Old 05-10-2008, 11:14 AM   #1
conrad87
Member#: 163884
2008 G37S
Default OEM gauge pod removal
Does anyone know how to remove the oem triple gauge pod? is the faceplate where the gauges mount supposed to pop out or what? I've been fighting with this all morning and can't figure it out, its screwed in so it doesnt jut pop out. Heres a pic too....
conrad87 is offline   Reply With Quote
Old 05-10-2008, 11:31 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Grab the pod cover along the sides, and pull towards you and up. It will come off. The cover is held in place by clips.
Old 05-10-2008, 03:12 PM   #3
conrad87
Member#: 163884
2008 G37S
It's not pulling out I'll tell you that. With the vents out I can see as I'm pulling it its trying to pull everything out in one shot, including the screws....I dont see any tabs holding it in underneath, only screws.
Old 05-10-2008, 03:59 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well if it really is screwed in then somebody modified it. The factory pod is held in with only clips/tabs and removes by pulling.
Old 05-10-2008, 10:15 PM   #5
conrad87
Member#: 163884
2008 G37S
well its definately screwed in, but if its screwed in there has to be a way to reverse whats been installed. I tried pulling the front face that the gauges are on out but it seems stuck so I have no idea.
Old 05-11-2008, 06:24 PM   #6
conrad87
Member#: 163884
2008 G37S
no other tips.....
Old 05-11-2008, 07:53 PM   #7
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
give it a REALLY good tug straight back towards the rear windshield (the housing, not the gauges). Mine is fastened VERY firmly with just the push clips, but it will pop off. Id say it needs as much force as the radio trim if you know how firm that piece is held in place.
G3Red04WRX is offline   Reply With Quote
Old 05-11-2008, 08:40 PM   #8
conrad87
Member#: 163884
2008 G37S
well I was just out there tugging, and if i tug any harder my thumbs are gonna break off. i'm guessing im supposed to see clips instead of these screws......
Old 05-11-2008, 08:53 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yep those aren't supposed to be there. Looks like you'll need to get the gauge bezel off first, and then you should be able to access the screws once it's out.
Old 05-11-2008, 09:10 PM   #10
conrad87
Member#: 163884
2008 G37S
ok, just as i thought, thanks for the input
Old 05-14-2008, 09:17 PM   #11
G3Red04WRX
Member#: 66611
Those screws ARE supposed to be there. They hold the metal tray to the dashboard that holds the plastic cover in place.
OK, wait... Now you got me interested. Stand by for pictures of my OEM gauge pod...
Pics:
Installed:
Cover detached from tray:
Inside overview:
Closeup of screw locations:
So, its hard to tell from your pics, but the screws "may" be in the wrong location on your install.
OEM Gauge Pod (52mm) & Omori Oil Temp Gauge 52mm WRXerist Private 'For Sale' Classifieds 13 10-06-2004 12:36 AM
Factory OEM gauge pod with Auto Meter 52mm also including 4th extra gauge rpm-wrx Private 'For Sale' Classifieds 5 09-21-2004 06:28 PM
OEM Gauge POD - no gauges Stang2WRX Private 'Wanted' Classifieds 4 11-25-2003 03:25 AM
CA: Gauging interesting in OEM gauge pod and gauges BlackRex22 Private 'For Sale' Classifieds 20 10-29-2003 05:28 PM
OEM Gauge pod + 52mm gauges? Rocket Wagon Interior & Exterior Modification 6 09-07-2002 02:28 AM
