Old 05-07-2008, 07:51 PM   #1
ardevas09
Member#: 164710
05 440whp STi
2014 Evo X
Default defi help
alright, i bought 3 defi gauges (boost, egt, oil press) and a control link. The only wire that came with it was the wire that connects the 3 gauges to one another. i believe it's called the "daisy chain"
Now i'm in need of someone to review my list of things i think i need, to make sure i'm not buying anything i don't need/want.
boost sensor
boost meter wire
3 way fitting
rubber hose
oil pressure sensor
oil pressure sensor wire
oil pressure meter wire
egt sensor
egt meter wire
egt fitting
control link power wire
that's what i have listed... anything to add or omit?? Thanks for any help!
ardevas09 is offline   Reply With Quote
Old 05-07-2008, 08:15 PM   #2
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
The wires that connect the meters together are called the meter wires. These are the 10" long wires that come with each gauge. To connect the control unit to the gauges, you will usually need a longer (about 6') meter wire due to the placemment of the control unit. So, if you are using a 3-gauge pod, you would need two 10" meter wires to daisy-chain the 2nd & 3rd meters together and one 6' wire to connect the 1st meter to the control unit.
Check out the parts list:
http://www.nippon-seiki.co.jp/defish...parts_imp.html
...and the manual:
http://www.nippon-seiki.co.jp/defish...nual06064e.pdf
jac04 is offline   Reply With Quote
anyone have a pioneer avic u310bt need some help cosanostra Car Audio, Video & Security 5 06-04-2010 12:20 PM
defi help boostedNH Electrical & Lighting 3 01-04-2007 05:22 PM
Need more defi help please hybrid gti 2 Electrical & Lighting 0 11-19-2006 11:31 PM
Defi help BritneySpears Interior & Exterior Modification 15 07-23-2006 12:55 PM
Defi Help Please! mikeg313 Electrical & Lighting 1 08-22-2003 11:29 PM
