Old 05-12-2008, 09:04 AM   #1
EnforcerPSU
Member#: 76849
2011 WRX
Rally Blue
Default 100K maintenance - Timing belt necessary?
Honest question.
The dealer is trying to sell me on the standard 100K maintenance which includes a timing belt change. It costs approx $450 dollars for my 2005 WRX, just for the timing belt.
Is this a smart thing to do or is the dealership just trying to sell me something I don't need? Just need to know so I can make an educated decision.
Thanks!
EnforcerPSU is offline   Reply With Quote
Old 05-12-2008, 09:40 AM   #2
sorrowfulkiller
Member#: 170439
I <3 Lamp
tell them to go **** themselves and see what other people will charge you
sorrowfulkiller is offline   Reply With Quote
Old 05-12-2008, 09:58 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
are you asking if you need the timing belt, or if that charge is normal. yes you need it, if you break the timing belt you buy a new engine. (recommended interval is 105k miles) The price is high but not actually too bad for a dealership charge. There is a fair amount of work involved with the timing belt. You might be able to find it $100 or $150 lower if you shop around, but it won't be drastically cheaper.
Old 05-12-2008, 11:25 AM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
well is "insurance".
if a indepent shop did the work, would there be any warranty?
also timing belt install requires subaru specific tools.
450 is alot cheaper than 3000 for motor.
Old 05-12-2008, 11:36 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
I don't know how well subaru belts go over mileage, but I've had previous (non-interference!) engines that would reliably break the timing belt within 1000 to 2000 miles of the interval! Kind of scary how accurate it was actually.
Old 05-12-2008, 12:11 PM   #6
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
You prolly owned a dsm
Rexwagon03 is offline   Reply With Quote
Old 05-12-2008, 01:43 PM   #7
Strider327
Member#: 131280
2004 Impreza WRX
I would just buy the parts from the dealer and go elsewhere to get it changed, or do it myself. Just to let you know though, it is a pain to get to. You gotta remove the timing belt cover a lot of other things. Good Luck, whichever choice you choose.
Strider327 is offline   Reply With Quote
Old 05-12-2008, 01:47 PM   #8
PolarisSnT
Member#: 85905
2004 WRX
Find a Subaru specific shop, heck even make the drive to Precision Tuning in NJ. There are no 'Subaru specific' tools needed, just basic stuff to get the job done. $450 for just the belt may not be so bad but how much are they going to charge you for the water pump, t-stat, gaskets, etc?
PolarisSnT is offline   Reply With Quote
Old 05-12-2008, 01:59 PM   #9
awd-turbo
Member#: 167551
02 wrx
i need to do mine...how hard is it to do urself on this car?? the diy looked pretty simple.. i know u need to do belt and water pump and water pump gasket.. anything else need ot be done
awd-turbo is offline   Reply With Quote
Old 05-12-2008, 02:04 PM   #10
sorrowfulkiller
Member#: 170439
I <3 Lamp
get an sti timing belt... it may last longer overall
Old 05-12-2008, 02:05 PM   #11
rkramer
Member#: 118209
2015 WRX Limitec
ford actually
Old 05-12-2008, 02:30 PM   #12
DirtstyleWRX
Member#: 18212
For reference, the timing belt and tensioner alone are around $210 on subarugenuineparts.com.
DirtstyleWRX is offline   Reply With Quote
Old 05-12-2008, 02:31 PM   #13
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
ford actually
no surprise here.
rexman2002 is offline   Reply With Quote
Old 05-12-2008, 07:12 PM   #14
Yakshii
Member#: 166500
'01 RHD Evo 7,
92 Skyline GTR
is there any signs at all to be seen when to change the timing belt
im not sure if the last owner did it on time. i have high mileage
Yakshii is offline   Reply With Quote
Old 05-12-2008, 07:42 PM   #15
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I had the belt done else where with a PE belt. Yet I would get the official subaru list.
Old 05-12-2008, 08:14 PM   #16
EnforcerPSU
Member#: 76849
2011 WRX
Rally Blue
Thanks everyone. I think I am going to shop around for a couple weeks and see what I can find.
Old 05-13-2008, 05:03 PM   #17
leecea
Member#: 37359
2003 WRX
In my opinion, it will be very hard (or maybe impossible) to tell if it has been changed, and there are no warning signs to let you know it's about to break.
leecea is offline   Reply With Quote
Old 05-14-2008, 10:25 AM   #18
strohausii
Member#: 26770
'02 WRX
midnight black
Well, afterall it is a belt; although, a toothed "precision" belt. If the timing belt cover is removed, you could inspect it for the classic rubber belt signs of impending failure as in cracks in the rubber. IMHO, considering the price you will pay if that belt breaks, the risk of just ignoring it is just too high.
Chances are good that if replaced by the dealer, they will check out the idlers and determine if they need replacing too.
strohausii is offline   Reply With Quote
Old 05-15-2008, 10:00 AM   #19
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Originally Posted by EnforcerPSU View Post
Honest question.
Thanks!
There is no "standard 100K maintenance." Minor service intervals are every 15k, major service intervals are every 30k. You should be following what it says in your owners manual, not what the dealer tries to sell you. That said, IIRC the timing belt should be done every 105k so yes it is about due.
Mike Wevrick is offline   Reply With Quote
Old 05-15-2008, 04:56 PM   #20
wrxwhite
Member#: 28632
2011 Legacy 3.6R
Dark grey metallic
Also you may want to think about replacing the water pump. It's driven by the timing belt and unless replaced previously, the bearings and seals in it have 100k on them.
wrxwhite is offline   Reply With Quote
Old 05-15-2008, 05:32 PM   #21
RoadTrippin
Member#: 161175
Better safe than sorry. I would consider getting the water pump done while you are at it since it is in that area.
I just had mine done last week. Had the belt, water pump, oil pump, tensioner and one idler replaced as the bearings in the tensioner and idler were going and the water pump and oil pump was leaking. All in all spent a fair amount but am glad it is taken care of....peace of mind is cheaper than a new engine.
RoadTrippin is offline   Reply With Quote
Old 05-15-2008, 07:21 PM   #22
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
you might as well change the t-stat as well.
Bishop is offline   Reply With Quote
Heading towards 100k miles - things I should check/replace while I do timing belt Back Road Runner Service & Maintenance 3 07-12-2009 08:48 AM
Gas mileage lower AFTER 90K maintenance and timing belt change TheRedWRX Service & Maintenance 9 08-14-2008 04:49 PM
can anyone recommend a shop for CV maintenance/timing belt replacement? 280hp_REX Mid Atlantic Impreza Club -- MAIC 5 03-07-2008 10:23 AM
timing belt maintenance how much? dvang Mid West Subaru Owners Club Forum -- MWSOC 3 07-06-2005 08:14 PM
Timing belt change interval 60k or 100k ? il96 Normally Aspirated Powertrain 7 10-06-2003 03:51 PM
