Old 05-08-2008, 03:18 PM   #1
mgoss79
Member#: 168136
2004 WRB WRX
VF-39 2.5 hybrid
Default What does the owner's manual say for distance between oil changes?
For a 2004 WRX - what does the owner's manual say for miles in between oil changes? I think it says 3000 - 7500 miles between oil changes if using synthetic? I am in a situation with my warranty company and I'm missing some receipts.
mgoss79 is offline   Reply With Quote
Old 05-08-2008, 03:20 PM   #2
Nicklz
Member#: 94096
2003 WRX
I can tell you for sure it's not 75000 miles
Nicklz is offline   Reply With Quote
Old 05-08-2008, 04:05 PM   #3
MasterKwan
Member#: 98961
2003 WRX
US 06 shop manual says 7500 miles.
I did read about a TSB that claims that any turbo needs 3500 mile, severe duty intervals. I've not read the TSB myself.
Synthetic or not doesn't matter. You need to change at no more than 7500 miles no matter what oil you use. If not, kiss your warranty goodbye.
Old 05-08-2008, 08:30 PM   #4
mikeythejew
Member#: 141672
Your year is under the 7500 mile normal service interval period. As said by me before, take photos of your receipts with date and mileage written on them and burn the jpegs to a CD-R. Keep the CD-R and receipts in a $25.00 @ walmart sentry locking fire chest.
mikeythejew is offline   Reply With Quote
Old 05-09-2008, 12:56 AM   #5
Arctic Penguin
Member#: 119532
2006 WRX
or 4 months whichever is sooner
(not kidding)
Arctic Penguin is offline   Reply With Quote
Old 05-09-2008, 08:31 AM   #6
mgoss79
Member#: 168136
2004 WRB WRX
VF-39 2.5 hybrid
That's good advice but it won't help much now as I am missing some receipts. Hopefully I can figure something out.
Lesson learned to keep all receipts in a safe place. I've never had a warranty on a car before and never even thought this would be an issue.
Old 05-12-2008, 12:25 AM   #7
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
What situation are you in? Are they saying you don't change it enough, or that the oil was low, causing a problem.
Technically, whether using synthetic or regular oil, you can, although not really advised anymore, go 7500 miles under normal driving conditions. BUT, you need to check the oil frequently, especially if using synthetic, because it is not uncommon to burn oil in a few thousand miles, up to a quart every 1000 miles is considered normal, although not common.
If you engine is sludged, you are not changing it enough. If your engine was low on oil, you are not checking it enough.
Receipts show proper maintenance in both instances, so depending on your situation, you will need to show that you have done the oil changes and check the oil on a regular basis.
Depending on whether you did the services yourself or at a shop, you can usually call the shop or dealership for copies. Depending on the state, they need to keep records for a few years.
RexyGirl is offline   Reply With Quote
What does the unmarried screen say on accessport nerdydorkus AccessPort 2 04-14-2006 09:01 AM
Umm... What does the future look like for the STi? STiBoost25 General Community 10 09-10-2005 12:51 AM
What does the Focus WRC use for a transmission/transfer case? Gravel-Fun Motorsports 2 06-12-2004 10:18 AM
What does the Focus WRC use for a transmission/transfer case? Gravel-Fun Off-Topic 8 06-11-2004 07:16 PM
What does the USDM STi mean for the SCCA ProRally Open class? jackansi STi Forum Archive 5 02-20-2003 07:27 PM
