Old 05-13-2008, 02:02 AM   #1
imprexaRS03
Member#: 145883
2008 wrx
psm
Default splicing headlight wires for hid install
so i got some hids that are for an 06 /07.How would i splice the wires together.What wires go to what wires.Thanks!
imprexaRS03 is offline   Reply With Quote
Old 05-13-2008, 02:44 AM   #2
Handsdown
Member#: 29355
1. read the HID faq
2. the vehicle in your profile is an 03 RS, is this correct? is it running 03 headlights or 06/07 headlights?
3. you shouldn't splice any wires, you should use a relay harness that uses stock connectors. if you decide not to, it depends on the answer to number 2.
no one can help you until you give us more information... and when you do most people will tell you to do a real retrofit with hid projectors to give proper cutoff and even beam.
most people including me.
Handsdown is offline   Reply With Quote
Old 05-13-2008, 07:45 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
And to clarify the above response a bit further, if you do in fact have an 03 and you got HIDs for an 06/07, they will NOT WORK. In that case, return or sell them.
Old 05-13-2008, 02:40 PM   #4
imprexaRS03
Member#: 145883
2008 wrx
psm
yea thats what im going to do.thanks guys
fs: one bmw headlight (great for hid retrofit) paulmofyourhand Exterior/Styling 1 10-20-2006 06:05 PM
Help finding speed sensor wire for Nav install dkowasic Baja Forum 2 08-26-2005 12:17 AM
Help: where to hook up wires for gauge install on 05 STI xS2k Electrical & Lighting 1 08-11-2005 05:31 PM
Can't locate Ignition Wires for TT Install unwrittenlaw Newbies & FAQs 5 06-15-2004 07:14 PM
Which wires for indiglo install? Bighurt1 Interior & Exterior Modification 1 04-11-2002 09:31 PM
