#1 |
Member#: 147521
SCIC
Vehicle:03 Saggy buttwagon PSM |
I have an 03 wrx where my side marker currently died out, anyone have any specific leds i should get to replace? I'd like white leds, but don't know what kind. I tried searching off superbrightleds but didn't know which to get. Any help? Thanks
#2 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
you don't have the oem amber ones huh
#3 |
Member#: 147521
SCIC
i have the oem ambers actually, just switched to the clear side marker. the light bulb popped on me trying to take it out. any help?
#4 |
Member#: 123843
NESIC
Vehicle:2006 SGM WRX S2 Let LED's light your way! |
WLED-x4
32º viewing angle - tight - projects the light mostly forward. WLED-x5 220º viewing angle - wide - projects light out forward and to sides. If used in a 2006/2007 headlamp housing, it fills the housing, for example. If fender side marker lamp is stock, then lense will diffuse light -- this would be a good choice. Can also use -x4 or -x6 If fender side marker lamp is clear (not diffused -- you can see bulb clearly), then use either WLED-x4 or -x6. WLED-x6 35º viewing angle - tight - projects the light mostly forward, with some side projection. If used in a 2006/2007 headlamp housing, it will fill the housing, but less so, but light projected is brighter -- more LED's more light (more flags, more fun). NOTE: the "x" as in "x5" for example, stands for the color you want. So, if ordering an amber bulb, then you would purchase, for example, WLED-A5. |
#5 |
Member#: 180277
Look for superflux LEDs if you can find'em. They're much brighter.
| Thread Tools | |
| Display Modes | |
| This is what I call it LED technology (Pics inside) | Power_Getter | Electrical & Lighting | 24 | 04-01-2008 11:26 AM |
| what do i do when my spoiler LED is out? | STi-Nismo Dood | Southern California Impreza Club Forum -- SCIC | 4 | 03-30-2004 07:04 PM |
| Safer Lighting....LED? Quartz Conversion? What? | funscooby | General Community | 1 | 01-09-2002 08:12 AM |
| whats with the led lights on the hood? | Keirik | Interior & Exterior Modification | 15 | 09-24-2001 06:17 PM |
