Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 05-08-2008, 10:26 PM   #1
johnb990
Member#: 125325
2015 Subaru WRX STI
Default Kazama voltage stabilizer/ grounding kit
Hey everyone I've just got the Kazama voltage stabilizer/ grounding kit. i was just wondering if anyone can tell/help me where to put the gound wires. Please help. thanks everyone.
John
johnb990 is offline   Reply With Quote
Old 05-08-2008, 10:39 PM   #2
xlur8ed
Member#: 147812
1998 2.5RS
Brilliant Red
There isn't really an incorrect way to install a ground kit. Use the wires to go to as many different components under the hood as possible. Typically I would run one to the ground point on the strut towers, block, firewall, etc..
Here is a picture of my vehicle, yellow circles are places I used for grounding. Just look for places that the factory grounded too (usually 10mm bolts) and ground ontop of them. The words I typed on intercooler state there is a ground point on the firewall behind the intercooler that I cannot circle for you.
Hope that helps!
xlur8ed is offline   Reply With Quote
Old 05-09-2008, 12:08 AM   #3
johnb990
Member#: 125325
2015 Subaru WRX STI
Hey man...thanks. that actually helps..i wasn't sure where to put them. Now i have an idea. thanks a lot i really appreicaited.
Old 05-09-2008, 12:20 PM   #4
xlur8ed
Member#: 147812
1998 2.5RS
Brilliant Red
you bet man
Old 05-09-2008, 12:54 PM   #5
Craig A.
Member#: 122519
2004 Super 16g'd WRX
drivers and passengers side heads, alternator, passenger and driver side manifolds, and throttle body if possible. The idea is to make a direct ground for sensors, so they have a common ground. Therefore they will have a common reference point. The strut tower is a horrible place for a ground.
Davenow did a write up on it and he highlights grounding points.
http://forums.nasioc.com/forums/showthread.php?t=674153
Craig A. is offline   Reply With Quote
Old 05-09-2008, 02:25 PM   #6
bzbuzz
Member#: 116052
2011 STI ( Sold )
always wrong information from some people here..
you need to research more in here..
do the ground mod correctly otherwise you gain nothing wasting time money energy..
dont reference the picture above..
bzbuzz is offline   Reply With Quote
Old 05-09-2008, 05:44 PM   #7
xlur8ed
Member#: 147812
1998 2.5RS
Brilliant Red
I see NASIOC's finest here Thanks for the chime in guys. The way I regrounded my car took away a stumble at warm idle, took away an IAC issue on the first start of the day, a flutter at ~2500rpms, and alternator whine (ground loop) were ALL gone. To say what I did was bad or poor advice is easily proven wrong, and would imply that Subaru of America has no idea what they are doing. One point you missed or didn't notice is that all of my ground points (yes Craig the strut towers) were OEM ground locations. I slapped a new ground/ring terminal ontop of them (retaining the stock bolt and location of the ground). The link YOU (Craig) provided, shows a newer age impreza (which judging from the OP's car, is more useful)....but what it also shows is exactly what I advise my customers to stay away from. Leaving wiring just ran across here and there without tape/loom is not only tacky, but makes it look like a 16 yr old did it. No matter what you do, buy some zip ties, and at very least route the ground wires with OEM routing (where possible). Here are some pictures of proof on my grounding points being OEM points. The only one that ISN'T a OEM ground point, is the front passengerside of the intake manifold, which I used as a point to send off the other ground wires. This avoided having to run 3 wires across the motor and keep things somewhat cleaner.
Pics:
I regrounded every point I could find as an OEM ground location, and also put one on the block/intake manifold/firewall. All ground wires return to the disc ontop the negative battery terminal, giving equal ground values/strength to all locations. Perhaps I could add more ground points and receive even better results (I'm not perfect), however the main sporadic issues I had are now gone.
So as you both so rudely stated, be careful who you get information from on the internet...Especially those so quick to jump down others throats when they are the unversed individuals.
- Jason
Old 05-11-2008, 09:37 PM   #8
PA-Outback2000
Member#: 161832
2000 Outback Limited
just keep the grounds on the engine. try the alternator area, intake manifold/throttlebody area, and i have one near the tranny bell on the engine.
PA-Outback2000 is offline   Reply With Quote
Kazama Voltage Regulator, Stabilizer! $70 jdmstuff SWIC Private Classifieds 12 01-13-2009 10:36 AM
FS:: SunAuto Hyper Voltage & Grounding Kit!! TURBOTOD Engine/Power/Exhaust 19 02-27-2007 06:49 PM
Kazama Voltage Stabilizer and Grounding! JDM Importers Engine/Power/Exhaust 1 04-28-2006 11:04 AM
Anyone here using the Spoon Ground Voltage Stabilizer? ScoobyNubieToo! Electrical & Lighting 12 12-17-2004 01:30 PM
JAW Inzuma Hyper Voltage Stabilizer Kit aceking66 Private 'For Sale' Classifieds 7 09-28-2004 06:31 PM
