with a bit of persuasion. There was a mechanical version but I don't know if it's available any more, you can use the electrical version with just a bit more work.
For more info on the Omori gauges contact J-Spec Tuning, they are a NASIOC vendor and US distributor for Omori.
Old 05-09-2008, 08:10 PM   #5
calmbomb
Member#: 168971
2011 STI
I guess i was more concerned with the vacuum line and the power wires than the gauge housing, but thanks for the info
F/S(SC)- OEM Lamco Boost gauge w/ wiring, WRX Fronts Seats, Stinger Power Supply, juanmedina Interior/Dressup/Audio & Security 30 06-19-2010 03:21 PM
FS/SOCAL OEM Lamco Boost Gauge/WRX CLOCK dkan Interior/Dressup/Audio & Security 11 02-08-2009 02:57 AM
subaru oem lamco boost gauge w/ oem pod scooby_x Interior/Dressup/Audio & Security 7 04-02-2008 10:20 AM
OEM Lamco Boost Gauge, Clock Pod, OEM Speakers B16A2NR Interior/Dressup/Audio & Security 5 07-16-2007 11:18 PM
WRX OEM laMco Boost Gauge*RED LED* Aspenrex03 SCIC Private Classifieds 2 07-10-2007 01:47 PM
Message Board Statistics All times are GMT -4. The time now is 01:07 PM.
