Old 05-11-2008, 08:36 PM   #1
hypoxvi
Member#: 173002
Default STi oil pump vs. WRX oil pump
Are they the same? what are advantages to using the STi oil pump in the 2.0L motor?
hypoxvi is offline   Reply With Quote
Old 05-11-2008, 09:47 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
AFAIK there is no difference between the sti and wrx, but there are differences in model years and what was used. Search in the built motor forum as there is a thread about which pump provides more volume vs pressure.
Tony
Old 05-11-2008, 09:54 PM   #3
MrSlowbaru
Member#: 129231
2005 wrx
cgm
08 sti has a larger oil pump
MrSlowbaru is offline   Reply With Quote
Old 05-11-2008, 11:20 PM   #4
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
The WRX and STI use the same oil pump (10mm FWIW) until 2008 when the STI got an 11mm pump. If you are still using your stock motor, I would say to just stick with the OEM pump. If you are going to build it up, or plan on making substantially more power than stock, then it might be worth upgrading your pump.
Of course, before that, you would want to make sure that you are using a good quality oil (lots of discussion on that)...
Good luck with your project.
J. Cooley
Flatirons Tuning Project Car
Flatirons Tuning F.A.Q. Blog
Flatirons Rally Team Blog
FlatironsTuning.com is offline   Reply With Quote
Old 05-11-2008, 11:41 PM   #5
hypoxvi
Member#: 173002
would i benefit from using the 12mm jdm pump? my horsepower goals are under 300whp. I am more concerned about longevity as i am replacing the short block due to a spun bearing.
Old 06-03-2009, 10:01 PM   #6
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
Default 12mm oil pump beneficial?
Old thread I know but it had the question I was about to ask but no one had responded to it. Would a 12mm oil pump on a 2.0 provide extra protection against a spun bearing?
JoeTX is offline   Reply With Quote
Old 06-03-2009, 10:55 PM   #7
wheatpaste
Member#: 170747
2004 WRX Wagon
No, not necessarily. In fact, having too much oil pressure can be problematic as well. As others stated, there is a lot of discussion about this in the built motor forum. I would do a lot of research in there.
From what I've gathered (and this is very very summarized):
-10mm is fine in stock form for most 2.0L applications
-Shimmed 10mm for built 2.0L and hybrids w/increased bearing clearances and no AVCS
-11mm for built 2.5L w/single AVCS
-12mm for double AVCS and/or motors with piston squirters
wheatpaste is offline   Reply With Quote
Old 06-03-2009, 11:48 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I will be running my 12mm pump. My engine setup consists of intake AVCS, oil squirters, and larger clearance rod bearing with the double cross drilled crank.
Until someone runs into an issue running a 12mm oil pump, I don't see a problem using it.
FuJi K is offline   Reply With Quote
Old 06-04-2009, 12:17 PM   #9
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
I'm running an shimmed 11mm pump on my hybrid with large bearing clearances
slowmike is offline   Reply With Quote
Old 06-04-2009, 01:44 PM   #10
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
Originally Posted by wheatpaste View Post
...there is a lot of discussion about this in the built motor forum. I would do a lot of research in there.
I didn't check there. Thanks.
sti fuel pump vs. wrx pump vtboost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-03-2007 11:23 PM
Sti vs Wrx fuel pump numbers brandonbeeb Newbies & FAQs 3 09-06-2007 12:00 PM
STi vs WRX fuel pump subyguy04 Newbies & FAQs 0 10-09-2006 04:12 PM
STi fuel pump vs. WRX fuel pump WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-02-2005 08:05 PM
Variable WRX fuel pump vs basic Impreza pump? bryan_johnson Subaru Conversions 13 01-31-2005 10:24 AM
