Old 05-13-2008, 02:40 PM   #1
SBPhilly
Member#: 134454
2004 Impreza WRX STI
Silver/Silver
Default How do I setup an Accessory fuse box?
I am trying to wire the led rings on the headlights of my 98 accord(my other car is an 04 STI) and I want to run them seperate from the other lights, I have a switch for them I want to mount on my dash.
So to setup an accessory fuse box do I just tap right onto the battery terminal or do I run the power from somewhere else??
Thanks in advance
SBPhilly is offline   Reply With Quote
Old 05-13-2008, 04:16 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If the new circuit doesn't require very much current you could just tie into one of the exsisting fuse circuits by using a fuse tap. This replaces an exsisting fuse with a fuse holder. You then place the regular fuse in one slot and then another slot is filled with a fuse to run to the new circuit. A good parts store will have these.
Old 05-14-2008, 02:09 PM   #3
SBPhilly
Member#: 134454
Silver/Silver
Ok I found a fuse tap but it is for the larger sized fuse's do you know if they make a mini fuse tap??
Old 05-14-2008, 10:48 PM   #4
Cougar4
Member#: 53443
Winestone
They do have them available for the smaller fuses also.
Old 05-15-2008, 12:16 AM   #5
jonney_boy
Member#: 28747
06 WRX
In my pickup where there is lots of space I have one of these installed
http://bluesea.com/category/5/21/productline/126
it gives me 12 circuts to play with...... I power it with a fused 4 guage from the battery.... way overkill but works GREAT
I have a much smaller version of this for the wrx..... (soon to be installed)
jonney_boy is offline   Reply With Quote
Old 05-15-2008, 03:09 PM   #6
SBPhilly
Member#: 134454
Silver/Silver
Jonney_boy so you just run power to the bottem terminal??
and ground the top terminal and then the rest of the terminals are to run the power to the corresponding accesory?
WHere can I get one of these??
Old 05-15-2008, 11:38 PM   #7
jonney_boy
Member#: 28747
06 WRX
yes.. you have to run a FUSED power line to the bottom terminal.. and the top terminal is for ground (if you want to use it... else purchase one without the ground.. they are much smaller and easier to fit under the hood).
Each accessory can have one circuit....... fused for the wire size you deside to run.
Again, these are "way" overkill for your use.. but they do work very well.... I picked mine up from
http://www.northeastmarineelectronic...OD&ProdID=5604
ps.. the total thing is good for 100 amps... but each circuit is only good for 30 amps...... so you can't power anything really power hungary with it (larger stereo amps or good sized inverters).
How do I change the accessory belts in 03 wrx? Lordhowe Service & Maintenance 12 06-04-2009 03:43 PM
How do I know what size fuse to.... jdiddy Car Audio, Video & Security 31 03-12-2007 07:40 PM
How do I install an 02 WRX stereo in an 04 STi? adrive43 Car Audio, Video & Security 6 08-23-2005 11:47 PM
How do I actually tap a fuse for gauge install? phyzical Electrical & Lighting 14 02-15-2005 05:07 PM
***? car won't start? how do u take out a fuse scobaru Mid West Subaru Owners Club Forum -- MWSOC 4 02-14-2005 01:27 AM
