Old 05-13-2008, 06:21 PM   #1
knakai1
Member#: 51846
2004 WRX Cobb Stg. 2
Java Black Pearl
Default Nuts and Bolts of a 07 STi 6 Speed into an 04 WRX
I wanted to get an idea of what all I would need if I piece a 6MT package together separately. I need a better idea if I need Subaru specific nuts and bolts basically to attach such things as the shifter linkage (as I believe it is different than the 5 speed), tranny mount, and so on.
Below is what I will have purchased separately:
6 MT (includes 6MT Clutch Fork, Slave Cylinder)
Clutch Assembly, Flywheel
6MT Tranny Mount
Automatic Driveshaft
Axle stubs, circlips, and axle seals
STi Short Throw shifter linkage
Any feedback would be appreciated.
knakai1 is offline   Reply With Quote
Old 05-13-2008, 06:30 PM   #2
MrSlowbaru
Member#: 129231
2005 wrx
cgm
a new throw out bearing would be nice
MrSlowbaru is offline   Reply With Quote
Old 05-13-2008, 07:13 PM   #3
SlammedREX
Member#: 134474
RIP
03 Wrx
6MT Tranny Mount
I did the same swap in my Bugeye and I dont think your missing anything. Its been over a yr since the swap. But I think your good.
SlammedREX is offline   Reply With Quote
Old 05-13-2008, 07:40 PM   #4
Mcahol3
Member#: 141517
02 WRX PSM
08 Forester X
Not to thread jack but what auto drive shaft are u using?
let me know im searchin for one. would a forester or legacy auto tranny drive shaft work and what years?
Mcahol3 is offline   Reply With Quote
Old 05-13-2008, 07:46 PM   #5
MasterKwan
Member#: 98961
2003 WRX
You don't need to replace the clutch unless it needs replacing. Your current clutch parts will work just fine. Your 5MT Slave Cylinder will work fine too. You do need the fork though.
I did this swap not too long ago. Using the 5MT clutch, 5MT slave, 5MT TO bearing, and clutch fork pin.
Price no object, the STI clutch is a fine piece. You don't HAVE to install it though.
Old 05-13-2008, 08:26 PM   #6
SlammedREX
Member#: 134474
RIP
03 Wrx
I used a 07 sti drive shaft cause its alittle thicker then my old wrx drive shaft and all I had to do was drill out the holes on the driveshaft part that mounts to the diff and I was good to go. I just had to drilled the holes outward enough to line up with the diff....
Not really as ghetto as you might think. Its working for me great.
Old 05-13-2008, 08:34 PM   #7
Mcahol3
Member#: 141517
02 WRX PSM
08 Forester X
yeah ive seen that done before but its alot harder to find a sti drive shaft locally than it is for a legacy or forester
Old 05-13-2008, 08:59 PM   #8
SlammedREX
Member#: 134474
RIP
03 Wrx
Mine came in a package deal 07 STi tranny w/ 200 miles on it FTW
Old 05-13-2008, 09:41 PM   #9
knakai1
Member#: 51846
Java Black Pearl
I am not sure about the legacy and forester driveshaft, but I believe that any automatic tranny that mates to an R160 Rear diff will be a direct bolt on, but definitely try to verify.
Still any idea of ACTUAL bolts, nuts, or washers that I will need, that I cannot reuse from the existing 5mt?
Old 05-13-2008, 09:45 PM   #10
MrSlowbaru
Member#: 129231
2005 wrx
cgm
iirc you need a couple extra bolts for the sti clutch flywheel pressure plate combo
Old 05-13-2008, 10:03 PM   #11
Mcahol3
Member#: 141517
02 WRX PSM
08 Forester X
yeah i saw in a post that i guy had said he had used a 96 leg auto driveshaft and another guy sayin he has a auto driveshaft from a forester on his set up.. i dont know years or models dont wanna just buy any ol driveshaft.
Edit:Examples
Originally Posted by fusionchicken View Post
for your driveshaft if it fits between the 6spd and 3.90 R160 it's most likely customized, or off of an automatic subaru. for example i'm running an automatic Forrester driveshaft on mine - 05 6spd mated to a 3.90 R160.
And
Originally Posted by mcu81 View Post
I bought a USDM 04 STI 6speed for 2800 on the dot, including clutch, flywheel, driveshaft, shifter assembly, even the shift knob. got a r160 w/3.9 gear in it for 250, right here on nasioc, turns out the sti shaft wont bolt to the modded r160, so i get a auto shaft from a 96 L for 100 bucks.
-mikey
Old 05-13-2008, 10:04 PM   #12
Mcahol3
Member#: 141517
02 WRX PSM
08 Forester X
could we just find these at a hardware store and match them up or somethin from subaru?
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 808 08-12-2015 09:01 AM
WTB 06-07 Sti 6 speed transmisssion, and what ever else to swap into wrx felixwankel88 Private 'Wanted' Classifieds 8 09-20-2009 10:55 PM
2 questions about an STI 6 speed into an '02 wagon Cyclops Brakes, Steering & Suspension 17 04-04-2008 04:03 PM
How to put a 2007 usdm sti 6 speed into my 2003 WRX InfamousDX Transmission (AT/MT) & Driveline 11 10-27-2007 12:54 AM
05' STI Guage Cluster into an 04 WRX subietech420 Electrical & Lighting 7 04-16-2006 01:17 PM
