Old 05-08-2008, 10:56 PM   #1
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
Default My Bugeye got ANother EYE Transplant (3rd Retrofit)
Bought my car with koji modded headlights
Shortly after that I retroed some e46 bixenons in used housings
Wanted less chrome - wanted something sportier (same projectors)
The lenses got pretty bad on these after a while, wet sanding only made it slightly better, so I got these.
USDM replicas, and rocked them for 6 or so months
Started driving at night a lot more and wanted hid again... this time I wanted more light, using porsche bixenons with 55w ballasts.
Driver
Front
Unfortunately I don't have many spots around the area that have little ambient lighting, this is the best so far (got it done today)
Driver side IS dimmer because it's still the 35w matsu****a ballast, need to wait on a new d2s connector to come in soon (hopefully)...
Porsche bixenon projectors (HUGE)
55w Apexcone/DDM ballasts (TINY)
Osram 66040 bulbs (maybe swapping for 85122+)
E46 shroud (painted obviously)
Amber led corner running light
Chrome/Amber turn signal bulb
Questions/Comments?
ptirmal is online now   Reply With Quote
Old 05-08-2008, 11:05 PM   #2
B16A2NR
Member#: 88676
Thats quite a bit of light modding. Hope your happy with the final setup. BTW lip looks sick. Its one piece? Brand?
B16A2NR is offline   Reply With Quote
Old 05-08-2008, 11:22 PM   #3
ptirmal
Member#: 82243
07' Acura TL-S
Yes I am finally happy with the headlamps... I bought the car with the lip, I believe it's a v1 STi. Might be doing something with the fogs now though,
Old 05-08-2008, 11:49 PM   #4
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
wow, frankenheadlights for sure!
mmiller2002 is offline   Reply With Quote
Old 05-08-2008, 11:59 PM   #5
LightWerkz
Member#: 125432
2004 E46 M3
http://lightwerkz.net
Looks good. Driver side seems a bit off rotationaly, could use clockwise adjustment.
Raise the drivers side beam while you are at it.
But great job man, retrofits make driving at night a pleasure! Those shrouds kick ass inside those lights...never seen that before.
LightWerkz is offline   Reply With Quote
Old 05-09-2008, 12:47 AM   #6
ptirmal
Member#: 82243
07' Acura TL-S
Yea I was in the process of aiming them and I didn't bolt the center bolts which keep the lights leveled. It's level though. I need to raise them both up a bit but I'm just going to wait until I swap the other ballast. I don't have the philips horizontal adjustment screw like stock headlights and my socket wrench doesn't fit behind the headlights so I basically have to take them off tighten/loosen and check them...
Old 05-11-2008, 12:41 AM   #7
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
+1 on those shrouds
jdubya301 is offline   Reply With Quote
Old 05-11-2008, 12:40 PM   #8
ptirmal
Member#: 82243
07' Acura TL-S
They're my favorite shrouds, too bad they're so expensive and hard to come by but they do have replicas out now...
Old 05-11-2008, 03:17 PM   #9
subaru3169
Member#: 55252
* pullup bar *
any experience with the replicas??
subaru3169 is offline   Reply With Quote
Old 05-11-2008, 03:21 PM   #10
ptirmal
Member#: 82243
07' Acura TL-S
No not personally - there was a review on hidplanet and I believe they are only missing the xenon with the indents going all the way around... also they are thicker plastic and chrome is more durable from what I read
Old 05-11-2008, 03:49 PM   #11
subaru3169
Member#: 55252
* pullup bar *
ahh.. that's not a bad deal then if it's really that much more affordable
Old 05-11-2008, 06:22 PM   #12
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Your car looks like a vehicular terminator t800....
G3Red04WRX is offline   Reply With Quote
Old 05-20-2008, 12:05 AM   #13
ptirmal
Member#: 82243
07' Acura TL-S
Posted this in another thread, figured I'd post it here in case anyone was thinking about where to mount the ballasts...
The ballast I'm using (black one)
Screws attached
Drilled holes, you can see the screw ends sticking through with washers and nuts, the right one is hidden slightly by the loom
Right under that sheet
Driver side had lots of room under there to mount to that sheet, the passenger side has some wiring under which makes it more congested but as you can see my ballasts are small...
Old 05-20-2008, 12:12 AM   #14
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
You go through headlights like I go through girlfriends. Hey oh!
axelthrasher is offline   Reply With Quote
Old 05-20-2008, 10:21 PM   #15
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
are you running the high voltage from the ballasts through those crimp connectors?
Old 05-20-2008, 11:48 PM   #16
ptirmal
Member#: 82243
07' Acura TL-S
No those connectors are for the high beam solenoids and power to the ballasts...
Igniter to the d2s connector is connected with amp connectors and I haven't messed with the wires on them (they're long enough)
Old 05-22-2008, 04:16 PM   #17
spdfrk77
Member#: 37596
2002 Impreza WRX
black
damm they look hot. I'm thinking of doing this since I have a spare set of cheap replica morettes(after diy splitter and guage install). Just where did you get you supplies, average cost of your conversions and average time dedicated to it??
spdfrk77 is offline   Reply With Quote
Old 05-22-2008, 09:00 PM   #18
ptirmal
Member#: 82243
07' Acura TL-S
Check out Jdubya's thread for a better look on how you do it...
http://forums.nasioc.com/forums/show....php?t=1482552
It will probably be harder on replica morettes (they have two projectors right?), because not many projectors can fit in their location...
Prices
Porsche bixenon projectors - I paid 120 a long time ago (now they're a lot harder to find and more expensive), projectors run 100-300 depending on the projector
55w Apexcone/DDM ballasts - I paid 160, OEM ballasts run about the same for 35w used ones
Osram 66040 bulbs (maybe swapping for 85122+) - I am now running 85122+ bulbs, bulbs cost about $100 new or 40-60 used
E46 shroud (painted obviously) - I had these for a LONG time, I think I paid 30 for them back in the day, now they're about 150. Different shrouds cost different prices, you can even make your own from stuff in stores if you get creative.
Time depends on how confident and careful you are. I could bang out a set of bugeye headlights in a weekend taking my time I believe. I normally spent longer waiting on parts and being lazy, lol...
Old 05-23-2008, 04:20 PM   #19
spdfrk77
Member#: 37596
2002 Impreza WRX
black
ptirmal, thanks for the info, BIG HELP
yeagh they have two projectors. I am pretty confident that some modification to each of the projector portion of the replicas is in order. I Will not know until after my research on the projectors. looking at the the diy retro fit, it's gonna be tricky.
Old 05-24-2008, 04:53 AM   #20
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
those are gonna be effin hard to do. you will have to find some sealed units (most likely hellas) and probably learn some fiberglass skills
Old 05-25-2008, 03:38 AM   #21
spdfrk77
Member#: 37596
2002 Impreza WRX
black
thanks for the tip on the hellas, i have to do research for sure on this.
I am thinking of keeping away from fiber glass. I hear it`s kinda fragile.
Old 05-25-2008, 12:15 PM   #22
ptirmal
Member#: 82243
07' Acura TL-S
Who told you that? Fiberglass done right is EXTREMELY strong
My Bugeye for a Hawk eye? Nitrousspeed General Community 29 07-27-2009 12:35 AM
my bugeye gots the stiff. sigurd Member's Car Gallery 5 04-12-2008 12:47 AM
Bugeye Extinction - Another I Got My Car Back From the Body Shop Thread karazyman Member's Car Gallery 24 09-15-2007 06:51 PM
Should I do angel eyes to my bugeye retrofit drrice Interior & Exterior Modification 9 11-29-2006 12:52 AM
Uh oh... another Californian transplant! Bomb20 North West Impreza Club Forum -- NWIC 13 08-10-2002 05:05 AM
