Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-10-2008, 09:48 PM   #1
ggixxer599
Member#: 126991
2013 Impreza STI
Default Trunk Light Trouble?
My trunk light will not turn on? I have checked fuses but none of them are specific to the trunk light? does anyone have any suggestions on what might be wrong?
ggixxer599 is offline   Reply With Quote
Old 05-10-2008, 10:32 PM   #2
subaru3169
Member#: 55252
* pullup bar *
have you looked at the bulb??
subaru3169 is offline   Reply With Quote
Old 05-10-2008, 11:05 PM   #3
ggixxer599
Member#: 126991
2013 Impreza STI
yeah i have looked at the bulb and i have even bought a new one. im stumped
Old 05-11-2008, 03:50 AM   #4
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Do you own/know how to use a multimeter? Invaluable tool to have...
Micky is offline   Reply With Quote
Old 05-11-2008, 04:52 AM   #5
ggixxer599
Member#: 126991
2013 Impreza STI
i do not own one but i should pick one up.? good point.
Old 05-11-2008, 04:53 AM   #6
subaru3169
Member#: 55252
* pullup bar *
ya it'd be a good idea to have one
Old 05-21-2008, 05:02 AM   #7
marrenr813
Member#: 135668
2015 WRX
Did you fix it?
marrenr813 is offline   Reply With Quote
Old 06-01-2008, 03:44 PM   #8
04ImprezaWRX
Member#: 120237
2004 WRX
Same problem here what fuse is the trunk light on? I checked the bulb and its deffinately not blown.
04ImprezaWRX is offline   Reply With Quote
Old 06-01-2008, 03:57 PM   #9
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
It looks like fuse #2 supplies power to the light for the '04 model at least.
Old 06-06-2008, 03:43 PM   #10
zen_nation
Member#: 181267
i had my sti since it came out in 03 and the trunk light die in 05 someone please help us.
zen_nation is offline   Reply With Quote
Old 06-07-2008, 04:00 PM   #11
zen_nation
Member#: 181267
so i check the bulb and its good. i disconected the plug from in the back of the light bulb and check it out and repluged it. checked fuse #2 its all good. but still no working trunk light! wtf!
Old 06-07-2008, 11:06 PM   #12
Cougar4
Member#: 53443
Winestone
You need to get a test light probe and start checking where power is getting to.
Old 06-09-2008, 05:39 PM   #13
rhocking1
Member#: 132472
2007 STi
CGM
You might also want to check whether the switch (on my 07 it is next to the latch) is not stuck.
rhocking1 is offline   Reply With Quote
Old 06-10-2008, 04:43 PM   #14
zen_nation
Member#: 181267
ok so i checked the switch next to the latch and it move freely. i checked the wires with the test light its all good. checked the bulb again it looks fine but i think i am going to get a new bulb today. dose any know the part number fo the trunk light bulb?
Old 06-12-2008, 01:19 PM   #15
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I know my trunk striker switch sticks often...
There might be a problem with it making contact at the striker to... all it is, is a ground.. I would look at the striker closer..
Old 06-18-2008, 04:14 AM   #16
zen_nation
Member#: 181267
ok i looked at a brand new one at work and broked it and then i hitting the stricker and yep it works. i came home and i and to push the power wire around and played with the stricker and what do you know it works. dam man your good. when i get more time i am gonna open it up and tighten things up a bit.
Light trouble Vostok 7 Electrical & Lighting 3 05-18-2004 11:19 AM
anyone have shift light troubles on 03? it8ezbngrn Electrical & Lighting 0 05-05-2004 11:10 PM
Sti shift light trouble wrxxed Electrical & Lighting 5 02-10-2004 05:53 PM
Check Engine Light Troubles HezWrx Service & Maintenance 5 03-28-2003 05:43 AM
break light trouble shooting ScoobyJoe Service & Maintenance 1 11-13-2002 02:31 AM
