Old 05-18-2008, 03:06 PM   #51
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Originally Posted by sluflyer06 View Post
I don't agree with that statement completely...stock tmic..no. GOOD (Turboxs or Spearco) yes.
Maybe with the Spearco. The TXS TMIC is a Chinese made POS. I have helped three different friends build cars with TXS TMICs and all three have had issues such as pinholes in welds, warped flanges, etc.
dexterous is offline   Reply With Quote
Old 05-18-2008, 03:13 PM   #52
Davenow
Member#: 23676
Originally Posted by MumblinAviator View Post
I've heard that many times during my search, and I realize this type of work gets very addictive, but going much bigger than that will eventually require internals which is going much deeper than I want to go. Not only that, but going larger than the 20g/equivalent will probably increase lag a bit which is getting away from what I'd like.
I appreciate the responses!
(this is in reference to the post which you responded to here)
that is exactly why I didnt bother with the GT30R for my setup. I bought the 30R, but then before I put it in, I read for the 50th time that most GT30r people want a 35R within 2 weeks.
SO I said screw it and go the 35R.
I will tell you this much
Blouch TD05-20G 8cm
TurboXS TMIC
Meth injection
tuned to 22PSI
Gruppe-s header
aps 65mm cai
44mm EWG
catless tbe (I am defiant autospeed, look at my setup above)
I got bored with the power. And making it a TD06 and adding a FMIC wouldnt have been nearly enough.
With the fact that greens are laggy IMHO, and dont make that much more than a well set up 20G, it wouldnt have been enough either. Rotated was the only choice that would give me enough to make me happy.
Combine the FMIC, GT35R, EWG, Meth and $3000 worth of headwork that is going into the car, which will put down closer to 500whp on 93 pump+meth, I should be satisfied for a few months
Old 05-18-2008, 03:14 PM   #53
Davenow
Member#: 23676
BTW, for the record, any 20G car making 400whp or more without headwork or meth, got those results from a high reading dyno.
With meth, a 20G can hit 400whp, but it still takes a semi optimistic dyno.
Old 05-18-2008, 03:57 PM   #54
MumblinAviator
Member#: 143327
04 STi
JBP
I agree completely. This thread has done a great job showing the ranges of power one could acheive with each setup AND the type of dyno. Most seemed to be in the 350-390 range.
RE: GT35R - the idea of 500whp on this car scares the outta me, as well as spending that sort of money on getting there.
That's the majority of my problem at the moment. I'm sure I can save and safely spend enough to support a 20g with meth down the road and I believe that'll keep me happy for quite some time. I know that I CANNOT spend enough (right now) to support a rotated kit or equivalent.
MumblinAviator is offline   Reply With Quote
Old 05-18-2008, 04:09 PM   #55
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
I've read extensively about your experience with 18G's and 20G's, and it has greatly helped to shape my view so far and encouraged me to do more successful research.
That said, what is your opinion on the FP Green and Dom 3?
zeropsi is offline   Reply With Quote
Old 05-18-2008, 04:21 PM   #56
RyeLou
Member#: 179113
05 Evo
Originally Posted by zer0psi View Post
Intercooler?
As of right now I plan on leaving the stock STi TMIC in place. I just got the car, and my plan is to not go with everything all at once. I'll use what I've already planned on for the rest of this year, then next spring change around a few more things. No need to do everything within weeks of getting the car...I would be bored with it too soon and I don't want to have to build the engine. With my current build plans it still gives me room to grow without changing turbos (again) yet.
I'm not trying to be the fastest or the highest HP. I want a fun and quick daily driver with good spool and a safe tune. That's what my list is based off of...not beating any of you. All of you should be proud of your numbers, but I probably won't even bother posting mine when I get them...they don't mean too much to me.
RyeLou is offline   Reply With Quote
Old 05-18-2008, 04:22 PM   #57
MumblinAviator
Member#: 143327
04 STi
JBP
Originally Posted by dexterous View Post
Many people actually think that the DOM 3 spools FASTER than most TD06H 20G turbos. I have a friend who is building a car identical to my car except that he has a DOM3. He is getting tuned by the same person on the same dyno so it should be very interesting. I will post the results in a month or so.
That'd be a fantastic side by side comparison! Don't forget about me or the thread when it happens
So you're trying to tell me that 401/365 wasn't enough for you HaHaa let's face it... it's a neverending quest for more speed that is only rivaled by the amount of dollar-dollar-bills needed.
Old 05-18-2008, 04:25 PM   #58
RyeLou
Member#: 179113
05 Evo
Why limit yourself to an off the shelf turbo? Call one of the vendors on here or call around your area and find someone who builds them. I have a friend who does just that and I'm going through him. It's an FP Green based turbo, but it will spool slightly quicker and make more power up top. Not a lot...but noticeable if you were to drive mine after a similarly modified regular FP green car.
Old 05-18-2008, 04:27 PM   #59
MumblinAviator
Member#: 143327
04 STi
JBP
Welcome to the thread...
You basically repeated everything that's been circling around my head for the past few months. Numbers are a great benchmark that might give someone an idea as to what the car would feel like or how it would perform, but the ultimate test is your own personal Butt-Dyno, and how big of a smile you have after WOT. If someone is happy with a 145hp front wheel drive, fantastic. I won't be the one to try and squash their fun... which is of course, what this is all about.
With that said, post your numbers anyway!
Old 05-18-2008, 04:34 PM   #60
RyeLou
Member#: 179113
05 Evo
We'll see. I'll probably post them at some point, but the only comparison I would care to make or even hear about is from someone on the same dyno round here. Other than that, you can really only get a handle on the range of power a certain turbo can make. The modified FP Green I'm going with will be perfect for me. Fast spool is what I'm looking for, and everything else follows. I go to the drag strip maybe 2 - 3 times a year, but I drive it every day to from work and any other road trips I do. I love having a car I can step on the gas and take off, regardless of who or what (if anything) is next to me.
And going to the STi from the SRT will be awesome come winter time
Old 05-18-2008, 04:43 PM   #61
zeropsi
Member#: 175453
AE86 GT-S coupe
If you don't mind my asking, what are the physical/mechanical differences in your turbo that cause the change in power/spool over an OTS (off the shelf) Green?
Old 05-18-2008, 07:50 PM   #62
RyeLou
Member#: 179113
05 Evo
I'll get the technical specs and post them once I do. I'll probably end up making a new thread about it, assuming it's fine with my friend.
For anyone local to me I always suggest people get their turbos from this guy. Certain manufacturers are a little more sensitive to allowing him to modify their "perfect" turbo, but in the end he hasn't ever ran into any major issues with it.
The turbo that went into my SRT was a Garrett 50 trim (almost exactly the same size as a GT3076) but journal bearing instead of dual ball bearing. He ported the housings of the turbo though and managed to fit the wheels from the S256 in it. It helped spool by a couple hundred RPM so it still spooled similar to the GT series turbos and also made it a little more efficient too.
Old 05-18-2008, 11:36 PM   #63
zeropsi
Member#: 175453
AE86 GT-S coupe
Sounds pretty B.A.
If he could improve on an HTA Green, I just might be interested.
Old 05-19-2008, 12:15 AM   #64
teg5
Member#: 163853
2011 STi Hatch
Does this friend of yours happen to have hair that looks similar to Whoopie Goldburg and have a red civic named "AKIRA." If so, I can't imagine buying a turbo from anyone else. I'm trying to talk him into going "off the beaten path" and design something different for my 05 STi. If you see him anytime soon, tell him Aaron says hello.
Back on topic, this thread highly interests me as I feel in the same boat. I want a little more power, but not enough to require new pistons in a month or two as my luck goes. 20G was what I'm thinking but the jury is still out for sure. Nice results from what I have seen so far, thanks guys.
teg5 is offline   Reply With Quote
Old 05-19-2008, 12:30 AM   #65
MumblinAviator
Member#: 143327
04 STi
JBP
Good! Glad this is helping someone else out... that was the point, after all.
20g sounds like it'll be my final result, but it'll come in stages:
Stage I
Cobb AP v2
Meth Injection
Tune
Stage II
20g (probably DB or Blouch)
Injectors
Tune
Stage III (If I'm not already dead or divorced)
Larger TMIC or FMIC
EWG/ EWG Uppipe
BOV?
Headers
Tune
I know what you're thinking.... if you do it all at once, you only need to get tuned once.
While some of us have the deep pockets to buy everything at once, I don't, and I also think building in stages will be more interesting and will allow me to draw out the fun a bit.
Old 05-19-2008, 12:38 AM   #66
MumblinAviator
Member#: 143327
04 STi
JBP
Afterthought:
Am I nuts to want to put Injection First? I can expect gains on a stock turbo, right?
Old 05-19-2008, 01:07 AM   #67
zeropsi
Member#: 175453
AE86 GT-S coupe
It'll give you gains no matter what.
I can just say that personally I'm a bit scared of it, as methanol is by nature a very corrosive substance. It's not to say it'll be damaging, but I'm super paranoid about keeping this car as perfect as possible.
Old 05-19-2008, 01:23 AM   #68
MumblinAviator
Member#: 143327
04 STi
JBP
I suppose that's a reasonable concern, although I haven't read up much on the negative side effects.
I have heard though that you can just run straight H2O... it may not net as much gain, but it'll help with your concerns.
Old 05-19-2008, 10:36 AM   #69
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
You will not need to do internals with a DOM III. Depending on the tune and the Driver, this turbo cangive VERY strong, consistant power that is also reliable. The 20G is a great Turbo, but I promise you will want more when it is all said and done. I have had my Dom III for about 2 months now and it is starting to feel slow. EVEN though yesterday I walked a 2002-2004 Z06 from a freeway roll, I still feel like more power would be great. My Dom III spools like a maniac, it is rare for a turbo this size to also have a 1st and 2nd gear.
The Dom III would cost another $500 on top of the 20G and it boasts an additional 8 lbs/min flow. The 20G is only 9 lbs/min flow over the stock VFxx turbo's. So if you look at it that way, you will be getting that much more headroom for power and you spool up just as quick. It makes me confused as to why the 20G is even considered anymore, but that is just my opinion.
Stames_wiltz is offline   Reply With Quote
Old 05-19-2008, 10:39 AM   #70
RyeLou
Member#: 179113
05 Evo
That would be him, I think. I know the red Civic used to his his wifes car and had a different plate...but I haven't seen that car in over a year. My only concern is it will take him a while to get me my turbo with all his traveling for work and being busy with law school. I'm going to give him a call later this week and let him know it's just about time.
Old 05-19-2008, 12:56 PM   #71
yohan04
Member#: 73003
- __ -
Here's the old set-up when I had the FP Green
2.4 FP Green 8cm
TXS FMIC
Nismo 740cc
Catless TBE
44mm Tial EWG
Perrin inlet
K&N Intake
GM boost solenoid
Tuned and dyno'd at Agile, netted 409whp/375tq on pump 93.
yohan04 is offline   Reply With Quote
Old 05-19-2008, 01:40 PM   #72
MumblinAviator
Member#: 143327
04 STi
JBP
Awesome results!
Stames - I think you might be convincing me...slowly but surely. Your assuredness about its spoolup time AND its potential top end are starting to sway my decision
Do you know anyone else on here with the Dom III? I'd like to talk to them as well, get some more opinions and setups, kinda like this thread.
Thanks!
Old 05-19-2008, 08:46 PM   #73
wuuusaa
Member#: 92894
2015 Wrx
^^^06rexwagon has a Dom 3 as well, his name is Cameron. He made like 420+whp on meth/pump iirc.
Old 05-19-2008, 10:34 PM   #74
MumblinAviator
Member#: 143327
04 STi
JBP
Awesome, ill have to look him up. I've found a few others since I've posted, too.
Anyone else reading that hasn't posted, keep bringin in the numbers!
Old 05-20-2008, 09:41 AM   #75
zeropsi
Member#: 175453
AE86 GT-S coupe
FWIW, in my research I'm liking the results of Deadbolt 20G's over the competition and might lean towards that direction.
WTB: 20g or fpgreen ultramagnus Private 'Wanted' Classifieds 4 09-08-2007 06:32 AM
Larger than stock turbo street setups on STi: state your mods and MPG please :) thomez Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-20-2006 12:39 AM
Deadbolt 20g VS FPgreen (dynosheet) TopSpeed Proven Power Bragging 153 06-08-2005 02:43 PM
Post your LE28's and CE28's pretty Please blinguskahn Tire & Wheel 0 02-09-2005 07:28 PM
Moving to NH/MA area, I need your help...pretty please with sugar on top? Sean New England Impreza Club Forum -- NESIC 30 12-05-2000 09:15 AM
