Old 05-13-2008, 08:28 PM   #1
clbd39
Member#: 104078
2013 WRX
Default Help with Bugeye Front Bumper Removal
First off, I did search and found all the needed items to remove... I just can't figure out where all the clips are... I'm doing this to be able to get my OEM lip on well
below this message I have the Message Subie Gal posted in a post a while ago...
Anyways I removed...
the grille, grille sides, headlights, foglights and now I'm getting the clips off, are there any actual screws holding the bumper on? I have removed the 4 front and center, the one on either side where the headlight goes and one more on either side on the backing of the bumper, still partially on top, where are the other clips, if any?
So far that's 9 clips basically on the top of the bumper, what else should I remove?
I'll attach a pic so if anyone has some microsoft paint skills they can point to them...
Side note, it seems to be stuck around the foglight areas...
Originally Posted by Subie Gal View Post
bolts in behind the bumper where the bumper meets the fender
so basically
remove those 2 bolts
remove grille
remove grille side pieces
remove headlights
remove fog lights
remove every bumper clip you can see, top and bottom
then give it a little tug
if it doesn't come free, you've missed something.
go back and see where it's stuck - remove clips, tug again
it's really fairly simple
clbd39 is offline   Reply With Quote
Old 05-13-2008, 08:35 PM   #2
wrxguy02
Member#: 174672
02 AW WRX
02wrxX2,06sti,94wgn,04sti
just jack the car up on jackstands or something and put the lip on that way.... your making it a whole lot harder than this needs to be,
just hold it up with panters tape and screw that ****ing thing on...
theres no need to take the bumper off...
just put 2 or 3 screws in each side then put the middle up then work your way around each side...
wrxguy02 is offline   Reply With Quote
Old 05-13-2008, 08:36 PM   #3
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Subarus are held together by clips didn't ya know that?
Seriously though I think that's all of them... been awhile since I've done it but just pull forward and up c a r e f u l l y and it should come right off
silverF4turbo is offline   Reply With Quote
Old 05-13-2008, 08:40 PM   #4
clbd39
Member#: 104078
2013 WRX
Well I can't get a few of the j-springs or whatever they are without the bumper coming off or something, I dunno lol But I thought this would be easier, and I'm pretty much there to having the bumper off...
the pics...
Old 05-13-2008, 09:18 PM   #5
subaru3169
Member#: 55252
* pullup bar *
i think you got everything and the bumper should slide right off.. i don't understand how it can be stuck on the fogs area
subaru3169 is offline   Reply With Quote
Old 05-13-2008, 11:35 PM   #6
clbd39
Member#: 104078
2013 WRX
i don't know either, i tugged and tugged at it earlier, i got the edges off but it wouldn't budge...
Old 05-14-2008, 02:56 AM   #7
subaru3169
Member#: 55252
* pullup bar *
can you see anything on the inside of the bumper, like towards the interior from the opposite way?? or rather.. the backside of the fogs
Old 05-14-2008, 03:10 AM   #8
FireScoob
Member#: 86642
If I remember correctly there are clips that attach the fender well liner to the bumper. Also there should be a screw that holds the fender to the bumper as well. You will have to peel back the fender well liner to see it.
I don't remember what exactly is there... but there is something that holds the fender to the bumper. I remember I thought I had everything disconnected and still couldn't get the bumper off. Then I discovered the issue.
FireScoob is offline   Reply With Quote
Old 05-14-2008, 04:40 AM   #9
Letx
Member#: 100655
2003 Wrx
Sonic Yellow
^yep. when i took my bumper off, there was a screw holding the fender to the bumper. it's right behind the fender liner just like fire scoob said. It was a pita to take off the bumper until i figured out that there was a screw hold the bumper & fender together.
Letx is offline   Reply With Quote
Old 05-14-2008, 04:56 AM   #10
subaru3169
Member#: 55252
* pullup bar *
i think the op has stated that he already took that bolt that holds the fender to the bumper on the very ends.. which makes this so perplexing
Old 05-14-2008, 05:05 AM   #11
Letx
Member#: 100655
2003 Wrx
Sonic Yellow
hm..if that's the case then I'm lost. ghetto rigged zip ties from previous owner? I remember it wasn't THAT hard to take off my bumper.
Old 05-14-2008, 11:20 AM   #12
clbd39
Member#: 104078
2013 WRX
Well I haven't taken any actual screws that hold the plastic bumper on...
I have tazken 9 of those expanding black plastic snap on things off...
5 were right on top, 1 on each side on the inside right in front of the fender well, and one on each side basically where the headlight was...
if there's an actual screw somewhere that would make sense, maybe if someone has a pic of their bumper off that would show where everything is attached lol...
i really don't feel like ripping my bumper today lol
Old 05-14-2008, 12:47 PM   #13
porkchop
Member#: 12288
02 WRX
there are 3 more clips, one on each side and one in the middle. you have to undo the fender liner where it attaches to the front bumper and the under tray. You should be able to spot the clips then.
Tommy
GST Motorsports
porkchop is offline   Reply With Quote
Old 05-14-2008, 12:58 PM   #14
Letx
Member#: 100655
2003 Wrx
Sonic Yellow
If you haven't removed this screw, that might be it. connects the bumper to the fender. Here's a pic of the bumper & fender, might help you.
Old 05-14-2008, 03:10 PM   #15
clbd39
Member#: 104078
2013 WRX
/\ that definitley might be it!
thanks a lot!
i'll be trying this again on the weekend, I just put everything back together and put the air splitter on for now, the front lip if a bit warped it seems, and i don't want to drill into my bumper to get that piece to pay flat so now i get to rethink some things lol
thank you a lot though!
Old 05-14-2008, 03:22 PM   #16
subaru3169
Member#: 55252
* pullup bar *
argh!! i thought you had said you already removed those hahah.. well glad you know now
Old 05-15-2008, 10:49 PM   #17
clbd39
Member#: 104078
2013 WRX
well since we're kind of on topic, does anyone know what to do to take care of the front lip, the instructions say to screw into the bumper but i don't want to make a hold in it :S
Old 05-16-2008, 12:50 AM   #18
subaru3169
Member#: 55252
* pullup bar *
in letx's pic.. towards #2 on the bumper in the fender well, there are holes.. lips should have preexisting holes that bolt up to that and the holes along the bottom of the bumper
Old 05-16-2008, 02:43 PM   #19
clbd39
Member#: 104078
2013 WRX
i'm meaning on the front of the lip, it sticks out about an inch or so, not exactly flush with the bumper......
Old 05-17-2008, 12:00 AM   #20
designfate
Member#: 114502
lets keep that to PM's
designfate is offline   Reply With Quote
Old 05-17-2008, 12:04 AM   #21
yellowspec
Member#: 177473
03 wrx spec r1
yellow
hey man u un do you splash shield on the bottom and there 2 or 4 clips that got to the re bar i have mine off right now as im re doin it complete so ya take the bottom one out and if u really want the ones in the wheel wells helps out alot makes things easier
yellowspec is offline   Reply With Quote
Old 05-17-2008, 12:08 AM   #22
jaypt802
Member#: 149730
2002 Impreza WRX
there is also a push clip between the foglight and the brake ducts all the way at the bottom i'll take a picture of it in a bit and put it up on here, u have to take the bottom plastic shields off to get to that push clip!!!
jaypt802 is offline   Reply With Quote
Old 05-18-2008, 04:21 PM   #23
Letx
Member#: 100655
2003 Wrx
Sonic Yellow
any luck? keep us posted
Old 05-20-2008, 01:34 PM   #24
clbd39
Member#: 104078
2013 WRX
no i haven't tried yet, i'm goign to have to drill into the bumper i guess everyone with the oem lip does.... ergh
Old 03-12-2012, 09:25 AM   #25
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
I am doing this this weekend, let me get it straight......
5 clips under the grill
2 screws holding the side of the bumper to the fender
Are their more clips?
And do u really have to remove the fog lights or just undo the connection plugs?
shamrock 05 is offline   Reply With Quote
Urgent help needed!!! 05/06 STI front bumper removal silvscorp Interior & Exterior Modification 6 06-04-2007 01:55 PM
WTB: Bugeye Eyelids, Bugeye front bumper cover, and driver side fender. twofast4u MWSOC Private Classifieds 0 01-22-2007 12:14 PM
pic. request. GD8 with front bumper removed. rob oneill Member's Car Gallery 0 02-16-2004 02:26 PM
Help with WRX front bumper reddog15 Interior & Exterior Modification 10 07-17-2002 10:55 PM
Front bumper removal help jasonmolinari Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-07-2002 11:56 AM
