Welcome to the North American Subaru Impreza Owners Club Monday June 1, 2015
Old 05-13-2008, 10:23 PM   #1
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
Default Which perspective is correct(chk oil level)
Ok read the faq,
and it states to check oil when engine is warm. 3 People have stated to me that i should check it first thing in the morning when oil is in the oil pan(obviously engine is cold). After work on day, car sat for about 4 hours in parking garage, checked the oil and it was low ok. So i drove to get some oil, checked it again and this time it reads normal. Wondering which is the correct answer, when engine is hot or cold.
Dr. octagon is offline   Reply With Quote
Old 05-13-2008, 10:42 PM   #2
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
After a drive, wait a few minutes so the oil can drain into the oil pan, then check it. It should be close to full or a little above the full mark. If its past the notch in the dipstick there's too much oil.
rexman2002 is offline   Reply With Quote
Old 05-13-2008, 10:52 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
at least for me, i get the same reading completely cold as i do if I check 15 minutes after shutting it down. Just need to give it enough time to completely drain into the oilpan.
Old 05-14-2008, 09:38 AM   #4
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
ok, well i am going to check the oil this morning.
Tired of searching, Can someone tell me which cylinder is 1 and which is 4? crowbar Off-Topic 4 10-24-2006 02:47 PM
Which is better Oil Pressure or Temp gauge? spitfirezip100 Electrical & Lighting 4 11-23-2004 03:40 PM
Of that 3 plug bulb connector, which one is high, and which one is for low beam? Kwyjibo Electrical & Lighting 1 10-21-2003 08:07 PM
Stupid oil question (not which one is best) live311 Service & Maintenance 15 08-15-2002 08:28 AM
Which pully is which? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-09-2001 03:57 PM
