Old 05-08-2008, 10:06 AM   #1
efmd3
Member#: 120985
2002 Impreza WRX
Midnight Black Pearl
Default Diagnosis help.
So i just got my 6sp back into my 2002 WRX.
a few miles down the road, fuse #18 blew.
I replaced the fuse and it blew in the exact same place on the road that it blew the first time (i got there sooner this time).
where might the short be? this circuit has the VSS, head light, high beam, drl, abs solenoid, etc on it.
PS did not do any wire hacking to install the 6sp.
efmd3 is offline   Reply With Quote
Old 05-08-2008, 02:31 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Here is a list of the areas that fuse 18 ties to. If you are just starting the car out from a cold start perhaps the trouble is in cooling fan circuit.
Circuit FB-16
ABS relay
Back-up light switch (MT)
Check connector
Cruise control main switch
Cruise control module
Daytime running light control module
Daytime running light relay
High-beam relay (Daytime running light)
Inhibitor switch (AT)
Keyless entry control module
Security control module
Vehicle speed sensor (MT)
Wiper deicer relay
Wiper deicer timer
Circuit FB-17
Main fan relay (Non-turbo engine model)
Main fan relay-1 (Turbo engine model)
Main fan relay-2 (Turbo engine model)
Old 05-08-2008, 02:38 PM   #3
efmd3
Member#: 120985
2002 Impreza WRX
Circuit FB-16
ABS relay
Check connector
Wiper deicer relay
Wiper deicer timer
Circuit FB-17
thanks for the help, but i've solved the problem.i didn't see that the craptacular packing job stripped the wires to the reverse sensor and they were arcing through the trans. i disconnected the reverse sensor and the problem is gone. looks like i'll need a new reverse sensor.
Old 05-08-2008, 10:53 PM   #4
Cougar4
Member#: 53443
Winestone
Glad you solved the trouble. Thanks for the feedback.
850cc's lean cold start diagnosis help Macabre Engine Management & Tuning 67 11-01-2005 01:52 PM
Need HID diagnosis help, relay? 909 Electrical & Lighting 4 06-01-2005 03:12 PM
Engine Diagnosis help (comp & leakdown test results) Slack Normally Aspirated Powertrain 11 03-10-2005 03:08 AM
Diagnosis Help? Since the SE is so cool zoomfactor South East Region Forum 14 01-08-2004 11:09 PM
diagnosis help nyaconis Transmission (AT/MT) & Driveline 2 06-14-2003 12:32 AM
