Old 05-12-2008, 10:50 AM   #26
steverx05
Member#: 128269
'13 VW Golf R
Originally Posted by The Satch View Post
edit: just checked out the lightwerkz sight, and having the 06 head lamps, $660 for S2000 HIDs sounds pretty good, 475 for TSX HIDs sounds good too. is there a benefit to running the S2000 projector over the TSX projector?
If you're going to go the retrofit route...get the S2K projectors, you definitely won't regret it. They are amazing at night and offer more width than the TSX projectors, which alone makes these worth the extra price to me. They are a lot more colorful at the cutoff too.
steverx05 is offline   Reply With Quote
Old 05-12-2008, 08:00 PM   #27
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
so whats the easiest way to return these to stock if i choose that route?
The Satch is offline   Reply With Quote
Old 05-12-2008, 11:30 PM   #28
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
so how expensive is it to replace the back of the headlight assembly? i pulled the HID bulb so i could put in an H7 Halogen and cracked one of the plastic nubs off that holds the little spring locking mechanism in place
looking at how the ballast was wired, what is wrong with the spade connectors? they plugged into the stock harness, i fail to see how that is a saftey hazard?
Old 05-13-2008, 01:49 AM   #29
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
its a safety hazzard because most kits have you replace the headlight fuses with higher amperage fuses, the reason for this is because during ignition the ballasts draw more current than the wiring was intended to handle. this SHOULD be ok, because the ignitors act quickly and then the system draws 20 watts less (usually) than the stock 55 watt bulbs, this is perfectly safe. problem is, when they are not working correctly they could be drawing excessive amperage from the ignitors trying to fire repeatedly this can cause the wires to overheat and start a fire as the older apropriate fuses have been removed.
ProdriveDreams is offline   Reply With Quote
Old 05-13-2008, 11:28 AM   #30
steverx05
Member#: 128269
'13 VW Golf R
If you do a retrofit...the easiest way to return to stock would be to sell your retrofit to someone, and as part of the deal, get their stock lights. Or find a set of lights for sale on here in the classifieds.
how to tell between hid projector vs halogen projector? (jdm bugeye) ASpec818 Electrical & Lighting 2 02-27-2009 01:01 AM
jdm HID projector problem.. sp99ling Electrical & Lighting 6 05-04-2008 04:35 AM
JDM STi HID Projectors Problem PhreeZe Electrical & Lighting 2 09-17-2004 12:31 AM
problems with jdm hid projector install Benjamin Tang Electrical & Lighting 2 10-23-2003 11:03 AM
STI JDM HID/Non HID Projectors, glossyblack or flatblack? Vineet Singh Interior & Exterior Modification 3 11-10-2001 07:47 PM
