Old 05-13-2008, 02:23 PM   #1
evilwankel
Member#: 95124
Default Is there a write up for this?
I am curious if someone has a write-up for changing a fuel pump for a 96 legacy outback.
I'm sure it's pretty straight forward but I dont wanna drop the tank and forget to remove a line and bend it. Thanks
evilwankel is offline   Reply With Quote
Old 05-13-2008, 04:03 PM   #2
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
You don't have to drop the tank, it's right on top, accessible under the carpet in the storage area. This goes for the wagon and the sedan, sedan is more difficult to get to, because you're gonna need to get in the trunk for this one. and if you are tall, it sucks.
-Release fuel pressure, just open the gas cap, stick a long screwdriver to open the flap.
-There are two oval accessholes, take the one on the right off, and you can see your gas tank. The hole on the right is your fuel pump, one on the left is the fuel sending unit I believe....
-Unplug the harness, take the lines off, take all the small nuts out...it may be pretty rusted, use some good anti-seize if you are afraid of breaking the studs.
-Carefully pull the pump out, its a little awkward to pull out, just do it gently, and manuever it side to side, every which way to get it out.
There you go, just do the reverse for installation. Also, be sure you have the smallest amount of gas in the tank so you don't stank up the car too much. Also clean off the top of the tank before removing anything, mice love to store nuts and stuff up there, be sure none of that gets in the tank.
runninstrong is offline   Reply With Quote
Old 05-13-2008, 05:17 PM   #3
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
yea no dropping the tank...I changed my fuel pump in about 30min in a parking lot last year. No sweat.
Kawikid20o2 is offline   Reply With Quote
Old 05-15-2008, 12:17 AM   #4
ROC pit-bull
Member#: 67814
1995 legacy L
white
my legacy has the fuel pump in the sending unit, its the access on the passenger side
ROC pit-bull is offline   Reply With Quote
Old 05-15-2008, 03:25 PM   #5
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Uh, that does not release the fuel pressure of the fuel system, only the tank? One way to release fuel pressure is to disconnect the harness for the fuel pump, and then crank the starter on the car for a little bit.
jey is offline   Reply With Quote
Is there a part number for this (hatch latch area) breakfasteatre Legacy Forum 18 08-27-2007 12:43 AM
is there a knock-off for this chargespeed hotness SQ3.0dotJP Interior & Exterior Modification 6 06-12-2007 12:57 PM
Cobb write up in this months Modified... silver_rocket Texas Impreza Club Forum -- TXIC 6 11-14-2006 02:02 PM
timing belt write up for 2.5RS- I searched civic2scooby Service & Maintenance 3 01-16-2005 11:03 PM
HKS SSQV BOV Kit Install write up for MY02 WRX. View Askew Bay Area Impreza Club Forum -- BAIC 3 04-06-2002 06:08 PM
