Old 05-10-2008, 02:24 AM   #1
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Default Grounding steering column
Hey guys, my horn doesnt work and Ive determined that its because the steering column isnt grounded. Any idea how the ground is supposed to be attached? I cant seem to find anything.
Splinter is offline   Reply With Quote
Old 05-10-2008, 10:57 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Are you absolutely sure about that? I find that hard to believe since it has to be so sercured to the dash and firewall.
Old 05-10-2008, 04:05 PM   #3
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
100% sure, theres no continuity between the backing plate where the horn switch contacts and any other ground source in the car, but theres continuity between the backing plate and the universal joint in the engine bay.
The steering column doesnt connect directly to the firewall or dash, it rides inside a sleeve, and Im guessing its supported by bearings, so theres no direct electrical path.
The car was stripped and put back together before I bought it, so Im sure its just a matter of something not being put back in the right places, but I'll be damned if I can figure out what it is.
If steering column to steering linkage bolt fell out, would steering fail? garface Brakes, Steering & Suspension 7 03-18-2009 01:56 PM
FS:06 sti steering rack and steering column Wandaniers Suspension/Brakes/Handling 11 09-25-2007 11:20 PM
WTB 06 forester steering column to steering rack swivel joint 2slofouru Private 'Wanted' Classifieds 1 08-02-2007 07:02 PM
Omitting / Replacing Steering "Damper" on WRX Steering Column to Improve Feel caterpill Brakes, Steering & Suspension 38 03-18-2007 09:59 PM
WTT: OEM boost guage and steering column pod for just steering colum piece D Money Interior/Dressup/Audio & Security 4 12-07-2006 01:19 AM
