Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-12-2008, 02:48 PM   #1
02blueru
Member#: 80012
04 BMW M3
Ducati 620 Dark / 08' 848
Default Engine part identification help...
Sorry if this sounds very noobish but recently my car has started making this constant low pitched "whining" noise that isn't rpm dependent and it is coming from the front of the engine. Its also emitting a slight burning smell at times.
I've isolated the noise to the round pump on the right of the alternator but I'm not sure exactly which pump it is. My guess is that its the PS pump but like I said I'm not sure. Also, I'm not sure if it is a bad bearing or is actually the pump going bad and if it is the power steering pump, where do I check to see if there is enough fluid in the reservoir? Many thanks
02blueru is offline   Reply With Quote
Old 05-12-2008, 02:52 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
The accessory on the drivers side of the alternator is the AC compressor. On the passanger side is the Power Steering pump.
To check the fluid level in the PS system, check the tank mounted next to the PS pump on the inner fender. You should be able to trace the hose from the pump to the tank.
J
jeffg is offline   Reply With Quote
Old 05-12-2008, 03:03 PM   #3
02blueru
Member#: 80012
04 BMW M3
Thanks for the quick reply
Making list for new engine parts need help Richbmxer87 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-04-2009 09:59 PM
Part Identification Help STiRA-435 Brakes, Steering & Suspension 2 05-25-2009 09:16 AM
Help with part identification atlblu General Community 1 07-06-2008 10:34 AM
Part identification help needed Trin_Starr Legacy Forum 4 03-28-2006 10:23 AM
Part Identification Help stimpy Subaru Conversions 16 08-24-2003 04:00 PM
