Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 05-10-2008, 06:37 PM   #1
orical154
Member#: 171317
2005 STi
Question Need help tightening the belts.
Ok so i need to tighten my belts because they are loose and causing this weird rattiling noise. But i don't know how to do it. Here are some photos that i took. I was wondering if i just need to tighten the screws that are circled or is it something else that i need to tighten?
orical154 is offline   Reply With Quote
Old 05-10-2008, 10:04 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
the adjuster to the left of the alternator is for the belt that drives the alt. and power steering pump. The adjuster to the right of the alt is for the ac belt. When adjusting the ac belt make sure you loosen the nut that holds the pulley to the bracket(the pulley bolted into the long slot). That bracket is easily broken, there are many threads on it.
flstffxe is offline   Reply With Quote
Old 05-11-2008, 12:51 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
just pointing out the obvious here, but loose belts usually don't make a rattling noise. The only indication you have a belt too loose is squealing when a pulley slips. Rattling could be all kinds of other things, but very likely an idler going out.
Old 05-11-2008, 01:28 PM   #4
orical154
Member#: 171317
2005 STi
sorry it makes the squeling noise lol
Need to tighten the endlink bolt, Just spins freely, HELP!!?? sanremors Brakes, Steering & Suspension 4 07-29-2008 11:51 PM
Frustrated Novice Needs help with Timing Belt Nick the Novice Normally Aspirated Powertrain 16 10-03-2006 09:09 PM
Need help with timing belt. Norcalrallyist Subaru Conversions 9 07-06-2006 06:13 PM
Advice needed on tightening the Shifter trustWRX Newbies & FAQs 8 07-23-2003 12:33 PM
Don't over tighten the belts! Jason Technical Forum Archive 8 10-02-2000 07:16 PM
