Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Closed Thread
Old 05-13-2008, 03:19 AM   #1
DS1
Vendor
Member#: 111780
Default MFactory Gear set
I've recieved a lot of questions about the MFactory close ratio gear set lately so I figured I would try to answer them here.
Please feel free to post all your questions here but try to keep it on the topic of this set. (no comments on other ratios, other brands, etc please )
Ratios:
1st - 3.27
2nd - 2.286
3rd - 1.667
4th - 1.238
5th - 0.958
They are available in a 1-5 and 1-4 set to use a stock 5th gear.
1-5 Set - $2549
1-4 Set - $2299
If you would like to calculate your top speed per gear for your tire size and redline you can do so here:
http://teammfactory.com/gearcalculat...=0&trannytype=
Fittment:
We've installed quite a few sets of these over the past few months and have been very happy with the quality of fittment of them.
Use:
This set is designed for for fast road / Auto-X / Road Race use.
They are a semi-helical design good for around 350ft/lbs (maximum we have tested so far).
Noise and Shifting:
There is a noticeable increase in gear whine, I would estimate at maybe a 10% increase in noise.
Shifting remains smooth and unchanged.
Professional thoughts:
It's nice to finally have an option between RA and PPG gears for those of us who don't need a $4600 gear set. Yes these gears are shorter than stock but the increase in acceleration will put a smile on your face (especially you RS guys ).
I will try and have the owners of the sets chime in with their own reviews here too.
Dylan @ DS1 Motorsports
Authorized MFactory Installer
DS1 is offline
Old 05-13-2008, 01:33 PM   #2
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
I have a set waiting to go in this week, so I will chime in shortly with my feedback.
zeropsi is offline
Old 05-13-2008, 02:33 PM   #3
bboylocob
Member#: 151809
2007 WRX
these ratios are really not bad for us 06-07 guys with the 3.70fd.
im more of a road course guy so i personally like this set.
bboylocob is offline
Old 05-13-2008, 02:40 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I forgot about ya'lls final drive...yeah, they would be great with that. They would be a terror on a 4.444 set-up though. You'd be shifting like a Gixxer on that set-up!
Unabomber is offline
Old 05-13-2008, 02:47 PM   #5
DS1
Vendor
Member#: 111780
On the 4:11 final in the RS they make a huge difference.
We're putting them behind our H6 with a 4:44 final drive later this week
-Dylan @ DS1
DS1 is offline
Old 05-13-2008, 04:28 PM   #6
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
How much are we looking at for the install?
2gnt2wrx is offline
Old 05-13-2008, 04:39 PM   #7
DS1
Vendor
Member#: 111780
^^ in or out of the car?
DS1 is offline
Old 05-13-2008, 04:48 PM   #8
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
Both.
moosecakes is offline
Old 05-13-2008, 05:22 PM   #9
DS1
Vendor
Member#: 111780
Out of the car is $275 + parts
In the car is $675 + parts (no additional labor cost for clutch replacement while trans is out)
-Dylan @ DS1
DS1 is offline
Old 05-13-2008, 06:08 PM   #10
wrxjrk
Member#: 164093
what is the issue with having to shave the 2nd gear?
I will be having a tec at subaru install them if i decide to get them.
wrxjrk is offline
Old 05-13-2008, 07:18 PM   #11
DS1
Vendor
Member#: 111780
I have not had the same issue that Andrewtech did with 2nd gear in any of our installs, I believe their's was an early test set so that may have been the issue.
-Dylan @ DS1
DS1 is offline
Old 05-13-2008, 08:04 PM   #12
06wrxlbart
Member#: 154013
2012 S4
Monsoon Grey
DS1 Motorsports can you measure each gear ? in mm or inches ? plus count teeth on each gear thank you.
06wrxlbart is offline
Old 05-13-2008, 08:15 PM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
how much total installed?
txl146 is offline
Old 05-13-2008, 08:31 PM   #14
DS1
Vendor
Member#: 111780
06wrxlbart- What would you like measured?
txl146- prices are listed above
-Dylan @ DS1
DS1 is offline
Old 05-13-2008, 09:51 PM   #15
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I mean... what's the price of gear sets.
txl146 is offline
Old 05-13-2008, 10:50 PM   #16
06wrxlbart
Member#: 154013
2012 S4
Monsoon Grey
Hello DS1 , I'm hoping you can measure thickness of each gear , and count the teeth on each gear. I want to see if these are stronger than my APS gearset because I am upgrading to a 20g 8cm + mass other loads of **** and the APS are rated very low 325tq. Let me know please thank you.
Gearset measurments:
1st gear : 17mm wide , teeth count : 38 ratio: 3.45
2nd gear : 14-15mm wide , teeth count : 35 ratio: 1.94
3rd gear : 15mm wide , teeth count : 31 ratio: 1.36
4th gear : 16mm wide , teeth count : 26 ratio: .96
5th gear : 16mm wide , teeth count : 27 ratio: .96
I converted inches into MM. This is what I came up with my APS gearset.
Old 05-14-2008, 05:32 AM   #17
crisco3
Member#: 163526
I know this is a noob question and sort of off-topic, but would I run into any problems installing a 06-07 3.70fd into a 2004 WRX?
I like this gearset option, but I am not crazy about the calculated 139mph top speed.
crisco3 is offline
Old 05-14-2008, 06:03 AM   #18
wopgenius
Member#: 153855
2008 Hyundai Elantra
if one installed theses gears, would it make the the driving better as opposed to the POS stock trans?
wopgenius is offline
Old 05-14-2008, 09:29 AM   #19
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
will you recommend this gears for a 30R?
juanmedina is offline
Old 05-14-2008, 10:33 AM   #20
DS1
Vendor
Member#: 111780
txl146- Original post updated with pricing
06wrxlbart- The width of the gear doesn't determine strength, it's the material, tooth profile, ratios and processing of the metal that make all the difference (aka why 04' gears are no stronger than 02' gears )
Crisco3- The final drive swap isn't hard but involves a lot of parts. 139mph is a little faster than most need to go
wopgenius- I much prefer these over stock gears. What about the stock trans don't you like? There are many of the issues that can be fixed without a gear set.
juanmedina- A 30R is capable of making quite a bit of power, it would depend on your driving style and how much power you put down.
-Dylan @ DS1
DS1 is offline
Old 05-14-2008, 11:05 AM   #21
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
QUESTIONS:
Car 07 WRX
1- How will this effect hwy driving if I do the MF 1-4 with OEM 5?
2- effects on gas mileage?
3- I have no idea if its an option or a good idea, but what about 1-3 and OEM 4/5. Possible? If so, at what price?
I worry about the short top gears because while my car is a DD and mostly autocross, there is an event twice a year where my car sees 150+ mph. I dont want to completely ruin that aspect.
thanks
Shawn
lackofhp is offline
Old 05-14-2008, 11:27 AM   #22
DS1
Vendor
Member#: 111780
^^ 150mph+ holy carp!
1- If you keep the stock 5th there will be no difference at highway speeds.
2- Gas milage around town may go down slightly, on the highway there will be no loss
3- We can only do 1-4 or 1-5, sorry
-Dylan @ DS1
DS1 is offline
Old 05-14-2008, 11:33 AM   #23
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
-Dylan @ DS1
Thanks for the info.
Here is the event I was talking about. Standing mile. start from a start and you have one mile to go as fast as you can. the very last few hundred yards your top speed is measured.
www.texasmile.com
there are a few subbies hitting 170+ and my friends 42r build is going for 200+ in october.
HIGHLIGHTS FROM MARCH 2008 TEXAS MILE
**** 151 Entrants
**** 721 Runs
**** 22 Entrants Make the 200+ MPH Club for the March 2008 Event
**** New Overall Top Speed Record Set by Team Dewitt in their Jet Car
Unlimited Race Car Power Adder Extreme (URCPA): 324.967 MPH
**** Fastest Overall LSR Motorcycle Rider for the event – Charlie Anstaett
on his 2004 Black & Purple Suzuki Hayabusa: 240.192 MPH
**** Fastest Overall Street Motorcycles with Power Adders at the event
Terry Kizer (Mr. Turbo) @ 237.894 MPH & Tom Gates @ 237.398 MPH
**** Fastest Overall Unlimited Street Car Power Adder & New USCPA Record
Sriyantha Weerasuria in his 1995 Toyota Supra Turbo @ 229.670
**** Most Event Runs made by Benjamin Beckert: 19 Runs
type in texas mile in youtube and be amazed
lackofhp is offline
Old 05-14-2008, 11:37 AM   #24
DS1
Vendor
Member#: 111780
^^ wow now that sounds like fun
DS1 is offline
Old 05-14-2008, 01:04 PM   #25
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
I did some calculations
MF Gear 1-4 OEM 5 (red)
07 WRX OEM (Blue)
http://www.teammfactory.com/gearcalc...ission+1+and+2
Formatting on forums arent my specialty but here is an Excel I made. The "Redline Shift to RPM" is how i am describing where you land when you redline the gear before. Also those are estimates I made by looking at the chart that I made on MF's site.
HTML Code:
Type	Gear	Redline Shift to RPM	Ratio	Top MPH
MF	1	0	3.270	38
MF	2	4,500	2.286	55
MF	3	4,500	1.667	75
MF	4	4,500	1.238	101
OEM	5	3,500	0.738	170
OEM	1	0	3.454	36
OEM	2	3,500	1.947	65
OEM	3	4,500	1.366	92
OEM	4	4,500	0.972	129
OEM	5	4,500	0.738	170
lackofhp is offline
Closed Thread
MFactory Gear sets and front LSD's just in time for spring!! DS1 Drivetrain 23 05-10-2009 12:56 PM
mfactory gear set wrx115 Transmission (AT/MT) & Driveline 15 05-09-2009 02:59 PM
MFactory Gears-2nd gear noise bcristea Transmission (AT/MT) & Driveline 6 10-05-2008 03:37 PM
mFactory gear set wrxjrk Texas Impreza Club Forum -- TXIC 37 05-15-2008 05:57 PM
Anyone here running MFactory gears? blitzmr2 Transmission (AT/MT) & Driveline 10 05-13-2008 04:09 AM
