Alaskan Impreza Club
Old 05-12-2008, 01:48 AM   #1
prometheum
Member#: 92003
04 bicycle!
Post hey jerry! whats this noise coming from my car?
http://video.google.com/videoplay?do...47163197497751
the engine is not running; you can feel it through the fuel hoses especially in that little round black thingy connected to the fuel hose next to the fuel filter
throws a p0183 code
it won't start anytime it makes that noise and i have to cycle the key from acc to on a few times to get it to quit
prometheum is offline   Reply With Quote
Old 05-12-2008, 10:19 AM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
I don't know what the noise is but the code is for fuel temp sensor "A" circuit high input. So maybe there is something wrong with the valve?
Mavrik is offline   Reply With Quote
Old 05-12-2008, 11:15 AM   #3
prometheum
Member#: 92003
04 bicycle!
what valve are we talking about?
also does this
http://forums.nasioc.com/forums/show....php?t=1510538
and might be unrelated but a lot of the times when i my turn signal disengages (like just finished making a turn and turn signal is no longer going off) the headlights turn off for a split second...sounds like a headlight relay? related? i don't know
Old 05-12-2008, 11:15 AM   #4
prometheum
Member#: 92003
04 bicycle!
also swapped out fuel pumps last night...didn't fix it
Old 05-12-2008, 03:53 PM   #5
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
also does this
my does the same thing and more so on left turns than right, i have know idea what is causing it but if some does please let us know,
bump for funny noise in fuel area. did you check wires and plugs near sensors.
Alaskan EJ20 is offline   Reply With Quote
Old 05-12-2008, 05:07 PM   #6
prometheum
Member#: 92003
04 bicycle!
does it do hte funny fuel thing too?
the headlights seem especially bad whenever i've got my high beams on. i brought it into the dealership over a year ago for the stalling problem and they fixed it by repairing a ground point on the UTEC and it no kidding fixed the problem all the way up until now...i don't have a utec anymore though...
Old 05-13-2008, 04:29 PM   #7
AK SloPok
Member#: 56464
12 Ram
Sure sounds like the self test when the green connectors are put together and it cycles through self tests. Perhaps evaporative system? Check the fuel cap (simple) and perhaps the evaporative canister near the rear tire?
AK SloPok is offline   Reply With Quote
Old 05-13-2008, 11:20 PM   #8
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
So heres some ideas from maddog:
1. Joint ground connector next to the ECU may be corroded.
2. Main relay(Brown) next to the passenger kick panel. Bad connection?
3. Green diagnostic connectors might have shorted to ground.
4. Ecu connector loose, or junk ECU.
Was the key on when it made that noise?
Have fun!
Arctic Assassian is offline   Reply With Quote
Old 05-14-2008, 07:17 PM   #9
prometheum
Member#: 92003
04 bicycle!
Have fun!
thanks for the input
Old 05-15-2008, 12:09 PM   #10
prometheum
Member#: 92003
04 bicycle!
k i think i found the problem...i think its a bad main relay thanks!
Old 05-16-2008, 11:14 AM   #11
Arctic Assassian
Member#: 91875
91 legacy TD04
I'm sure if you bought him lunch, he'd be stoked.
Old 05-16-2008, 06:01 PM   #12
prometheum
Member#: 92003
04 bicycle!
i kind of live on the opposite side of the continent
Old 05-17-2008, 11:09 PM   #13
prometheum
Member#: 92003
04 bicycle!
ok got the parts in today, but the car hasn't been doing it for the past 75 miles or so, but i installed the new fuel pump relay and main relay now i am too scared to get on the throttle because with my luck those 2 parts weren't causing the problem and the second i hit WOT at redline the fuel pump will do its crazy thing again
also i but the walbro back in and disconnected the fuel pump and started the motor it ran for a good minute...wtf? when i disconnected the fuel line there was still quite a bit of pressure in it. wtf?
Old 05-19-2008, 09:49 PM   #14
Arctic Assassian
Member#: 91875
91 legacy TD04
Walbro's have a cooldown time if I'm not mistaken.
Weird Moaning noise coming from my front right axle area...? Flyin_Hayn Transmission (AT/MT) & Driveline 2 06-05-2010 02:50 PM
whats that noise coming from my car...video inside prometheum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-12-2008 05:55 PM
SO there was this bad gridning noise coming from my brakes (HELP!) kaisersouse Brakes, Steering & Suspension 25 06-15-2006 11:14 AM
Oh no, what is this smell coming from the car? ImprezedRS South East Region Forum 7 09-04-2001 02:15 PM
What is this noise comming from my clutch? ABS issues too... IMPREZAmike Normally Aspirated Powertrain 3 03-01-2001 04:25 PM
