Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 05-08-2008, 04:08 PM   #1
B16A2NR
Member Sales Rating: (69)
Member#: 88676
Default Hotchkis Front Sway Bar, Hotchkis Front Camber Plates
Hotchkis Front 02-07 Sedan WRX/STi Sway Bar 1" 25.4 mm
Comes with hotchkis 1" bushings, brackets, front endlinks. Same exact bar as the blue Cobb version sold sold sold
Hotchkis front Camber Plates SOLD. Front OEM STi KYB Struts, Front OEM STi Springs 15k miles make an offer.
http://www.racebydesign.net/store/in...roducts_id=363
B16A2NR is offline   Reply With Quote
Old 05-10-2008, 02:56 AM   #2
B16A2NR
Member#: 88676
Bump.
Old 05-10-2008, 02:40 PM   #3
crazycanasian
Member Sales Rating: (6)
Member#: 129554
03 WRX
this 25mm is hollow right? so what does that equate to solid?
crazycanasian is offline   Reply With Quote
Old 05-11-2008, 04:40 PM   #4
B16A2NR
Member#: 88676
a 25.4mm by 6.35mm tube will act like a 25.0 mm solid bar as in
torsion and bending (swaybar).
http://www.whiteline.com.au/docs/bul...%20Swaybar.pdf
Sway bars work off of torsional force (twisting motion). Therefore, the material in the center of a solid bar plays little role in the resistance of torsional force. With this in mind, we have eliminated some of the center material and also moved some to the outside of the tube, where it is most effective. In turn, this produces a sway bar that is lighter in weight and just as stiff, if not stiffer than solid. For example, a 1’3/8” hollow bar is equivalent to a 1’1/4” solid. But the 1’3/8” hollow bar is 6% stiffer and 43% lighter than the 1’1/4” solid.
Old 05-12-2008, 11:41 PM   #5
B16A2NR
Member#: 88676
Bump.
Old 05-13-2008, 05:42 PM   #6
B16A2NR
Member#: 88676
Camber plates sold. Just the struts and springs left.
Wagon Whiteline 22mm front sway bar, kartboy front endlinks SOCAL thejaredhuang Suspension/Brakes/Handling 3 08-05-2009 03:07 AM
Wagon Whiteline 22mm front sway bar, kartboy front endlinks thejaredhuang SCIC Private Classifieds 8 08-03-2009 02:50 PM
WTB: CUSCO Front Sway Bar (Optionally Front Enlinks) for 05 STI bptrueno Private 'Wanted' Classifieds 0 01-07-2008 06:14 PM
wtb adj 24mm front sway bar & front endlinks jlam86 VIC Private Classifieds 3 05-01-2007 12:45 AM
front sway bar vs. front upper tie bar WrexFactor36 Brakes, Steering & Suspension 7 02-13-2005 02:56 PM
